[Solved] Locating Air Pressure Sensor & Alarm Speaker in 2011 Volvo FH 460 EEV
volvo fh460eev 13002 4
  • #1 16900754
    volvo fh460eev
    Rate: 36
    Hello, please tell me where is the air pressure sensor that gives a signal to the dashboard clocks. Car from 2011. The tip is crazy, too much or too little. The pressure from the computer is 10-11 bar
    Added after 7 [hours] 34 [minutes]:
    Colleagues, help me because the sensor has fallen completely and now every 5 seconds the alarm sounds. Where is the alarm speaker to suppress it?
    Anjei
    Help: 10
    Rate: 61
    Many times there was a problem in the dashboard.
    The air pressure sensors are located under the bonnet fairing and the driver's door.
  • #3 16903250
    volvo fh460eev
    Rate: 36
    Dude tell me yet, if connecting the pins shortly at the sensor will it temporarily solve the problem before I get on the base? It's about silencing an alarm that won't let you go.
  • #5 17083617
    volvo fh460eev
    Rate: 36
    Thank you for helping me find the sensor. Ordered used, original and replaced.
