[Solved] Thermomix TM5 Issue: Knife Stops Rotating with Load, Motor and Screw Functioning
eik 23022 4
  • #1 18646645
    eik
    Rate: 9
    Hello!
    The knife in the Thermomix stopped spinning, i.e. the screw did, but the blades stayed in place. They were still spinning when the container was empty, but one large frozen strawberry was enough and at faster speeds a slight smoke came out of the knife screw...
    We bought a new knife, everything worked fine for a week. And the same thing again: the screw is turning, the knives are stationary.
    Can anyone advise? Is it the fault of the knife, the engine, or something else...?
  • #2 18647876
    ssss
    Help: 471
    Rate: 1824
    The knife is not original and that`s how it will be
  • #3 18647905
    eik
    Rate: 9
    But the first one was the most original....
  • #4 18651068
    ssss
    Help: 471
    Rate: 1824
    All that remains is to advertise it
  • #5 19704180
    eik
    Rate: 9
    Finally, we disassembled the entire Thermomix, cleaned it thoroughly and everything started working. With a new knife.
