Beko DPY 8506 GXB1 Dryer - Prolonged Drying Time, Wet Laundry, Clogged Evaporator Issues
dawidor5 26550 5
  • #1 17151373
    dawidor5
    The dryer dries very poorly, it lasts 3-4-5 hours, the laundry is still wet / damp. The heater works and the water tank is empty and everything goes to the sewage system. The fluff filter is always cleaned before drying and additionally emptied during drying. The filter in the drawer (condenser filter) cleaned regularly. Fluff accumulated on the evaporator, still wet or dried, which cannot be drawn in with a vacuum cleaner, as described / suggested cleaning the evaporator in the dryer's instruction manual. What to do and how to get rid of these fluff from the evaporator?
    Thank you
  • #2 17151815
    MARCIN.SLASK
    Home appliances specialist
    Help: 1036
    Rate: 2650
    It would be ideal to replace the heat pump set (no heater is there), but that's 3/5 of the new dryer. Clean is not easy. It is necessary to soak (preferably with a suitable agent) and mechanically, clean carefully so as not to bend the lamellas. It's best to disassemble the entire dryer, remove the entire heat pump and then clean it thoroughly. You may also find that the compressor no longer has the required capacity and will delay the drying.
  • #3 17153838
    dawidor5
    I would prefer not to untangle anything, maybe we can do some cleaning, we'll see.
    thanks
  • #4 17387831
    mr_roba
    Rate: 19
    I have the same dryer. For me it happens every few months (the dryer goes at least 3 times a day) as the moisture sensors inside the drum get clogged. You need to pick a fluff with a toothpick and spray, for example, liquid for cleaning windows and works.
  • #5 20285976
    Tony2k
    Can you explain please where is located the sensor you're speaking? Thanks.
  • #6 20288163
    mr_roba
    Rate: 19
    When you open the door, at twelve o'clock, a few centimeters from the front, there are two pinheads separated by 5 cm.
