Condenser Dryer with Heat Pump: Built-in Under Counter Options (82cm High) - BEKO DPU8360X & Others
PawelO210 11559 2
  • #1 16929266
    PawelO210
    Good day.
    I am looking for a condenser dryer with a heat pump built-in under the counter, i.e. with a removable top cover - then the dryer should be about 82 cm high. I am asking for types and indications. Initially, I found the BEKO DPU8360X dryer - the photos show that this one has a removable top. I have a second question: are there built-in dryers, so without a front?
    Regards
  • #2 16929526
    Borutka
    Help: 125
    Rate: 414
    The dryer often produces a lot of moisture. Even if a colleague manages to build it in, it may be a faulty solution in the long run.
  • #3 16930492
    PawelO210
    I understand. I read that the dryer gives off a lot of heat, but on various interior arrangements you can see that the washer and dryer are hidden in the closets.
    I also read that such a solution is used, with the room must be well ventilated and the cabinet door opened during drying.
    In my case, the dryer will be standing under the concrete countertop, in the recess between the wall and the ventilation chimney. Therefore, I can make a ventilation grille with a fan in this recess, directly under the countertop.
    Returning to the question, I am asking you for a hint and a good dryer for such buildings, i.e. with a removable top.
    Regards :-)
