Thermomix TM21 - INA F-228055 Bearing Replacement for Knife, 19x5.8x16.2 Dimensions
marian_212 9906 1
  • #1 16798567
    marian_212
    Does anyone know where I will get this placenta. I bought TM21 for a pear cap and don't want to invest a lot in repair. I pulled out the bearing, has dimensions 19 x 5.8 x 16.2 and inscriptions INA F-228055 ??? , line below 02 / J4. invisible numbers with question marks, first 2 in the name - 50% certainty that it is 2.
    Will I get one?
    Regards
    M.Ł.
  • #2 17504394
    kristofss
    Rate: 53
    AND HOW managed to buy it? I also bought such a thermomix and I wonder if it should be like that. The knife turns with slight resistance under the finger. I wonder if it is a question of seals that are tight and it should be replaced, the bearing needs to be replaced, there is no leakage at all.
