MAG 322 IPTV Decoder Standby Mode Issue: Screen Goes Blank after 10 Minutes on Same Channel
lukaszSP 4449 8
  • #1 16910516
    lukaszSP
    Rate: 15
    I received a decoder as in the title from my supplier.
    I have a problem with him.
    The set-top box turns off while watching a TV channel, e.g. for 10 minutes without switching to another channel.
    That is, the decoder does not turn off completely but the picture goes blank. Just change to another channel and the picture returns.
  • #3 16910535
    lukaszSP
    Rate: 15
    mihal2002 wrote:
    Read the manual.
    if there was a manual, I would not ask.
    There is only a manual for the remote control and nothing else.
  • #5 16910617
    LeDy
    Help: 1992
    Rate: 2942
    Switch off energy saving, eco.
  • #6 16911405
    lukaszSP
    Rate: 15
    Where is this function?
    Added after 47 [seconds]:
    Download in pdf.
    If you have a link, give it
    LeDy
    Help: 1992
    Rate: 2942
    Go into everything you can and maybe something similar to eco, saving, you will find. Maybe auto shutdown in time settings?
  • Check power saving, firmware, and HDMI cable
    #8 21525496
    masterartotaku
    Thank you for your message.
    The problem you describe may be due to the decoder's energy-saving settings or a software error. Please try the following steps:
    Check the power saving settings - go into the decoder's settings menu and check that the auto blanking or sleep function is not enabled after a few minutes of inactivity.
    Update the software - if a decoder system update is available, please install it.
    Reset the decoder to factory settings - this may help if the problem is due to the system configuration (please save important data or settings beforehand).
    Check the HDMI cable - sometimes a display problem can be caused by an unstable connection.
    If the problem persists despite the above steps, please let us know - we will forward the matter to the technical department or replace the device if necessary.
  • #9 21775900
    taylercoooper
    Power-saving settings – make sure functions like auto-sleep or automatic screen blanking aren’t enabled. They can sometimes turn off the picture after a few minutes of “inactivity
The MAG 322 IPTV decoder shows a blank screen after about 10 minutes on the same TV channel, while the device itself does not fully power off. Changing channels restores the picture. The discussion suggests checking the decoder’s energy-saving or eco settings, looking for auto-sleep or automatic screen blanking options in the menu, updating the firmware/software, resetting the device to factory settings, and verifying the HDMI cable connection. If the issue remains, the device may need technical service or replacement.
