Audio Amplifier on Transistors: Stereo Conversion, 2x17V Toroid Transformer & 2M Capacitor Marking
Penio00 8331 16
How do I convert a mono discrete transistor amplifier schematic to stereo correctly, and is the original old design suitable for a simple school project?
For stereo, you must duplicate the entire amplifier path for both channels; only the power supply can be shared, with a common bridge/rectifier, transformer, and filter capacitors [#16821721] The posted 1969 Sinclair 30-style circuit is considered an old quasi-complementary design and was criticized as unstable, with quiescent current depending too much on transistor gain and with a tendency to oscillate [#16821319] Several replies recommend using a proven design such as Eltron 100/Eltron 30 or another Unitra-type amplifier instead, because those are more robust and have output-current protection [#16821681][#16822594] If you want the simplest cheap version, a design built around BDX53/BDX54 Darlington transistors was suggested, and lower supply voltage is acceptable for a lower-power build [#16821681][#16821697]
  • #1 16821119
    Penio00
    Hello, I found a schematic of a mono amplifier on the internet and converted it to stereo. Is everything ok after my connection? Of course, I will make a symmetrical power supply and the transformer I will use is a 2x17v toroid. And what is the marking of the 2M capacitor? Audio Amplifier on Transistors: Stereo Conversion, 2x17V Toroid Transformer & 2M Capacitor Marking
  • #2 16821159
    aaanteka
    Help: 729
    Rate: 1193
    And what was that amplifier and in what class did it work? Seems like the correct diagram. However, I recommend modifying the schematic to that of the proven, good "Eltron 100" on slightly more modern transistors and you will have no problems and a pretty decent amplifier.
  • #3 16821171
    Penio00
    This amplifier, what I found, I only know about it that it is 30w, but I do not know the class or other specifications. Generally, I do not need an outstanding amplifier, but I need it for school as an analog circuit work.
  • #4 16821203
    aaanteka
    Help: 729
    Rate: 1193
    This may be enough, but you should consider how the stabilization of the quiescent current is carried out (the teacher may ask :D ).
    The most simple construction can be obtained on the old TIP142 / TIP147, BDX53 / BDX54, BDW83 / BDW84.
    Link
  • #5 16821237
    Penio00
    The teacher is emm lazy to say. It does nothing in the lesson but requires. As for the projects, we already had one, and he only checked the board performance and operation, so I doubt he will ask for anything. So this scheme can be like this?
  • #6 16821285
  • #7 16821296
    Penio00
    Now I'm a little confused. So I can use this schamt to build an amplifier or not.
  • #8 16821319
  • #9 16821335
    Penio00
    I read what you wrote. But now my question. What amplifier should I make. I do not want it to be expensive to make because I will not use it on a daily basis, I will probably run it once in a while. It doesn't have to be very powerful either. But it must be on discrete elements
    Added after 1 [hours] 54 [minutes]:
    Ok, I found it already, whether it's good or bad, I hope that it will work and writes that Q3 and Q4 and IC are common for both channels and on the schamacie only the left channel is presented so I have to do literally the same as above to put these scams next to each other left signal to one right to the other or some other way to connect it. I would ask for a quick reply
    • Audio Amplifier on Transistors: Stereo Conversion, 2x17V Toroid Transformer & 2M Capacitor Marking received_686210221578198.jpeg (24.24 KB) You must be logged in to download this attachment.
  • Sinclair 30 schematic identified as study design
    #10 16821681
    aaanteka
    Help: 729
    Rate: 1193
    You had said:
    - follow the "Eltron 100" diagram, and use, for example, newer transistors such as 2SC5200 / 2SA1943, or 2SC3858 / 2SA1494 in the complete power stage, or only two 2SC5200 or two 2SC 3858 in a pseudo-circuit [/url] complete, in the control stage 2SC4793-2SA1837,
    OR
    - in the cheapest version, use Darlington transistors like the cheap BDX53 / 54, which will simplify the design to a minimum. Another example diagram:
    ( of course you can use a lower supply voltage and BDX 53/54 - similar to one of the versions of the amplifier in Zodiac - generally Unitra used one, practically more or less developed scheme ;) ).
    The diagram you provided is a Sinclair 30 study from 1969 :D . And here's a little more about its design. and on ours forum .
  • #11 16821685
    Penio00
    But above I wrote that I want something simple because it only gives back and get a grade .. I don't need 100w until. And would what I gave now be ok?
  • Suggesting lower supply and Unitra-style 20 W amplifier
    #12 16821697
    aaanteka
    Help: 729
    Rate: 1193
    I can see that my friend has a vague idea of what he wants to do. It is enough to use a slightly lower power supply and with lower efficiency, possibly correct the gain and have a colleague amplifier 10-20-30W. It is enough to look at Unitra's constructions, such as the amplifier in the mentioned Zodiac, later Tosca, or the Dior WS422 set amplifier.
    The amplifier from the BDX53 / 54 would probably have 20W / 8?. Also my friend does not like its simplicity?
  • #13 16821706
    Penio00
    The main point is that I have a vague idea of what I want to do because the teacher himself does not teach us much. He will come to say what to say and his work is over. He said make an amplifier on discrete elements so much information about it. I found something else 10w amplifier that I posted above and is it ok good and whether in stereo it looks the same as the first one
  • Stereo amplifier needs duplicated power stages
    #14 16821721
    aaanteka
    Help: 729
    Rate: 1193
    Opinions have already been written about the project you have chosen, and here, as well as in the materials that were recommended. If you want to make a stereo amplifier, you must necessarily duplicate the entire amplifier path for both channels, i.e. the voltage and current stage of the power amplifiers are performed twice. At most, the power supply is common, i.e. the bridge transformer and filter capacitors. You had it clearly explained.
    I don't know why you choose strange constructions with such parameters, but also that can cause trouble.
    Make a copy of any of the "Unitra" type amplifiers. Unless you also like a simple 3-5W amplifier, the design of which is simple and cheap (you can even use battery power, i.e. make something like a popular portable speaker).
  • Elektor amplifier needs emitter resistors added
    #15 16821740
    rewida17
    Help: 9
    Rate: 24
    I will propose such a solution:
    1.It works for sure, and it's pretty good. Anyway, for some year it has been using a 4? loudspeaker
    2. I can describe the diagram. It comes from the "Elektor" magazine so there are no problems with the quality of the solution. Very stable. In total, the commissioning consists in checking the voltage on the emitters of the BD679 / 680 transistors
    3. Not many components, not bad parameters, for 80% I have a PCB design for it.
    4. I have made a simulation of the system, if it was needed or for reference.
    5. I recommend a solution
    6. If this arrangement will not fit, I suggest also one Link I also put it together and it sounded pretty good, I only changed the diodes from stabilization to transistor ;)
    Ps. I will not show a better diagram of the studio audio amplifier that we "tested" as a group in the studio because it is going to break down ...
    EDIT:
    In the circuit from "Elektor" emitter resistors should be added (I added 1? ;)
  • #16 16822382
    aaanteka
    Help: 729
    Rate: 1193
    [/url] The previous version of the amplifier from Elektor - even more simplified :) :
    - only four transistors in total.
  • Eltron 100 uses short-circuit current limiting
    #17 16822594
    398216 Usunięty
    Help: 3925
    Rate: 9447
    aaanteka wrote:
    follow the diagram "Eltron 100",
    Exactly; the same series also featured the Eltron 30 - the scheme is practically the same, the difference is two, not four, power transistors and a smaller power supply. At the same time, the amplifier is "idiot-proof" thanks to the use of a circuit that prevents excessive current flowing through the power transistors (eg in the event of an output short-circuit).
    https://obrazki.elektroda.pl/44_1209907625_thumb.jpg
The discussion revolves around the conversion of a mono amplifier schematic to a stereo configuration, utilizing a 2x17V toroidal transformer and addressing the marking of a 2M capacitor. Participants suggest modifications to improve the design, recommending the "Eltron 100" amplifier schematic with modern transistors like 2SC5200/2SA1943 or simpler Darlington pairs such as BDX53/54. Concerns are raised about quiescent current stabilization and the potential instability of the proposed design. Participants emphasize the necessity of duplicating the amplifier path for both channels while sharing various schematic examples and solutions, including a simplified version from "Elektor" magazine. The conversation highlights the importance of using discrete components and offers guidance on achieving a functional and stable amplifier suitable for educational purposes.
TL;DR: For a school-build stereo on discrete transistors, a simple Darlington stage delivers about 20 W/8 Ω; “use BDX53/54” for minimal parts. [Elektroda, aaanteka, post #16821697]
Why it matters:** This FAQ helps beginners convert mono to stereo, choose parts, size the 2×17 V transformer, and avoid stability traps.
How do I turn a mono transistor amp into stereo?
Duplicate the entire amplifier channel (input, VAS/driver, output) for left and right. Keep one common PSU: same transformer, bridge, and filter caps. Wiring: two identical amp boards fed from the shared split supply, each with its own input and output. 3‑step: 1) Clone the mono PCB. 2) Parallel the supply rails to both boards. 3) Route L/R signals to their respective inputs and separate speaker returns. [Elektroda, aaanteka, post #16821721]
Will a 2×17 V toroidal transformer work for a 10–30 W stereo build?
Yes for modest-power class‑AB builds. Using lower rail voltage limits power, which suits school projects. Aim for 10–30 W per channel and ensure adequate filter capacitance. Keep speaker loads reasonable (8 Ω preferred) to reduce heat. “It is enough to use a slightly lower power supply … and have … 10–20–30 W.” [Elektroda, aaanteka, post #16821697]
What does the “2M capacitor” marking mean here?
The thread does not resolve this marking. Check the original schematic legend or bill of materials. If uncertain, trace where it sits: input coupling (µF), timing (nF–µF), or compensation (pF–nF). When in doubt, ask for the full schematic note set or part list. [Elektroda, Penio00, post #16821119]
Why is quiescent current stabilization critical?
In the proposed schematic, bias depends on power transistor gain, causing thermal drift and possible oscillation. Add proper biasing and small emitter resistors to stabilize idle current. Edge case: without emitter resistors the stage can run away under temperature or mismatched hFE. “The amplifier will be unstable.” [Elektroda, Anonymous, post #16821319]
What is a quasi‑complementary output stage?
It uses NPN devices (and drivers) to mimic a complementary pair when good PNP power parts are scarce. It’s an older concept and can complicate biasing and distortion performance compared to true complementary outputs. Consider modern complementary pairs instead. [Elektroda, Anonymous, post #16821319]
Should I add emitter resistors in the output stage?
Yes. Low‑value emitter resistors (e.g., 0.22–0.47 Ω) help current sharing, bias stability, and tame oscillation. The criticized design lacked these resistors, which is a significant drawback. Add them near the output transistor emitters and size for dissipation. [Elektroda, Anonymous, post #16821319]
Do I need a bootstrap network in this design?
A bootstrap on the voltage‑amplifier stage can increase headroom and improve linearity in simple topologies. The reviewer explicitly recommended adding one to the discussed schematic. Place the bootstrap capacitor from output to the VAS load node per the diagram. [Elektroda, Anonymous, post #16821285]
What transistor sets are simplest for beginners?
Use Darlington power pairs like BDX53/BDX54 for minimal parts, or TIP142/TIP147. These simplify biasing and reduce component count. “The most simple construction can be obtained on … TIP142/TIP147, BDX53/BDX54.” [Elektroda, aaanteka, post #16821203]
Is the Elektor transistor amp a safe school project choice?
Yes. It’s documented, stable, and easy to set up by checking emitter voltages on BD679/BD680. One builder reports good results even on a 4 Ω speaker, plus PCB and simulation support. Add small emitter resistors for robustness. [Elektroda, rewida17, post #16821740]
Is Eltron 100/30 a good template for learning?
Yes. Eltron 30/100 share a proven topology with protection that limits excessive output current, making them durable for students. Eltron 30 uses fewer output devices and a smaller PSU, yet retains the core schematic. [Elektroda, 398216 Usunięty, post #16822594]
How much power can I expect from BDX53/BDX54 on 8 Ω?
Approx. 20 W into 8 Ω with suitable rails and heatsinking. This matches classroom‑friendly power without stressing the supply. Quote: “The amplifier from the BDX53/54 would … have 20 W/8 Ω.” [Elektroda, aaanteka, post #16821697]
Can both channels share one power supply?
Yes. Build two identical amplifier channels and feed both from one transformer, rectifier bridge, and filter capacitors. Keep star‑grounding to minimize hum. Quote: “A stereo amplifier is two mono amplifiers … They can use the same power source.” [Elektroda, Anonymous, post #16821285]
Is the Sinclair 30 (1969) worth building today?
It’s a historical study and not recommended for beginners due to biasing and stability concerns compared with modern designs. Prefer Eltron or Elektor‑style circuits and newer complementary outputs. [Elektroda, aaanteka, post #16821681]
