Peugeot 3008 1.6 VTi Variable Valve Lift Faults: P101A, P1025, P1030, P1062 Diagnosis
david303 3030 2
  • Suspect VVT lift programming or actuator fault
    #1 21614909
    david303
    Hello, I am trying to solve a problem on my customer's vehicle - Peugeot 3008 1.6 VTi, mileage 130000 km. He bought it broken and now he wants to repair it. The problem is, Variable Valve Lift Motor isn't working when motor starts. Diag tells me faults P101A, P1030, P1062 and P1025. I tried changing both inlet camshaft sensors, set up chain timing and change VVT motor relay. I also tried set up adaptations, but it ends error every time. VVT test doesn't move with the motor, the only time it moves is, when I turn ignition. I really don't know what it can be. Could I ask for your help? Do you have any idea, what it could be?
    David
    Faults:
    P101A: Variable Valve Lift System Programming Fault Learning Error
    P1025: Variable Valve Lift System Programming Lift Programming Failure
    P1030: Variable Valve Lift System Programming Fault Coherence
    P1062: Variable Valve Lift System Power Part of motor relay - Difference between the motor control and position of the system
  • Suspected Valvetronic motor fault despite battery test
    #3 21686250
    david303
    thank you for the link to the forum. I have replaced the eccentric shaft in the car and carried out an adaptation, including a warm up and test drive, but the problem persists. The P101A and P1062 error is displayed and the Valvetronic does not start.... My guess is that the cause is the Valvetronic motor, but it is turning on the battery, and I have measured the connectors including the housing and everything seems fine.... Can I ask for advice on what else could be the cause?
