Vaillant ecoTEC PLUS F29 Error Code: Troubleshooting Power Outage & Water Supply Issues
kasiaszm 29361 2
  • #1 16912601
    kasiaszm
    Rate: 96
    We had a pretty long power outage today. When he came back, the error code 29 + flashing tap icon appeared on the stove. It seems to me that I had it before and that it was due to the lack of water supply during the breakdown ...
    I tried to turn it on to no avail. Please help :)
  • #2 16916065
    ls_77
    Help: 500
    Rate: 947
    Error F.29 in Vaillant ecoTEC boilers concerns the failure to detect the flame during operation. Ie. During the burner operation, there was a gas failure and then the boiler could not start. This could also mean a damaged gas valve or electronics.
    Switching the boiler off and on again does not help. You have to reset the boiler with the "failure reset", that is with a gray button with a symbol of a crossed flame. Then the boiler goes through a test procedure and if everything is ok, it tries to ignite the burner. Further unsuccessful attempts cause the crash again and error F.28. And this may mean a visit to the website because there is nothing you can do yourself.
  • #3 16922572
    kasiaszm
    Rate: 96
    Thank you for your help. It turned out that there was a gas failure after the power failure ;) The gas was probably cut off automatically due to a power failure.
