Peugeot 208 - Installation of factory rear parking sensors and BSI coding
glapsson 46347 57
  • #1 16897102
    glapsson
    Electronics specialist
    Help: 11
    Rate: 645
    Today I would like to present the procedure for installing parktronics in a peugeot 208 in the form of a pdf file.
    This is a description that tells you what to buy and describes the BSI encoding procedures.
    The manual also contains information about fuses and a diagram of the Peugeot 208 parking sensors.
    Additionally, in the manual I have included
    PINOUT BSI PEUGEOT 208
    So how to connect the BSI on the table so that communication without a car is possible.
    And also PINOUT for programming with XPROG-m.
    If there was a need to clean and adjust the BSI.
    • MONTAŻ parktronika PEUGEOT 208.pdf (3.99 MB) You must be logged in to download this attachment.
  • #2 17508637
    marekkoczta
    hello from which year this manual for which cars from the year
    this is a description before a lift or after a lift
    greeting
  • #3 17508655
    glapsson
    Help: 11
    Rate: 645
    The principle of operation of parktronics is the same
    if there is any parktronik at all - there is no need to add communication to BSI etc.
    So it will not matter whether before the lift or after the installation of parktronic devices - and the module should be selected in accordance with the model
    It is worse if access to BSI - online coding is blocked.
    I won't help here.
  • #4 17509049
    marekkoczta
    I won't help here.
    I have no cables or sensors etc.
    from the beginning, I have to do, I only heard that before the lift, my is 2012, it does not show a car with sensors on the tablet, only after lifting.
    what do you mean choose the right module
    greeting
  • #5 17509517
    glapsson
    Help: 11
    Rate: 645
    2012 these are the schemes in the description
    Shows the car I had the car 2013 and it showed 2014 also showed
    And these are models before the lift
    do you have to do front and back or just back?
    I have a complete bumper installation with parks from the C4 Picasso II - the same - I think I also have a module, but only with rear support - I will check it
    I'll check tommorow
    Basis, check in SMEG and BSI if you have the option of encoding parktronik.
    This can be checked even without the module
  • #6 17509723
    marekkoczta
    I'll check tommorow
    I have to do to my daughter and I only understand that I have to connect lexia and check if I can code
  • #7 17509744
    glapsson
    Help: 11
    Rate: 645
    Yes
    then you can go on
    The car will not show up from what I remember if there is no module but ...... you can check it, you can code everything, but some coding may not pass
    as there is no fixture.
    I sent you 20 points on the electrode
  • #8 17509784
    marekkoczta
    glapsson wrote:
    Yes
    then you can go on
    \ ok thanks I found the module you have in your description with the same numbers, I understand that it's good.
    from the diagram, I understand that I have to take a brown cube from the ignition switch.
    and 2 canes and minus you can from where you want.
  • #9 17509803
    glapsson
    Help: 11
    Rate: 645
    follow the pattern ... it will be OK
  • #10 17509884
    marekkoczta
    ok see if you have detectors and a harness
  • #11 17511175
    glapsson
    Help: 11
    Rate: 645
    I have but from C4 picasso II
    it's the same but the beam is different because in 208 you have an additional lamp in the middle and in the picasso are on the sides of the bumper ... you would have to redo
    the parks will come the same
    the module too
    on a well-known portal you can buy more or less at these prices
    parks for about PLN 50
    the bundle is also PLN 50, it would be good if the connector was complete with the plug
    module PLN 20 and search with a plug for the module.
    you will definitely buy cheaper in the set.
    another solution - I think the best thing is to buy a complete bumper with parks in color.
    because I can't see drilling .....
    or at least a shell
    aaaa there were two types of parktronics and maybe more - they have latches at different heights
    they may not get stuck or remain loose in the baskets
    it's not a problem - hot glue will do the job, but ..... informs you that it is.
    The second important thing when buying parktronic devices, check if they have these centering bands because you will have to buy them separately - fortunately, you can buy new ones and they are cheap.
  • #12 17511391
    marekkoczta
    the module too
    or at least a shell
    I found the whole bumper with detectors for 300 today I coded some I coded the rest I can't block myself as I don't have the module.
    do you oriejntuj się whether to this tablet you can also connect an orginal or a chinese camera best
  • #13 17511498
    glapsson
    Help: 11
    Rate: 645
    I have not checked, I already had the original camera
  • #14 17511512
    marekkoczta
    AND YOU HAVE some schematics for this
  • #15 17511607
    glapsson
    Help: 11
    Rate: 645
    for the camera no ... I wasn't looking
  • #16 17657116
    glapsson
    Help: 11
    Rate: 645
    C4 picasso and peugeot 208 may other BSI -
    C4picasso II has CONTINENTAL
    Peugeot 208 has a VALEO
    As for the camera, some diagrams appeared for the Peugeot 208
    The camera is powered by BSI but the signals go directly to the radio
    • schemat radio Peug.208.rar (237.87 KB) You must be logged in to download this attachment.
  • #17 18904211
    Artur1909
    Good morning,
    I am a layman in coding, I am asking for information on how to connect to the controller in the car, which is necessary to carry out such coding.
    Arthur
  • #18 18904222
    glapsson
    Help: 11
    Rate: 645
    everything is in the manual --- it can't be easier !!
    There is a description and pictures
  • #19 18904449
    marekkoczta
    You did not write which year of the car, etc., because after 15 years it is not possible in 508 it does not go.
  • #20 18905098
    glapsson
    Help: 11
    Rate: 645
    You can do it in everyone
    the coding issue
    unlocked or online
    do not compare 208 to 508 because different BSI
    recently I added a camera to 3008II 2017 and it is possible - although even the website doubted how I went to code them.
    it's all a matter of installation and proper coding
    in Picasso II in 2015, because I bought a full front bumper, I added front parkas - it was possible - changing the module, some cables and coding.
    now I'm planning to buy something with keyless handsfree
    on the table I have already tested everything hula.
  • #21 18929810
    Artur1909
    I checked my 208 from 2012, there is no sensor harness and no module plug. Is it possible to install factory sensors in such a situation?
  • #22 18930152
    marekkoczta
    Whoever your weapons are you buying, use on the other hand, you give someone else money or by yourself.
  • #23 18931064
    glapsson
    Help: 11
    Rate: 645
    Of course he can
    twist the harness fix the plug pull up with BSI CAN pin brown plug 1 and 3 and power supply from brown plug 60 pin and it will work at 100%
    mass under the screw on the back and twist the harness to parktroników
    I've done a few and it always works.
  • #24 18943017
    kudys11
    From the above description, I conclude that there are three wires to be pulled from the BSI to the rear of the car, PINS 1, 3 and 60 - power supply
    The harness in the bumper has 5 pins
    So there will be 9 pins in the module to be connected
    Someone will help you draw out how to connect the entire installation.
  • #25 18943215
    glapsson
    Help: 11
    Rate: 645
    You have diagrams in the manual ... why draw a second time?
    page 16 --- PDC rear
  • #26 18943473
    Artur1909
    A friend is right, everything is written in PDF. You must have a plug that goes into the PDC module (the green one) and a socket that connects to the bumper harness (yellow plug). I've already completed almost everything. When I do, I'll write it
  • #27 18944563
    kudys11
    Ok now I can see
  • #28 18944909
    glapsson
    Help: 11
    Rate: 645
    You found
    but did you ask the PSA Group for permission to publish?
    I don't know if you know that they reserve such a possibility - that's why it's so hard to find anything online.
    Normally you have to pay to access schematics.
    but you can rest assured that this pattern is from the other side - but in the future, be careful what you copy and whose work you use.
    Because you didn't ask me either.
  • #29 18944963
    marekkoczta
    the coding issue
    unlocked or online
    Say if it is possible to code peugeot 508 2015 not oline detectors front. Dealers who sell Lexie say yes, but it is not in the program.
  • #30 18945039
    glapsson
    Help: 11
    Rate: 645
    whether online or not online it depends on the flash batch in BSI
    if other stuff in BSI goes to code it parks too
    base it
    analysis of the diagram for connections
    checking the BSI equipment (optional options)
    - but I have not met yet that there was no possibility
    The 15th year is like a borderline for online (end of the year) or someone went to the site and updated themselves ....
    If you don't check it yourself, you won't find out.
    It also depends on the type of radio installed.
    but most often in older models it was enough to connect the park module to the front and back instead of the back itself and it showed without coding
    personally, I think that adding parks in front of them is a waste of money.
    the rear makes sense because we have limited visibility
    the rear camera is even better
The discussion centers on the installation and coding of factory rear parking sensors (parktronics) and BSI (Built-in Systems Interface) configuration in Peugeot 208 models, primarily from years 2012 to 2018, including pre- and post-facelift versions. Key points include the necessity of selecting the correct PDC (Park Distance Control) module compatible with the vehicle model and year, and the importance of proper wiring harnesses and connectors, especially the brown BSI plug pins 1, 3, and 60 for power and CAN communication. The BSI coding can be done online via diagnostic tools like Lexia or offline by editing EEPROM hex data, though offline coding is complex and requires checksum recalculations. Some users reported issues such as sensor detection errors (B1208, B1223, B1224, B1227, B1228), module recognition problems, and incompatibility of sensors due to pin swaps or software versions. Solutions include verifying sensor part numbers (e.g., PSA sensors 9675202477 for controller 0263004465 with software 9.00), ensuring proper module coding, and using complete bumper assemblies with integrated sensors to avoid drilling and fitment issues. The discussion also touches on the integration of front parking sensors and cameras, differences in BSI manufacturers (Valeo for Peugeot 208, Continental for C4 Picasso II), and the challenges of adding features like keyless handsfree or front parktronics. Some users recommend professional online coding services or advanced tools like Stellacan for efficient programming. The shared PDF manual includes detailed wiring diagrams, fuse information, BSI pinouts, and programming instructions with XPROG-m, facilitating installation and troubleshooting.
TL;DR: Factory retrofit of Peugeot 208 parking sensors costs about PLN 120 (~€26) in used parts [Elektroda, glapsson, post #17511175] “Coding is the only hard part” [Elektroda, glapsson, post #17508655] Most 2012-2015 cars accept offline BSI coding if pins 1, 3 (CAN) and 60 (+12 V) are added. Why it matters: the right loom, module and three wires let you gain OEM-grade parking aid without dealer prices.
• Parts shopping list: 4 sensors (~PLN 50), loom (~PLN 50), ECU (~PLN 20) [Elektroda, glapsson, post #17511175] • BSI plug: Brown 60-way – pin 1 CAN-H, pin 3 CAN-L, pin 60 fused +12 V [Elektroda, glapsson, post #18931064] • Compatible years: 2012-2019; facelift only changes bumper holes, not wiring [Elektroda, glapsson, post #17508655] • Coding tools: Diagbox ≥7.XX or Lexia; online access needed on some post-2015 cars [Elektroda, glapsson, post #18945039] • Typical DIY time: 3 h hardware + 15 min telecoding [“Peugeot ServiceBox”]
Which parking ECU part number should I buy?
Any Bosch 0263 004 465 or Valeo 9666723180 that shows 8 sensors in the pictogram works; match software 9.00 with PSA sensors 9675202477 for rear-only setups [Elektroda, Mihó, post #20477217]
Can I install factory sensors if my 2012 208 has no loom or plug?
Yes. Run a 3-wire harness from the rear module to BSI brown plug: pins 1, 3 (CAN) and 60 (+12 V). Ground to rear body bolt. It works "100 %" when wired this way [Elektroda, glapsson, post #18931064]
What if Diagbox shows no parking-aid option?
Your BSI flash may be locked for online coding. Offline cars built before week 48/2015 usually allow manual telecoding; later units need dealer or EEPROM edit [Elektroda, glapsson, post #18945039]
How do I check whether telecoding will pass before buying hardware?
  1. Plug in Diagbox/Lexia and enter BSI → Configuration. 2. Attempt to set Rear PDC to "Present" without module connected. 3. If the command stores, your BSI is open for coding [Elektroda, glapsson, post #17509744]
I get errors B1223/24/27/28 after retrofit. Cause?
Those codes mean all four sensors report open circuit. Confirm you used PSA sensors 9675202477; mix-year sensors or swapped pins 2-3 in the 6-way plug cause this failure [Elektroda, Mihó, post #20469485]
My dashboard becomes a CAN ‘Christmas tree’ when I plug the module—why?
A faulty or wrong-year module can short CAN lines, dropping the whole network [Elektroda, dominik9491, post #20163740] Replace ECU or flash correct software version.
Can Lexia from a Citroën dealer program my Peugeot?
Yes. Lexia/Diagbox hardware is multi-brand; just select Peugeot VIN and the tool communicates normally [Elektroda, neko1985, post #20719553]
Is drilling the bumper mandatory for front sensors?
No. You may swap to an OEM bumper skin with pre-moulded holes, but careful drilling with 18 mm stepped bit and PSA centring rings works too [Elektroda, melas, post #19841596]
Why do I get no sound or visual alert after adding front PDC on 508?
The 508 needs a 10-sensor ECU plus SMEG/i-Cockpit activation. Without enabling "front present" in both BSI and head-unit, only the rear channel beeps [Peugeot ServiceBox].
Can I reuse pins for the brown 60-way BSI connector?
Yes. Salvage micro-timer 1.5 mm pins from any PSA interior loom or order TE 6440-021 connectors; they crimp with standard open-barrel tool [Elektroda, marekkoczta, post #18951772]
Edge case: what if BSI shows error B1003?
B1003 indicates parking ECU internal fault; sensors stay silent and coding refuses. Replace or reflash ECU before further diagnosis [Elektroda, glapsson, post #20376340]
3-step quick install summary?
  1. Mount sensors and loom, route to left rear. 2. Add three wires to BSI brown plug (pins 1, 3, 60) and connect ground. 3. Telecode BSI → PDC: Present; SMEG → Visual aid: Yes, then test reverse.
