Connecting 5.1 Speakers to H96 PRO+ TV Box & Projector via SPDIF: NAS Server Setup, Budget PLN 3100
dziajl91 4407 5
  • #1 16792717
    dziajl91
    Rate: 10
    I am going to buy a projector and a tv box. I wonder how to connect 5.1 speakers to this set.
    I will add that TV because it will download multimedia from the NAS server.
    The tv box has an spdif output but I don't know how it works.
    Tv box I found H96 PRO + 3 with Android 7.1
    I do not have a specific projector model.
    I have a budget of PLN 3100 for everything
  • #2 16797802
    procsa
    Help: 173
    Rate: 364
    If the TV BOX has an optical output, what's the problem? Do you connect an optician to an receiver / amplifier, because you don't write anything about it, what do you want to get this sound from, probably not from the speaker from the projector / projector?
  • #3 16798102
    dziajl91
    Rate: 10
    Well, I don't have an receiver. The question is whether it can be directly connected to the speakers / soundbar anything.
    Because such a set of speakers + receiver is quite a cost. I want to get the 5.1 effect from the tv box at the lowest possible cost. Maybe you can recommend some speakers with spdif input to connect it directly, can't you?
  • #4 16798225
    procsa
    Help: 173
    Rate: 364
    This TV box also has an analog Audio Video (AV) output, so theoretically it can be connected to "everything", the problem may be that when connecting the AV cables, the image will be fed only through this connector ... rather it should not be, but you never know, I have a similar box myself, but I have never tested analog outputs, I didn't even have a cable for it, and I doubt that it is included in the set.
    If you want to buy the cheapest 5.1 set with optical input, look for "alledrogo" or anywhere, there is plenty of it, no one will look for you :) Or you can look for a used home theater with an optical input, cost of 100-300 PLN ...
  • #5 16798231
    dziajl91
    Rate: 10
    I don't expect anyone to be looking, I just want to know what to look for. So if I find any speakers with spdif input, everything will work for me?
  • #6 16798286
    procsa
    Help: 173
    Rate: 364
    Theoretically, yes, but no one will guarantee you if someone will have functional equipment :)
