Panda 1,1 * V 2008 - Tightening torque of the rocker arm screws
magnus27 23052 6
  • #1 16829274
    magnus27
    Rate: 310
    In my panda I have to swing the rocker, I would like to do it God's way and tighten with a torque wrench. In the internet I have a problem with finding the aforementioned moments; (
  • #2 16829516
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    See what screws are there and tighten according to the table
  • #3 16829607
    oktawian89
    Help: 52
    Rate: 444
    FRONT SUSPENSION LOWER LEVER
    M12 x 1.25 85 nm
    FRONT SUSPENSION LOWER LEVER BALL JOINT
    M8 32 nm
  • #4 16834330
    magnus27
    Rate: 310
    I have to understand that the front mounting arm 110 nm and the rear only 32 nm_ is not enough if both screws have the same size?
  • #5 16834334
    oktawian89
    Help: 52
    Rate: 444
    Mounting of the rocker arm and sled 85 nm bolt to 32 nm crossover
  • #6 16834364
    magnus27
    Rate: 310
    Thanks a can you know where you found these moments? In Józef Zembowicz's book (I fix it myself), you do not have an auto date. And one more thing which companies are the best rocker arms for the panda? In one wholesaler, I can buy the original trw for PLN 236. Is this a good price?
  • #7 16834369
    oktawian89
    Help: 52
    Rate: 444
    On the English-language fiata forum. Trw are ok
The discussion revolves around the tightening torque specifications for the rocker arm screws of a 2008 Panda. Users seek accurate torque values for various components, including the front suspension lower lever (M12 x 1.25 at 85 Nm) and the front suspension lower lever ball joint (M8 at 32 Nm). Clarifications are made regarding the torque differences for screws of the same size. Additionally, the author inquires about reliable sources for these specifications and the best brands for rocker arms, specifically mentioning TRW as a viable option at a price of PLN 236.
