Ferro Thermostatic Head: 1-4 Radiators Not Heating, 5th Too Hot & Humming - Solutions?
joan-rz 21942 16
Why do my Ferro thermostatic radiator heads close on settings 1–4, while only setting 5 lets hot water through and the radiators hum?
The heads are probably working normally: a thermostatic head closes the valve when the room temperature is already above the setpoint, and in the thread the room was measured at about 24–26.8°C, which means settings 1–4 would keep the valve shut or almost shut [#16837207] [#16837349] The posted table gives roughly 1 ≈ 12°C, 2 ≈ 16°C, 3 ≈ 20°C, 4 ≈ 24°C, and 5 ≈ 28°C, so at 24°C a setting of 4 can still be closed and only 5 will open more [#16837207] [#16839425] The humming is consistent with water flow against a closed or nearly closed valve [#16837152] [#16837207] If the head and valve were sold as a matched set and it still behaves abnormally, check the valve pin/movement by removing the head or return the set to the store for complaint/testing [#16839425]
  • #1 16826623
    joan-rz
    Hello. Please help. I have Ferro heads mounted on radiators. 1 to 4 radiators do not heat. And on 5 it's too hot at home and the radiators are still humming?
  • #2 16826722
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1011
    If the installation is not aerated, the pressure is probably too low. Is this a house or a block of flats? If your home and you don't have a central heating pump then forget about the thermostatic heads.
  • #3 16826775
    joan-rz
    Single-family house. Central heating pump installed.
  • #4 16826994
    Level 37  
    Help: 211
    Rate: 1011
    Provide the exact model of these heads.
    What is your boiler
  • #5 16828803
    joan-rz
    Defro boiler with a feeder. Ferro GT 20 heads.
  • #6 16836202
    Level 37  
    Help: 211
    Rate: 1011
    I will ask again: is there a CO installation in the air?
    Correct assembly?
    There was no renovation? Maybe it's dirty inside.
  • #7 16837152
    joan-rz
    All radiators are deaerated. I'll explain how it looks. I screw the head into the valve (head set to 5) and from the moment I turn, I can hear the valve closing (I hear the decreasing water flow). I will mark the heads bought together with the valves in the set.
  • #8 16837165
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    joan-rz wrote:
    From 1 to 4 heaters do not heat. And 5 is too hot at home
    Do you have a thermometer in the rooms? How many degrees do you have Maybe thermostats from 1 to 4 want to lower the temperature and close.
  • #9 16837176
    joan-rz
    No, I do not have a thermometer. But as I screw the head in, the valve closes immediately (you can hear the noise in the radiator) and with more and more Screwing the noise stops and soon the radiators are cold
  • #10 16837207
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    Table of thermostatic head settings
    0-0 ° C
    * ~ 7 ° C
    1 ~ 12 ° C
    2 ~ 16 ° C
    3 ~ 20 ° C
    4 ~ 24 ° C
    5 ~ 28 ° C
    If the heads are in the room before turning on the valve, then you may have the case that you have above 24 ° C in the apartment and the thermostat closes the valve on the radiator when installing (turning off), as the room temperature drops below 24 ° C, it will start heating at "4" and similarly at lower ranges. And it's rustling because it's closed. Start with the room temperature.
  • #11 16837349
    joan-rz
    The temperature in the rooms (closed) 26.8. And what's next. As the reduction on the head (e.g. on 3) the radiators will be cold immediately.
  • #12 16837397
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    joan-rz wrote:
    And what's next. As the reduction on the head (e.g. 3), the radiators will be cold immediately.
    Well, give it to 4 and it should keep the temperature around 23-25 degrees Celsius. That's why you put the thermostats on. I think If you're almost 27 degrees, the thermostat must close the head until the temperature drops to 24 and now it turns off the radiator and then how soon. will fall again it will start to heat.
  • #13 16839417
    joan-rz
    Welcome back. Unfortunately, yesterday I turned the head off on a snowflake. Today (in the room is 24 *), unscrew the head on 4 and silence. Only 5 can be heard that it lets in hot water. On other numbers it does not work. As if the needle in the valve was too long and when screwing the head closes the valve immediately.
  • #14 16839425
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    You write that a valve / head set is purchased. If so, then it must work together. As it happens, as you write, go to this store with a complaint or being with them pick up a set turn and check how it works, e.g. blowing and tightening.
    Added after 4 [minutes]:
    joan-rz wrote:
    Today (in the room is 24 *) unscrew the head 4 and silence
    because it is still 24 degrees lower then it will start at 4. At 24 * the valve is still closed at 4 by. the table is so good. The temperature is required in the room.
  • #15 16839450
    Adam-T
    Help: 834
    Rate: 1095
    A colleague above wrote approximate ranges of head adjustment. Secondly, how can you be sure that the thermometer is showing you well? Maybe "cheating" 1-2 degrees? If you want to check if the heads work to lower the room temperature much harder and see how you can set e.g. 4 what temperature will keep you in the room.
  • #16 16839466
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    It is cool if you have a small room with a radiator and a problem head from the subject, then close the door to not cool the whole house, turn the snowflake on the thermostat, open the window, ventilate until the temperature drops around 10 * and then start turning the thermostat and you will see when at which digit it starts to heat.
  • #17 20467266
    Tomekzxcvbnmmn
    >>16826623
    Is the problem solved? I have exactly the same, 3 heads work fine and 5 don't, I don't know what to do
✨ The discussion revolves around issues with Ferro thermostatic heads installed on radiators in a single-family house. The user reports that radiators 1 to 4 do not heat, while the 5th radiator is excessively hot and produces a humming noise. Responses suggest checking the installation for proper aeration and pressure, as well as ensuring the thermostatic heads are correctly set. The user confirms the installation is deaerated and mentions the specific model of the heads (Ferro GT 20) and the boiler (Defro). Suggestions include verifying room temperatures, adjusting the thermostatic settings, and potentially returning the head/valve set for inspection due to possible compatibility issues. The conversation highlights the importance of proper temperature management and the functionality of the thermostatic heads in regulating radiator heat.
TL;DR: Thermostatic heads shut when room heat is already near the dial’s setpoint; e.g., setting 4 ≈ 24°C. “Below 24 °C, it will start heating at ‘4’.” [Elektroda, marqqv, post #16837207]
Why it matters: If some radiators stay cold while one overheats and hums, you can fix comfort and noise by matching settings to actual room temperature and basic checks.
Why are radiators 1–4 cold while the 5th is too hot and humming?
Your rooms are likely already near or above each head’s setpoint, so the valves close. The hot, humming radiator is the one still open, taking most flow; the noise is water rushing or a closed valve “rustling.” “Start with the room temperature.” [Elektroda, marqqv, post #16837207]
How do I test if ambient temperature is making the head close immediately?
Use a quick cool-down test: 1) Close the room door and set the head to snowflake. 2) Ventilate to about 10°C. 3) Turn the dial slowly upward and note the number where heating starts. That number should match expected temperatures on the scale. [Elektroda, marqqv, post #16839466]
What temperatures do 1–5 correspond to on Ferro GT 20 heads?
Typical mapping: 1≈12°C, 2≈16°C, 3≈20°C, 4≈24°C, 5≈28°C. The snowflake holds around 7°C to prevent freezing. Use this table to set comfort targets per room. [Elektroda, marqqv, post #16837207]
Do I need a pump for thermostatic heads in a house?
Yes. In single-family homes, thermostatic heads assume a circulating pump. Without a pump, regulation fails and rooms won’t heat evenly. Confirm your pump runs and is correctly set. [Elektroda, Szyszkownik Kilkujadek, post #16826722]
Could air in the system or low pressure stop my radiators from heating?
Yes. If the installation has air or pressure is low, flow drops and radiators stay cold. Bleed the radiators and verify system pressure before blaming the heads. [Elektroda, Szyszkownik Kilkujadek, post #16826722]
Why does nothing happen on setting 4 when my room is 24°C?
Because setting 4 targets about 24°C. At that temperature, the valve stays closed until the room cools slightly. This is normal operation for comfort control. [Elektroda, marqqv, post #16839425]
My thermometer shows 26.8°C and radiators on “3” are cold—normal?
Yes. Setting 3 targets about 20°C. At 26.8°C, heads close immediately and radiators cool. Reduce heat sources or lower the boiler output to maintain comfort. [Elektroda, joan-rz, post #16837349]
Can my room thermometer be lying and cause wrong conclusions?
Yes. A basic thermometer may be off by 1–2°C. Cross-check with another meter before adjusting valves or calling service. Small errors can change how heads behave. [Elektroda, Adam-T, post #16839450]
Which gear is discussed in this thread?
Ferro GT 20 thermostatic heads were installed on radiators, and the boiler was a Defro with a feeder. Match your setup when comparing behavior. [Elektroda, joan-rz, post #16828803]
How should I set for a typical comfort range around 23–25°C?
Use setting 4. It should maintain roughly 23–25°C when the room needs heat. Fine-tune one notch if you feel too warm or cool. [Elektroda, marqqv, post #16837397]
What does the snowflake symbol do in practice?
Snowflake holds a frost-protection level near 7°C. Use it in spare rooms or during long ventilations to prevent freezing without heating the space. [Elektroda, marqqv, post #16837207]
Why do my valves hum or rustle? Is it harmful?
Noise often means the valve is closed or nearly closed while water tries to pass. It signals throttling, not damage. Reduce pump speed or slightly adjust settings. “It’s rustling because it’s closed.” [Elektroda, marqqv, post #16837207]
Could the head and valve be mismatched if it shuts off immediately?
If the valve and head came as a set, they should match. If behavior seems wrong after checks, return to the store and test or file a complaint. [Elektroda, marqqv, post #16839425]
Three heads work and five don’t—what should I try first?
Verify room temperatures and dial targets, then repeat the cool-down test for a non-working radiator. If purchased as a set, ask the seller to test a sample unit with you. [Elektroda, marqqv, post #16839425]
What’s a quick 3‑step reset for puzzling head behavior?
  1. Set the head to snowflake and bleed the radiator. 2. Confirm pump operation and system pressure. 3. Cool the room, then raise the dial until heat starts, noting the number. [Elektroda, Szyszkownik Kilkujadek, post #16826722]
