Thermomix TM6 Error C584: Wi-Fi Connected, Cannot Access Cookidoo - Repair Costs & Motor Issues
sledziu109 19449 5
  • Factory reset did not clear C584 login fault
    #1 20367844
    sledziu109
    I have a Thermomix TM6 after the warranty with error c584, the problem is that it is supposedly connected to wi-fi, but you can't log in to cookidoo, maybe someone knows how much such a repair will cost and whether it's worth playing in repairs. The equipment was reset and restored to factory settings and nothing helped, everything else seems to work, but the motor seems to be weaker during operation.
  • #3 20368506
    sledziu109
    Yes, but the cook key is in tm 5 and I have a problem in tm 6
  • #4 20368556
    mipix
    Help: 495
    Rate: 1483
    Well, it looks like there's no way to do it without replacing the motherboard. In model 5, sometimes even replacing the dongle did not help.
    According to the descriptions, you can try the method entitled PARANOIA. That is, repeating the same actions over and over again (reset) and expecting different results.
  • #5 20368631
    sledziu109
    That's what I'm afraid of, equipment without warranty and the motherboard probably costs PLN 1,500
  • #6 20793586
    griszkasty
    If the problem persists, try restoring the device to factory settings, sometimes it helps.
