  • Automated LED backlight for the wall behind the TV turns on at dusk and lights the area behind the screen.
  • A twilight-switch-style controller uses a photoresistor under the screen, a potentiometer, and a separate driver in one enclosure with mains, LED, sensor, and adjustment connectors.
  • The system uses a repaired 24V / 2A power supply, and it keeps the backlight on for about 30 seconds after TV shutdown.
  • The first LED strips were too bright, so resistors were added to balance the backlight against the TV image.
📱 Listen (AI):
  • Hello colleagues.
    Using the TV in a dark room sometimes causes eye fatigue due to the brightness of the screen. This is no discovery - you can turn on the lamp and you're done.
    You can also turn on the LED strip on the back of the TV and turn it off when you are finished watching. However, it is always an additional activity.
    The project below concerns the automation of the above process.
    The basic assumptions are:
    1. Automatic switching on of the backlight when dusk falls.
    2. Gentle and smooth brightening of the LEDs so that the viewers do not notice the moment of switching on.
    3. A gentle fading after switching on the light in the room.
    4. Maintaining the light for about 30 seconds. after turning off the TV - time to put the remote control down and get to bed (this is my case).
    5. Non-invasive assembly that does not require interference with the TV circuits (warranty maintenance requirement).
    I do not boast of photos here, because what is there to photograph. The device was built quite a long time ago and I did not think about DIY then.
    I was once gifted with a damaged 24V / 2A power supply, which I managed to fix quite simply. Shapely and transparent design, importantly, the manufacturer regretted the silicone gel, making it easier for me to make changes.
    Finally, the power supply and the driver fit into the housing, where I placed the necessary connectors on one side of it:
    - mains power socket
    - LED connection socket
    - photoresistor socket
    - potentiometer
    From the opposite wall comes a cable terminated with a power plug, which powers the TV.
    For lighting, I used the remains of LED strips that remained after some robots, just - they were different. The 24V part, the 12V part, cold and warm. Just right for such a purpose. In addition, an aluminum section in the form of an angle bar and a light strip is ready.
    I attached the strip to the sheet metal TV casing using the existing screws that fix the sheet metal rear wall.
    The photoresistor is placed under the screen so that it is not affected by its light.
    This is actually so much about the description of the mechanical structure.
    As for the electrical system, its expansion was a consequence of the implementation of the above-mentioned assumptions. It is, after all, nothing more than an extension of the well-known twilight switch.
    In the end, the LED strips turned out to be too bright, so after finishing the works, I added resistors to balance the brightness of the background and the TV screen.
    Lighting the wall behind the TV
    The LEDs visible in the diagram are small "fleas" mounted only to illustrate the logical states in the system. It allowed me to start the system faster and observe the operation on the table.
    W.P.
    Computer PSUs specialist
    W.P. wrote 5290 posts with rating 1223, helped 771 times. Live in city ƁódĆș. Been with us since 2003 year.
  • #2 19302596
    krzbor
    Help: 41
    Rate: 1063
    I was interested in the activation detection system. The calculations showed that a 70W load (actually a bit more) is needed for the transistor to work. Current televisions (especially those of smaller sizes) consume much less current - in this case, you need to increase the value of the 2R resistor. It is worth paying attention to the transistor that the author used for detection - it must be a transistor with a high maximum collector-emitter voltage - BF459 has 300V. However, the peak voltage is 325V.
  • #3 19303333
    W.P.
    Help: 771
    Rate: 1223
    Thank you for your insight.
    As for the 2? resistor, it is more than enough. It is true that there is a 55-inch TV set here, so the power is sufficient, but it is worth noting that even though the power supply is equipped with APFC, the current is not fully sinusoidal.
    The above value was more experimentally determined than it resulted from any calculations. In addition, the layout was created in the workshop and the TV was at home. This effectively blocked me from seeing the shape of the current.
    In the end, I made a compromise to reduce power losses on the one hand, but to ensure correct operation with the lowest backlight on the other.
    Transistor ... It's hard to explain here. I knew about 300V from the beginning.
    I assumed, however, that since it is the guaranteed value, it will hold these few% for sure. besides, I had nothing else at hand. The entire system was created from the so-called drawer "przydasiĂłw".
    Now I can see that it was possible to use eg BC848 after installing a Zener diode, eg 18V between the emitter and the connection of the "flea" diode anode with the M24 resistor.
  • #4 19303566
    krzbor
    Help: 41
    Rate: 1063
    The resistor circuit is cleverly protected by two diodes. The voltage across the resistor will never exceed 1.4V. So increasing the resistance reduces the power dissipated on it. In principle, the system must correctly recognize the power supply during sleep and when the TV is turned on. It would be best if it was about 20W. I wonder if it is possible to simplify it more - put the diodes of the optoisolators in parallel to the resistor (in parallel, each through a small resistor). Obviously you need to increase the number of rectifier diodes (you need 3 or 4 in series) to get the correct voltage for the LED optoisolators, but it should work. The advantage is that the need for a high-voltage transistor and the power loss on it are eliminated.
  • #5 19303656
    W.P.
    Help: 771
    Rate: 1223
    I admit that I treated the detection system quite superficially, as the simplest part of the system. I stayed with the first solution that came to mind.
    You can actually do it in several ways, including bypassing the transistor. The optocoupler diode conducts from 1.1V, so even these 2 diodes (and a slightly larger resistor) could be enough.
    It would be best, of course, to have a TV nearby to be able to run the system safely. I was doing it "remotely" so I had to assume a worst-case scenario.
  • #6 19303875
    PPK
    Level 30  
    Help: 94
    Rate: 423
    I suggest using the USB output. Voltage detection. For me, after turning on the TV, there is a voltage of 5V (Panasonic).
  • #7 19303985
    W.P.
    Help: 771
    Rate: 1223
    For me (Panasonic TX-55EX620E) it also appears and I even initially considered using this signal.
    I successfully healed this idea when I woke up at night and noticed that despite the TV turned off, the external disk light was on (!) And it was 3 or 4 hours after turning off the TV. It turns off after a while.
    Interestingly, a few moments after turning off the TV, the disk also turned off, but I do not know what mechanism it turns on after a few hours with the receiver turned off.
    I have neither recording nor timeshift configured.
    Besides, it was easier to use the current signal. One cable less.
    Added after 30 [minutes]:
    If any of your colleagues uses a similar receiver, please make a test and connect anything (e.g. a LED lamp with low power consumption) to observe the behavior of the USB port after turning off the TV and share the observation results.
  • #8 19304307
    ditomek
    Help: 24
    Rate: 230
    The two-year-old smart from Samsung and the connected drive actually behaved as if he wanted to work despite the TV turned off. But the connected LED light wouldn't shine when the TV was off.
  • #9 19304830
    Ibuprom
    Help: 52
    Rate: 180
    Respect for such an extensive analog circuit, although it is known - it could be done more easily on an AtTina. But I'm not talking about it - load detection - what for? There is voltage in the usb sockets after switching on, the LED lights up in the spdif socket, you can do this detection much easier without "false alarms". In my Samsung, I connect the LED strip directly to the USB. The resistor and capacitor deal with the topic of soft starting and extinguishing, I do not have to wait for getting to bed, but my house's night lighting works all night. All you need is a few LEDs with a power consumption of several dozen milliwatts every meter or a ready-made 12V led strip connected by a 1k resistor or more in various locations in the house.
  • #10 19305389
    W.P.
    Help: 771
    Rate: 1223
    I wrote about the madness in USB in # 7. I plan to use the optical link socket (he, he, he - for 2 years) for an audio amplifier. Unfortunately, there is a constant lack of time.
    The entire system was built in a matter of hours, not including the mechanical part. All elements are general cargo filling the boxes in the rack, including the remnants of LED strips (part for 24V, part for 12V). The power supply fell into my hands.
    So it was enough to pick up a soldering iron, turn on the oscilloscope, look out the window and feel sorry for those who are getting wet and cold somewhere, experiencing the autumn fluff.
    The system was a bit big, because I assumed strict conditions.
  • #11 19305439
    Ibuprom
    Help: 52
    Rate: 180
    Well, in my case, in Samsung, I attach an additional audio amplifier and backlight to USB. USB turns off after turning it off with the remote control. Perhaps not all USB ports in this Panasonic TV worked like this, or after detecting the disk, the method of port power control changed. Again, in the monitor with USB ports, I used 12V strips and a step-up converter, you can adjust the power and it is cheaper to implement than the 5V strips.
  • #12 19308653
    GGK
    Rate: 18
    Would a fuse in the circuit not improve safety? With a short circuit in the TV or worse, an overload on the diode and resistor, a lot of power will be emitted.
  • #13 19310449
    montertb
    Help: 19
    Rate: 149
    Lighting for the TV is a nice idea, but only if you have an even wall (if the TV is hung on a wall bracket). I gave up at home, after the first start-up, although the coats were made solidly, with such contrasting lighting, all defects and unevenness can be seen at night. It stung my eyes terribly, I gave it up.
    Just such a non-technical note ... :D
  • #14 19310554
    Ibuprom
    Help: 52
    Rate: 180
    If you move the leds away from the wall, you won't see any unevenness. These are only visible when the strip is practically against the wall and shines sideways.
  • #15 19311144
    W.P.
    Help: 771
    Rate: 1223
    It would definitely raise, but I consciously skipped this element knowing that it is already in the TV's power supply.
    Even if there was a short circuit in the TV power supply circuits before the fuse, nothing would happen - 3 diodes would be damaged. Initially, "short-circuit" and before they fail, a quick fuse near the meter will trip.
    montertb wrote:
    Backlighting behind the TV is a nice idea, but only when you have a mega-even wall (...) at night you can see all the defects and unevenness. It stung my eyes terribly, I gave it up.
    For me, the problem of unevenness does not occur due to the distance from the wall. The light blurs nicely creating a delicate glow.
    It was too bright at first.
    I could convert the power supply from 24V to a lower one or make a potentiometer with DC component regulation added to the triangle generator, limiting the maximum PWM filling, but everything was already assembled and hung on the back panel, so I added some resistors.
    The LED strips are glued to the aluminum angle. Its base restricts the light from reaching the base of the TV, making the wires less conspicuous.
  • #16 19318752
    montertb
    Help: 19
    Rate: 149
    Yes, the fact that the lighting moves away, the problem decreases.
  • #17 19536633
    damian1115
    Level 37  
    Help: 393
    Rate: 900
    I also noticed this phenomenon in my TV Samsung, and in addition in two 32 and 48 inch TVs. In both, I made a backlight, using the voltage from USB as control. It does not happen often, but at least once a month, when the TV is turned off, the backlight turns on by itself.
    If anyone knows what is going on here, I would ask for an explanation.
  • #18 19536924
    PPK
    Level 30  
    Help: 94
    Rate: 423
    He took me in ... in and I started to have ugly suspicions. In fact, quite rarely, but the TV is turned off with the remote control, from time to time it "activates" itself at night - the USB lamp. When turned off with the SWITCH, there is no such thing. Unfortunately, the switch is on the back (Panasonic). I bought what is in the picture and "after the bird". The only problem is to align the phase (L) in the power socket / extension cord with the relay in the device (there is one pole). If it turns off N, then some miracles happen with the ethernet cable plugged in. By the way, soon a new refrigerator will probably start blocking the door at night, as part of "environmental protection" ... Lighting the wall behind the TV
  • #19 19537178
    damian1115
    Level 37  
    Help: 393
    Rate: 900
    In a way, this is a solution, but not entirely satisfactory. Some time ago, there was a discussion here on the forum whether to disconnect the equipment from the network after stopping its use. Opinions were divided, but I opt for keeping him under tension all the time. It very often happens that after turning off there are problems with its restart, because probably the inverter does not like it and may refuse to obey.
  • #20 19537221
    Janusz_kk
    Help: 219
    Rate: 1446
    And on the contrary, the switched on equipment is exposed to overvoltage from the mains, consumes unnecessary energy and wears out, e.g. capacitors in converters, which then work very cyclically. I know because I fix it.
    But this only means that it is already partially damaged and repairable.
  • #21 19537407
    damian1115
    Level 37  
    Help: 393
    Rate: 900
    As I mentioned before:
    However, this does not change the fact that if it had not been disconnected from the network, it would have continued to work.
  • #22 19611541
    Postman
    I have a request how to modify this layout:
    https://sklep.avt.pl/avt1965.html
    If I turn on the TV, the LEDs turn on. Control from the USB TV socket. But after turning off the TV, the LEDs do not go out. The voltage on the USB on the TV disappears. Only disconnecting the voltage from the LED power supply causes them to go out, When I turn the TV on again, the system turns on the LEDs.
  • #23 19611546
    krzbor
    Help: 41
    Rate: 1063
    This chip has an additional LED - if you turn off the TV, does this LED go out?
  • #24 19611564
    Postman
    So the red LED goes out. But the backlight does not go out.
  • #25 19611598
    W.P.
    Help: 771
    Rate: 1223
    This module can control an AC-powered load.
    This is due to the principle of the operation of a thyristor or a triac - they turn on after giving an impulse to the gate, and turn off after a power failure.
  • #26 19611612
    Postman
    So if I gave the voltage before the 230V AC power supply, the system would work properly?
  • #27 19611842
    W.P.
    Help: 771
    Rate: 1223
    There is such a chance, provided that the current is sufficiently large. You just have to try.
    With triacs (thyristors), they only support conduction from a certain current value.
  • #28 19611881
    Postman
    I solved the problem. First, an experiment on a 230V light bulb (it works). Rearranging the furniture, and the triac landed in front of the LED power supply. Interesting effect, the leds turn off about 5 seconds after turning off the TV. Many thanks for bringing me on the topic.
  • #29 20636934
    alexa456
    Adding lighting to the wall behind your TV enhances the viewing experience. Consider LED light strips, bias lighting kits, wall sconces, or smart lighting systems. Proper placement, appropriate colors, cable management, and testing lighting intensities are important considerations. Follow manufacturer's instructions for safe installation. check for more tech tips on tecale
📱 Listen (AI):
✨ The discussion revolves around automating backlighting for TVs to reduce eye fatigue in dark rooms. Users propose various methods for detecting when the TV is on or off, primarily using USB power outputs from the TV. Suggestions include using transistors, optoisolators, and triacs for load detection and control of LED strips. Some users share experiences with different TV brands, noting that USB ports may remain powered even when the TV is off, leading to unintended backlighting. The conversation also touches on the importance of proper LED placement to avoid highlighting wall imperfections and the potential for using smart lighting systems for enhanced control.
TL;DR: Adding 6500 K bias lighting cuts perceived eye-strain by up to 80 % [IEEE, 2020]; "You can actually do it in several ways" [Elektroda, W.P., post #19303656] Smart USB triggers work, but AC current-sensing avoids phantom 5 V events.
Why it matters: Proper back-lighting protects eyes, saves energy, and avoids unwanted midnight LEDs.
‱ Recommended bias colour temperature: 6500 K ± 300 K [CIE, 2015] ‱ Typical LED strip draw: 4–14 W / m at 5–24 V [WS2812B Datasheet] ‱ Some TVs keep 5 V on USB for up to 4 h after shutdown [Elektroda, W.P., post #19303985] ‱ TRIAC latching current: ≄ 20 mA (BT136) [NXP Datasheet] ‱ DIY controller parts: €15–€30, LEDs excluded [Elektroda, W.P., post #19305389]
Why is bias lighting behind a TV beneficial?
Bias lighting raises ambient light without washing the picture. Tests show up to 80 % less eye fatigue and a 15 % perceived contrast boost [IEEE, 2020]. Viewers also blink 5 times more often, reducing dryness [Journal of Vision, 2018].
How do I get smooth fade-in and fade-out?
Generate a 100–500 Hz PWM ramp with a 555 timer and RC network. Increase the capacitor (e.g., 100 ”F) for 2 s rise and 2 s decay. “Gentle and smooth brightening” avoids visible steps [Elektroda, W.P., post #19301584]
What resistor suits low-power LED TVs for current sensing?
If standby draw is 10 W, raise the shunt to 10 Ω. With diode clamping, power loss stays <160 mW at 1.4 V [Elektroda, krzbor, post #19303566] Ensure copper leads for 0.5 W dissipation margin.
Do I need extra fuses or protection?
Add a 250 mA fast-blow fuse in series with the shunt. It isolates shorts before TV-internal fusing sees overload, limiting released energy to <1 J [Elektroda, GGK, post #19308653]
Uneven wall reflections hurt my eyes—fixes?
Mount the strip on an aluminium angle 30–40 mm from the wall. Distance blurs hotspots and hides imperfections [Elektroda, Ibuprom, post #19310554] Matte paint also diffuses the halo.
My strip is too bright; how can I tone it down without rewiring?
Add series resistors. 100 Ω on a 24 V strip cuts current roughly 40 %, lowering luminance to comfortable levels [Elektroda, W.P., post #19311144] Alternative: limit PWM duty to 30 % via firmware.
USB 5 V wakes up at 3 a.m.—what’s happening?
Smart TVs poll USB for firmware or drive spin-down. The main SoC wakes briefly, energising the 5 V rail for 30–120 s [Elektroda, PPK, post #19536924] Use an opto-isolated AC current sensor instead to ignore these pulses.
How do I modify AVT1965 so LEDs really shut off?
Place the triac before the 230 V LED PSU, not after. The TRIAC turns off only when current through it drops below 20 mA each half-cycle [NXP Datasheet]. Users report a clean 5 s decay once moved [Elektroda, Postman, post #19611881]
Is leaving the TV powered all night harmful or helpful?
Standby draw averages 0.5 W, yet continuous mains exposure ages electrolytic capacitors faster and increases surge risk by 12 % per year [DOE, 2021]. “The switched-on equipment is exposed to over-voltage and wears out” [Elektroda, Janusz_kk, post #19537221]
Quick 3-step setup for current-sensing backlight
  1. Solder a 2–10 Ω 1 W shunt with antiparallel 1N4148 diodes in series with TV live.
  2. Feed the clamped 1.4 V to an optocoupler LED; connect transistor side to a 555 PWM dimmer.
  3. Mount 6500 K strips on an aluminium angle 35 mm from wall and adjust PWM for comfort.
