Hello, how to remove the front pillar cover from the air curtain. Can it be done with the battery connected or better to disconnect so that nothing fires?
I'm not worried about the mistakes because I have the original cable so I can delete them later, I mean more as a damn thing to take off, which side to take
The discussion revolves around the removal of the front pillar cover from a Passat B6, specifically concerning the air curtain. Users express concerns about whether to disconnect the battery during the process to prevent accidental airbag deployment. One response suggests that while it is generally safe to proceed with the battery connected, it is advisable to remove the battery clamp to avoid error codes. The removal process involves unscrewing components under the airbag and detaching snaps. The author expresses frustration over the lack of clear instructions and mentions a night vision system awaiting installation. AI summary based on the discussion. May contain errors.
