[Solved] Beko DSX83410W Dryer: Persistent Wetness at Heat Exchanger's Bottom
zbychu 123 50541 8
  • #1 17852185
    zbychu 123
    Hello Forum members!
    I have been using the Beko DSX83410W dryer for 3 years. For some time now, when cleaning the heat exchanger, I have been puzzled by the fact that its bottom is wet. It`s not leaking outside yet, but there is more and more water. It`s high time to address this, so with your help I want to fix it. Thank you in advance for all your advice and tips. Regards!
  • #2 18294703
    werfeta
    Rate: 77
    Have you already dealt with this problem?
    I also have a Beko dryer. Today there was water on the floor and I noticed that, like you, there was water standing in the exchanger.
    Regards
  • #3 18294848
    UczenEl
    Help: 31
    Rate: 390
    Is there water in the condensate drawer?
  • #4 18294885
    werfeta
    Rate: 77
    Yes, there is water in the drawer, but I don`t know if it is less than usual.
  • #5 18295292
    mrhari
    Help: 835
    Rate: 3239
    This part in the photo is the condenser.
    The condenser, as the name suggests, is used to convert water vapor into water.
    If there is water, it is wet....
  • #6 18295387
    werfeta
    Rate: 77
    Ok, I understand (the water is there because it`s supposed to be there), but the question is why is it on the floor? Any suggestions; maybe just a clogged foam filter (the mess was really terrible).
    What possible reasons could there be? It was about the same amount as a glass of water. I will test it after cleaning the filter and write what happened.
    Regards
  • #7 18295421
    UczenEl
    Help: 31
    Rate: 390
    Jamming pump, clogged tubes, poor water reception
  • #8 18295761
    werfeta
    Rate: 77
    The floor is dry after running on the longest program.
    It`s possible it`s just a filter, but I`ll obviously keep an eye on it.
    I will buy a new filter insert, they cost about PLN 20-25 with shipping, so it`s not a tragedy, and cleaning it after three years of use is almost a miracle (clogged pores).
  • #9 18461514
    Kxsonka
    Rate: 78
    Hello! I have a question about the problem described in the title of the post. Did you manage to solve this problem? I have had the dryer for a year and initially, for about half a year, everything was fine, then the evaporator filter was only wet when using the delicate program, now water accumulates after each drying process, regardless of the program. I clean the sponge filter and these metal parts regularly, so I wonder what is the reason? Is this a defect of the device and is it covered by warranty?
The discussion revolves around the Beko DSX83410W dryer, specifically addressing the issue of persistent wetness at the bottom of the heat exchanger. Users report similar experiences, noting water accumulation in the condensate drawer and on the floor after drying cycles. Possible causes suggested include a clogged foam filter, jamming pump, or blocked tubes. One user mentioned that cleaning the filter may resolve the issue, while another inquired about warranty coverage for potential defects. Overall, the community is focused on troubleshooting and finding solutions to the water accumulation problem.
