[Solved] Renault Laguna 2: Starting Only with Clutch Depressed - Not a Reverse Sensor Issue
szpadyzor46 9369 10
Why does my Renault Laguna 2 only start when the clutch pedal is depressed, even though the reverse lights work and the start button used to light up after moving the gear lever?
The problem is likely a separate gearbox/gear-lever sensor or its wiring, not the reverse-light switch alone, because the car may not see the lever position and then it will not start or even light the start button [#16881757] The reverse sensor and the clutch/lever-related sensor are separate sensors in one housing, so working reverse lights do not rule out a fault there [#16881757] Check the harness and the sensor itself, and if needed replace the 3-pin reverse/gearbox sensor [#16952101] One reply also notes that this is a different ignition/interlock block than the reverse switch, which matches the symptom of only allowing starting when the clutch is pressed [#16881580] A computer diagnosis was also recommended to confirm what the UPC sees from the sensor input [#16881727]
  • #1 16881556
    szpadyzor46
    Hello, I have a problem with my Lagoon, which only starts when the clutch pedal is depressed. The rear lights work properly so that it's not a reverse sensor. Some time ago, the start button lit up to be ready to fire after moving the lever. I will add that I haven't connected it to my computer yet. Any ideas?
  • #2 16881580
    JacekCz
    Help: 760
    Rate: 1464
    Cars have a ignition block on the run.
    This is a different sensor than reverse. If it broke, it would look like that.
  • #3 16881596
    szpadyzor46
    The thing is that the car does not start (and fired) when it is thrown, it will light only when I push the clutch.
  • #4 16881621
    JacekCz
    Help: 760
    Rate: 1464
    What do you not understand in my statement?
    (you don't write punctuation completely illegibly, as if you didn't write. Practice the commas in this sentence: pardon, no, condemn )
  • #6 16881651
    szpadyzor46
    A similar failure but the guest did not work the reversing lights which indicates a reverse sensor, for me the reversing lights work so that it is some other sensor.
  • #7 16881727
    g107r
    Help: 811
    Rate: 993
    @ szpadyzor46 , i.e. you won't start the car in reverse, but in forward gears already? Is this what you are heading for?
    The reverse is the only thing you took note of?
    Cool, does this have a motion sensor? Didn't anyone suggest looking under the jack bellows? Under the clutch pedal?
    Do not look, go to the computer, there they will diagnose and fix for a few hundred what you could have checked yourself.
  • #8 16881757
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    If UPC does not see looseness from the box sensor, it will not fire and will not illuminate the button.
    The slack sensor and reverse sensor are separate sensors in one housing. [Pawel Wawa]
  • #9 16951516
    szpadyzor46
    It will only fire when you press the clutch, no matter what gear, at ease the same way.
    There is nothing under the bellows, and the sensor on the clutch works properly.
  • #10 16952101
    Pawel wawa
    Help: 1262
    Rate: 4432
    Renault Laguna 2: Starting Only with Clutch Depressed - Not a Reverse Sensor Issue To check the harness or replace the reverse sensor. Must be three pin!
  • #11 18048500
    szpadyzor46
    I sold a lagoon, I bought a BMW :P
The discussion revolves around a Renault Laguna 2 that only starts when the clutch pedal is depressed, with the owner confirming that the rear lights function properly, ruling out a reverse sensor issue. Various users suggest that the problem may be related to the ignition block or a separate sensor malfunction. The owner clarifies that the car does not start in any gear without pressing the clutch and that the clutch sensor appears to be functioning correctly. Recommendations include checking the wiring harness and considering a diagnostic check to identify the issue more accurately.
