Lenovo Laptop, No Sound Issue: 5-Year-Old Device, Speaker Test Fail, Device Manager OK
malfra41 5691 3
  • Suspected internal audio fault in 5-year-old laptop
    #1 16854215
    malfra41
    Hello, I have no sound in my laptop since yesterday. I checked everything according to the guidelines from the forum. Everything is as it should be. I suspect it's something inside. Can anyone in what it can be and what are the repair costs? The laptop is not new, it has been around for 5 years. Could this be related to the failure? There is no sound when testing the speakers. Everything is fine in the device manager, the icons are also as it should be.
  • #2 16854255
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Run some Linux livecd / usb and check if you can hear sound.
  • #3 16854312
    malfra41
    I checked and nothing. There is also silence on the explorer. I also did a restart and it did not help
  • Possible audio chip or PCB fault; try USB sound card
    #4 16854424
    safbot1st
    Help: 2719
    Rate: 1585
    On linux, silence = damaged audio chip. Check if it can be turned off and on in the BIOS and if it is on, but this option rarely exists in laptops.
    Added after 20 [minutes]:
    Was there a failure? The repair will depend on what exactly the broken will cost.
    There may be, for example, a short circuit in the jack socket / clamped speaker cables or a failure of the circuit on the PCB.
    The solution, or more of a workaround, will also be to buy a small USB sound card.
