Navman 5000 LM GPS: Software Installation Issue on Windows 7 - Compatibility and Solutions
polaris32 5223 7
  • #1 16916673
    polaris32
    Rate: 15
    I bought a Navman 5000 LM gps and received a program CD with it but for some reason I can't install it. Shouts that I have too old software and I have Windows 7
  • #2 16916684
    Freddy
    Help: 1394
    Rate: 2821
    Contact the bottom bracket, they will give you a working version. I went on about half a year ago, but unfortunately I didn't keep it because I did it to someone :(
  • #3 16916828
    koala106
    Help: 471
    Rate: 1240
    Run the installer in Windows XP compatibility mode. Alternatively contact with support.
  • #4 16917140
    polaris32
    Rate: 15
    I've tried different configurations and nothing.
  • #7 16918371
    Freddy
    Help: 1394
    Rate: 2821
    Try running on another computer.
    I was struggling the same with Mio480 and it was only on other equipment.
    Must have something to bite in the system.
  • #8 16919113
    koala106
    Help: 471
    Rate: 1240
    Install the virtual machine - put XP on it and it will walk. On the other hand, something is missing in the system - this version from navman is designed for all systems - including 8.1 and 10.
The discussion revolves around installation issues with the Navman 5000 LM GPS software on Windows 7, where users encounter compatibility problems. Suggestions include contacting support for a working version, running the installer in Windows XP compatibility mode, and trying the installation on a different computer. One user recommended using a virtual machine with Windows XP to bypass the installation issues, noting that the Navman software is compatible with newer systems like Windows 8.1 and 10.
