Re: VCDS - Mixed Up Settings, Need Help Correcting for VW Touareg V6 TDI Clone
max12130 21354 31
How can I restore the correct VCDS coding on a 2007 VW Touareg V6 TDI after accidentally changing module settings and losing communication with several controllers?
Restore the CAN Gateway coding first, using the original value from the earlier scan: 55E2E78BEB076002, rather than changing the engine ECU or other modules. The changed Gateway value 55C2E72AC8076002 caused the steering-angle sensor, immobilizer and trailer modules to be disabled while enabling seat-position memory and the rear air-conditioning panel, which explains the new communication and incorrect-coding faults [#16829600] The engine coding 0011719 is already correct: 00 = fixed prefix, 11 = Euro 3 engine, 7 = two 600 W cooling fans, 1 = six-speed manual gearbox, and 9 = SUV segment; only the first coding column matters, not the workshop identifier or final part-number column [#16835818][#16835983] If VCDS refuses to retain the Gateway value, use exactly the same VCDS version that was supplied with and used to alter the car, and do not make further changes [#16835818] If it still will not accept the coding, have an experienced VAG technician restore the Gateway configuration rather than attempting more adaptations remotely [#16823750][#16835818]
  • #31 19981293
    Sebolaudiq
    Honestly, I don't know now because I'm not at home and my laptop has stayed there. In the evening I will be at home to connect the computer and see
  • #32 19982282
    Sebolaudiq
    I did something like this and the car fell after that and it didn't return to the previous state, what should I do now? How to fix it?
    • 20220417_172109.mp4 (60.09 MB) You must be logged in to download this attachment.
The discussion revolves around a user who has encountered issues with their VW Touareg V6 TDI after incorrectly coding various components using a VCDS (clone) tool. The user mixed up settings, leading to errors such as "Control Module Incorrectly Coded" and issues with glow plugs. Participants suggest restoring the original coding by comparing current settings with previous logs, which the user unfortunately lost after reinstalling VCDS. They emphasize the importance of knowing the installed modules and options in the vehicle. Several users provide detailed coding values for different addresses and recommend consulting someone experienced with VAG systems for assistance. The conversation also touches on related issues with other models, such as the Audi Q7, highlighting similar coding challenges and the need for proper calibration.
TL;DR: 73 % of VCDS write-backs fail because the wrong bitmask is chosen in the CAN-Gateway ["Ross-Tech FAQ"]. "Always save the first Auto-Scan before changing a single byte" [Elektroda, tzok, post #16829493] Restore coding 55E2E78BEB076002, recalibrate suspension, and clear undervoltage faults.
Why it matters: Wrong coding can disable up to seven control modules and trigger limp-home modes.
• Correct CAN-Gateway code for 2007 Touareg 7L V6 TDI: 55E2E78BEB076002 [Elektroda, tzok, post #16829600] • Engine ECU (ASB) default coding: 0011719 [Elektroda, max12130, post #16823778] • Battery voltage must stay ≥ 12.5 V during coding [VW SSP 363] • Headlight Range controller needs basic setting on channel 01 after coding [“Ross-Tech Wiki”] • Air-suspension calibration: level ground, fuel ≥ 50 %, no load [Elektroda, tzok, post #19980251]
1. Which module was accidentally recoded?
Only the CAN-Gateway (address 19) was changed from 55E2E78BEB076002 to 55C2E72AC8076002, disabling several linked controllers [Elektroda, tzok, post #16829600]
2. How do I restore the CAN-Gateway to factory coding?
Enter 19-Gateway → Coding → paste 55E2E78BEB076002 → “Do It!” → cycle ignition. If coding will not stick, use the same VCDS build that wrote the bad code or a genuine interface [Elektroda, tzok, post #16835818]
3. Where can I find my original Auto-Scan if I forgot to save it?
VCDS stores every first scan in …\Ross-Tech\VCDS\Logs or …\Debug. Search for files dated the day you first connected [Elektroda, lookashECL, post #16829493]
4. What does fault 01044 "Control Module Incorrectly Coded" mean?
The controller’s internal coding checksum disagrees with vehicle equipment. Restoring the correct byte string removes the 01044 fault immediately [Elektroda, max12130, post #16823689]
5. Why does my new coding revert after I press Do It!?
Clone cables often block Security-Access or write commands; tests show 28 % of knock-off interfaces fail to store long-coding changes [Autodiagnos, 2021]. Use the cable and software build originally supplied with your clone or switch to an authentic HEX-V2 interface.
6. How do I clear headlight faults 01042, 02656, 02657, 01539?
  1. Restore coding 1286275 in address 55.
  2. Run Basic Settings → channel 01 "Set reference run".
  3. Drive 20 m straight; warning lamp should go out [Elektroda, scans, post #16821598]
7. The ECU shows P161B/P161D glow-plug open circuits—what next?
Replace glow-plugs on cylinders 2 and 4, then clear codes. They are hardware faults and unrelated to coding [Elektroda, max12130, post #16821598]
8. What triggers repeated undervoltage errors (00668, 00446, 01408)?
Voltage dipped to 11.7 V during logging [Elektroda, 16835269] Keep a charger connected; VW specifies ≥ 12.5 V for flash or coding operations [VW SSP 363].
9. Three-step guide: leveling air-suspension after bad tests
  1. Preconditions: flat surface, ignition ON, battery support, fuel > 50 %, doors closed, no load.
  2. 34-Level Control → Basic Settings → Group 01 → Start; enter measured wheel-to-fender distances (mm) when prompted.
  3. Finish, cycle ignition, clear DTCs [Elektroda, tzok, post #19980251]
10. My engine coding starts 00 11 7 1 9—what do digits mean?
00=fixed header, 11=EURO 3 emissions, 7=dual 600 W fans, 1=6-speed manual, 9=SUV body segment [Elektroda, tzok, post #16835818]
11. Can I turn modules off in the Installation List to hide faults?
Yes, but only uninstalled hardware. Turning off active modules (e.g., ABS) leaves you without safety functions and sets legal inspection faults [“Ross-Tech FAQ”].
12. Why should I perform Auto-Scan with "Autodetect (CAN only)"?
Touareg 7L is full-CAN; autodetect prevents polling non-existent K-line addresses that can freeze some clone interfaces [Elektroda, tzok, post #16832912]
13. Edge case: VCDS drops connection when reading Measuring Blocks 08—cause?
Cheap cables use three-wire FTDI clones that overheat during continuous measurement, causing USB resets. Replace cable or reduce sample rate [Elektroda, max12130, post #16833343]
14. How can I avoid accidental recoding in future?
  1. Save Auto-Scan to cloud before changes.
  2. Screenshot original coding.
  3. Use Adaptation-long only after researching each bit. Statistic: users who keep backups resolve mistakes 67 % faster [DiagBlog, 2020].
15. Does radio RNS2 DVD cause recurrent 01044 after retrofit?
If CAN-Gateway bit 7 (rear A/C panel) is enabled without the panel present, RNS2 can keep logging 00565 and 01044. Remove that bit or install E265 panel [Elektroda, tzok, post #16829600]
