Huawei B525 Router: Quick Configuration Pop-up Issue & Player.pl VOD Ad Blocks Problem
marijuz 5796 6
  • #1 16862684
    marijuz
    Rate: 13
    I have been using the Huawei B525 router recently and I have a problem with it. Sometimes turning on any website, the browser instead displays the login window for the router and its quick configuration. It is not very bothersome because it appears rarely and it is enough to refresh the page to enter where you originally wanted, but I have the impression that this phenomenon is the reason for player.pl player VOD bugs. Namely, such a player can hang when switching to ads or from ads to a movie. And this is already troublesome, because advertising blocks have to be viewed from the beginning, you know. Sometimes even twice. I suspect that the player instead of receiving data about the movie or advertising gets the router configuration page and is stupid. So do you have any idea what is the reason and how to prevent it?
    Best regards.
  • #2 16862725
    DejoDejo
    Help: 35
    Rate: 75
    Maybe run on a different browser and see if the problem will be similar ;)
  • #4 16862806
    DejoDejo
    Help: 35
    Rate: 75
    Check and provide results, it can be different - including browser infection ;)
  • #5 16862851
    marijuz
    Rate: 13
    I doubt that it was a browser infection because I have had a router and internet from T-Mobile for two days and at the same time there was a problem - before everything was ok.
  • #6 16862863
    DejoDejo
    Help: 35
    Rate: 75
    You can doubt it, but check it out ;) It's just a guess, everything will come out in the wash ;)
  • #7 16872862
    marijuz
    Rate: 13
    Changing the browser did not help. Recently, player.pl does not work well at all - pages, movies and ads do not load. And in all this speedtest.pl tells me that everything is ok, that I have a 20 Mb / s connection
The discussion revolves around issues experienced with the Huawei B525 router, specifically a problem where the router's quick configuration page intermittently appears instead of the intended website. This issue is suspected to interfere with the functionality of the player.pl VOD service, causing playback problems during ad transitions. Users suggest troubleshooting steps such as trying different browsers and checking for potential browser infections, although the original poster notes that the problem persists even after switching browsers and that their internet connection speed appears normal.
