How to Build a DIY WiFi Booster Antenna for Lenovo Z560 Laptop to Improve Signal Strength
756 8
  • #1 21659788
    Purnendu Kumar
  • #2 21659789
    Purnendu Kumar
  • #3 21659790
    Cody Miller
  • #4 21659791
    Purnendu Kumar
  • #5 21659792
    Cody Miller
  • #6 21659793
    Per Zackrisson
  • #8 21659795
    Scott Jones
  • #9 21659796
    Andres Climb
The discussion addresses improving WiFi signal strength for a Lenovo Z560 laptop by building a DIY WiFi booster antenna. The laptop uses an 802.11g WiFi standard with an internal antenna. Suggested solutions include using a WiFi router configured as a repeater with a detachable antenna placed externally, or employing a USB WiFi adapter modified with an extension cable and an external directional antenna. Proper impedance matching (typically 50 ohms) between the USB dongle antenna port and the external antenna cable is critical, potentially requiring an impedance transformation circuit. Homemade directional antennas such as a "cantenna" made from a Pringles can or a beer can reflector are recommended low-cost options to boost signal gain. External commercial amplifiers like Wilson amplifiers were also mentioned as alternatives for whole-house coverage.
