NodeMcu V.3 vs. "bare" ESP8266-12 - launching ESPEasy
maximus22_kr 2664 7
  • #1 16817698
    maximus22_kr
    Rate: 20
    I wanted to design my own board with ESP8266. First I wanted to check if on this version ( version 12 with antenna socket and antenna ).
    I connected according to the schematic below
    NodeMcu V.3 vs. "bare" ESP8266-12 - launching ESPEasy .
    During programming I shorted GPIO0 to Gnd, then Reset and with ESPEasy Flasher I uploaded the file ESPEasy_v2.0.0-dev12_normal_4096,bin.
    Later I disconnected GPIO0 and reset, a new network should appear, but I wait several minutes and nothing.
    I've looked at the NodeMcu schematic and the only difference I can see is that there is no 10K resistor on GPIO2 on mine. AND that GPIO15 is shorted directly to Gnd on mine and not via a resistor. Before I start cutting GPIO15 off from Gnd ( I have it all on a board with a 2.0mm raster connector ) I wanted to ask if, according to my colleagues, this should work, or does this version of the module require a different batch ?
  • #2 16817776
    inot
    Help: 450
    Rate: 819
    I have reviewed the NodeMcu schematic and the only difference I can see is that I have no 10K resistor on GPIO2. and that GPIO15 is in my case shorted directly to Gnd and not via a resistor
    This does not play a role. If GPIO15 is not used as an output then you can connect directly from GND.
  • #3 16817807
    piterek-23
    Help: 162
    Rate: 427
    maximus22_kr wrote:
    First I wanted to check that on this version ( version 12 with antenna socket and antenna ).
    The ESP-12 has the antenna on the PCB and the ESP-07 has the antenna on the PCB + antenna connector.
    If you have an ESP-07 then upload the soft ESPEasy_v2.0.0-dev12_normal_1024bin
  • #4 16817999
    maximus22_kr
    Rate: 20
    If you have ESP-07 then upload the soft ESPEasy_v2.0.0-dev12_normal_1024bin
    and this is the solution to the problem. I saw a version listing somewhere and the larger version with antenna and antenna slot had a flash of 4M
    Now I have:
    Code: Bash
    Well it just remains to choose a GPIO that is "safe" to use. To me it seems that :
    GPIO4, GPIO5 - I2C
    GPIO2 - DS18B20
    GPIO12 - DHT22
    GPIO13, GPIO14, GPIO15, GPIO16 - buttons ( possibly MAX6675 ) , I don't know how about GPIO15
    Regarding this version with antenna on PCB, I tried to play different versions to it and I always have:
    Code: Bash
  • #5 16818037
    inot
    Help: 450
    Rate: 819
    GPIO15 only needs to be in the L state at reset , and then it can be used freely.
    When it comes to this version with the antenna on the PCB, I tried to play different versions to it and I always get:
    Stack error means that these addresses do not exist.
  • #6 16818170
    maly_ninja
    Help: 10
    Rate: 13
    The schematic is correct, so this is unlikely to be the cause of the error.
    Even if the module has a 4M flash, it should work if the 1M version is uploaded, the other way round there may be some problems.
    Regarding GPIO selection, if there is a nodemcu firmware there is a note on the page:
    [*] D0(GPIO16) can only be used as gpio read/write. No support for open-drain/interrupt/pwm/i2c/ow.
    But I don't know if it's just this firmware that has it that way, or if it's some limitation of the ESP8266 (I didn't go into it because I didn't need it).
  • #7 16818287
    maximus22_kr
    Rate: 20
    Regarding the GPIO selection, if there is a nodemcu firmware on the page there is a note like this:
    I tested this practically, the DS18B20 thermometer did not work on this GPIO, neither did the DHT. It will serve as a possible input/output, although I intend to use the PCF8574 for this purpose ( I don't have the MCP230117, only the MCP23016 version on I2C - just that there isn't room for that many inputs/outputs in the setup - 12 max)
    GPIO15 only needs to be in the L state at reset, after that it can be used freely.
    that's good to know, I'll put a jumper on the PCB in case I have to reset manually
    As for the ESP8266 version with the antenna on the PCB, the same error persists, I've tried uploading older versions ( e.g. R120 ) but nothing either. I only have two of these, the rest are versions with antenna and socket, so no problem, I will upload traditional soft to them.
  • #8 16818329
    inot
    Help: 450
    Rate: 819
    If GPIO15 in normal operation has an output function then even the jumper should not be directly connected to GND but via a resistor e.g. 3.3k. Otherwise a short-circuit may occur after programming (when the pin sends a high level):
The discussion addresses issues encountered when programming a "bare" ESP8266-12 module with an external antenna socket using ESPEasy firmware. The main concern is the absence of a 10k resistor on GPIO2 and the direct grounding of GPIO15 without a resistor, differing from the NodeMCU V3 schematic. It is clarified that GPIO15 must be held low during reset but can be connected directly to GND if not used as an output; however, if used as an output, a resistor (e.g., 3.3k) is recommended to prevent short circuits. The ESP-12 module has an onboard PCB antenna, unlike the ESP-07 which includes both PCB antenna and antenna connector; firmware versions differ accordingly (4M flash for ESP-12 with antenna socket). Uploading firmware intended for smaller flash sizes (1M) may still work but can cause issues. GPIO assignments for sensors and peripherals are suggested: GPIO4 and GPIO5 for I2C, GPIO2 for DS18B20, GPIO12 for DHT22, and GPIO13-16 for buttons or other inputs. Attempts to upload older firmware versions to the ESP8266 with antenna socket failed, indicating possible hardware or firmware compatibility issues. The use of PCF8574 I2C expanders is considered for additional I/O due to limited GPIO availability.
