Create WIN10 System Backup on Pendrive: Solve 'Wrong Medium for Saving Data' Issue
gothic77 7485 10
How can I create a Windows 10 system backup on a USB flash drive when Windows says the flash drive is the wrong medium for saving data?
You cannot save a Windows system image to a USB flash drive; use an external hard drive in a USB enclosure, a second internal disk, or a docking station with a 2.5" drive instead [#16793729] If you are using a desktop, install an additional disk; if it is a laptop, connect the backup drive via USB [#16793729] To restore the image later, Windows still needs bootable recovery media burned to a CD/DVD, unless you use a separate cloning program that can clone the disk to a second drive [#16793824][#16793853]
  • #1 16793709
    gothic77
    Rate: 84
    I am asking for help, because I wanted to rip the whole system - a backup of the Win10 system on a pendrive, because I have no disk space, and besides, I only have a C drive on which I can not save, because I can not see.
    When choosing a USB flash drive, I have a message that this is the wrong medium for saving data and I cannot go to the next step.
    How can you solve the problem?
  • #2 16793729
    Pedros050
    Help: 2471
    Rate: 3927
    You only make a backup on a disk under the USB pocket, if it is a laptop and if you are a stationer, then mount the additional disk to the computer.
  • #3 16793735
    gothic77
    Rate: 84
    ... and in the case of e.g. a tablet? :)
  • #4 16793741
    Pedros050
    Help: 2471
    Rate: 3927
    And what OS on the tablet?
  • #5 16793742
    gothic77
    Rate: 84
    It was Win8.1, but they did update on Win10.
  • #6 16793752
    Pedros050
    Help: 2471
    Rate: 3927
    And you want to make a copy of the system, save it to the ONE DRIVE cloud or via a mini USB connector to a pocket with a 2.5 "disk
  • #7 16793814
    gothic77
    Rate: 84
    Ok, I managed to do it by using a docking station, but the next problem, namely creating a disk to repair the system, or uploading an image ... I can't create it, because I am calling for a CD burner :)
  • #8 16793824
    Pedros050
    Help: 2471
    Rate: 3927
    And so the boot disk must still be burned so that you can load copies of the system.
  • #9 16793844
    gothic77
    Rate: 84
    ... and e.g. you can restore an image of an already created system on another, uploaded system in case of failure?
    - without creating this boot CD?
  • #10 16793853
    Pedros050
    Help: 2471
    Rate: 3927
    Clone, but you must have the right program. To clone a disk into a 2nd disk.
  • External DVD drive causing system repair disk error
    #11 16796319
    gothic77
    Rate: 84
    I got a topic with an external drive (DVD recorder), but as it is in my life ... I encountered such an error while creating the repair disk - Unable to create the system repair disk. The parameter is incorrect (0x80070057)
    I looked for information on the microsoft website ... and all in all I could not do / fix it. I even downloaded the Microsoft FIX program, which will not work either, because it shows that I need to check the internet connection (WiFi works approx.)
    Please help. I have updated the entire system.
    Anyone have any idea to solve this problem? :)
The discussion revolves around creating a Windows 10 system backup on a USB flash drive, with the user encountering a "wrong medium for saving data" error. Initial suggestions include using an external hard drive or a docking station to facilitate the backup process. The user later reports success with a docking station but faces issues creating a system repair disk, receiving an error code (0x80070057) related to incorrect parameters. Various solutions are proposed, including using cloud storage (OneDrive) and cloning software for disk duplication. The conversation highlights the challenges of backing up and restoring systems without adequate hardware or software tools.
