Outdoor wi fi antenna for laptop, for receiving signal from the building
mateusz33 11709 5
  • #1 16882823
    mateusz33
    Rate: 26
    Hi
    Do they exist and is it possible to add an external wi fi antenna to the laptop and receive a wi fi signal from a building with a free network, distance plus or minus 100 m.
  • #2 16882835
    mistrzszymon1
    Help: 59
    Rate: 94
    There is such an option :) You can, for example, have something like that link
  • #3 16882849
  • #4 16882853
    mistrzszymon1
    Help: 59
    Rate: 94
    100 m as the author said it is not so much :) I used to have an ordinary yagi antenna from Mc Donald which was much more than 100m and in addition in a big city with a lot of networks around :)
  • #5 16882980
    m.jastrzebski
    Help: 679
    Rate: 865
    If you want to fry the brain or piss off the neighbors around or do the consequences from the telecommunications regulator, go ahead. Because according to the description, it breaks the rules having an output power 50x greater than allowed in this country. It probably has such an amazing quality that kneel the nations!
  • #6 16883259
    KOCUREK1970
    Help: 3861
    Rate: 5489
    There are no wifi antennas for the laptop - there are only external (internal) network cards.
    You can connect the antenna to receive wifi, but you have to disassemble the laptop (to connect to the built-in network cable and then all the mobility of such a computer goes into the head and it is already a desktop computer), the laptop itself must also be able to (the manufacturer of the wifi card did not fix built-in antennas so that they cannot be disconnected without a soldering iron or other equipment).
    In the building? - according to the regulations, the radiated power of the wifi signal in the 2.4 GHz band is ONLY 100 mW (for 5 GHz it is probably 200 mW) - you are sure that a wifi signal with such "power" is able to overcome these 100m in quality sufficient to maintain the connection ?
    Usually, such free hot spots are up to a stable range of up to 10 m from this place (no one wants to share "free" wifi, since they themselves bear the costs of maintaining it!).
    Maybe for what you recommended there is no "detective story", but I assure you that a possible visit (and she will be) of the UKE measurement team will knock you out of this idea and be sure that it will last.
    The fact that the 2.4 and 5 GHz band is not licensed does not mean that everyone in the wifi network with its power and range can do what they want.
    Please read this and your colleague will understand what you are talking about:
    • Rozporządzenie Ministra Administracji i Cyfryzacji z dnia 12 grudnia 2014 r. w sprawie urządzeń radiowych nadawczych lub nadawczo-odbiorczych, które mogą być używane bez pozwolenia radiowego.pdf (1.29 MB) You must be logged in to download this attachment.
