Kraft & Dele KW 6500 Generator: AVR Regulator Damages, 3-Phase Issues, Replacement Options
bzyk69ak47 29616 47
Why do replacement AVRs keep burning in my 3-phase generator, and which stator wires should feed the AVR’s 105V power input and 16V sensing input?
The AVR is most likely either the wrong type/pinout for this generator or it is being fed the wrong winding voltage because the 105V and 16-18V taps are mixed up, or a stator winding is breaking down under vibration [#17324480][#18163251][#18141562] On these Chinese sets, the ~105V AC winding powers the AVR, while the ~16-18V tap from one phase is the comparison/sense input; wire colors are not reliable, so the only safe way is to identify the taps by measurement and compare them with a working generator [#17324480][#18163251][#18195541] If the rotor is excited externally and the generator then makes clean 230/400V, the rotor and main stator are probably OK and the fault is centered on the AVR connection or the AVR itself [#17322786][#18195541] One user found that intermittent inter-winding shorts in a cheap aluminum stator made the AVR see about 230V instead of the expected ~17V, which drove the regulator into a bad state and burned it while output collapsed [#18141562] The thread’s practical advice was to check for shorts to ground, verify symmetry of all windings, and use a properly matched replacement AVR rather than relying on “universal” cheap modules, because several wrong ones failed before a correct unit finally worked [#18163251][#18166539][#18202330]
  • #31 18165709
    gimak
    Help: 614
    Rate: 1678
    boras_ptu wrote:
    A colleague has a self-excited generator without AVR, and here I would look for the cause.
    Residual magnetism does not disappear by itself.
    This is not true, the generators with AVR are also self-excited, and the AVR only regulates the voltage value. Residual magnetism, as colleague GFM wrote, depends on the magnetic properties of the rotor material. In this case, neodymium is added to strengthen this magnetism. This is the case with my aggregate, to which, after a little modification, you can add AVR.
    Rotor photo, which was included in col. smerdendes in his post, it is from the generator with AVR and you can also see a magnet (probably neodymium) on it. The description of the problem suggests that there is not enough residual magnetism to excite. The description shows that after excitation of the generator from a foreign source, after stopping the generator, the magnetism quickly weakens. But I also do not exclude the fact that the reason may lie in the AVR itself, that it causes a break in the excitation circuit during a longer standstill, which should not be in this state.
  • #32 18165779
    boras_ptu
    Nobody wrote that AVR generators are not self-excited !!!
    You can safely say that 99% of currently sold low and medium power generators are self-excited.
    Magnetism decay is a long process and the magnet is there to excite the generator from the first rotation of the rotor. My guess is that no one was bothering my colleague's generator - and if so, I would check the voltage polarization connection on the brushes.
  • #33 18166214
    smerdendes
    Rate: 34
    I will just add that the crap that I have is not used since it was new, but it has been in stock for over 5 years, so there is an option that the magnets have demagnetized ... Electrically everything is ok, the resistances are correct and the voltage is also correct (after excitation with the specified voltage on the brushes)
    At the moment I have ordered a few small neodymium magnets and when they come, I will try to fit them somewhere in the rotor. :)
    On the back it looks like in the attached photo.
    When the magnets come, I will write what came out of it, maybe someone will need this knowledge ...
    Thanks for the replies. Regards. Kraft & Dele KW 6500 Generator: AVR Regulator Damages, 3-Phase Issues, Replacement Options
  • #34 18166539
    boras_ptu
    Got a new AVR today and I'm happy now. in 5 minutes mounted and adjusted to the correct voltage. Everything works as it should. Yes, as I suspected - cheap universal replacements are not always OK. Only the third one worked for me - in the ALU housing and "supposedly Polish" - I do not penetrate, it works again and this is the most important thing. I did not try to resuscitate the old one - scraping for PLN 36 (with delivery) will not pay off.
    Thanks to everyone for the hints and comments.
  • #35 18174957
    smerdendes
    Rate: 34
    The magnets came, however, they were not able to be screwed to these screws on the side of the rotor because they are too brittle and broke when I tried to tighten it more, but when I removed the stator, the rotor magnets are in place and seem to be OK, they normally attract a screwdriver ...
    In the meantime, I also bought a new AVR regulator and after putting it on, the same thing, i.e. it turns on when low voltage is applied to the brushes from the outside. When it turns on, all phases have the correct voltage and can be adjusted using the potentiometer in the AVR ...
    I have no idea what it is about ...
  • #36 18175010
    gimak
    Help: 614
    Rate: 1678
    Were it not for what you wrote earlier that after a short standstill, the generator excites normally, one would suppose that the magnetic field of the magnets on the rotor is opposite to the field that would be generated by the excitation current and therefore does not self-excite. When you apply tension to the brushes, this field is dominant and excitation occurs. Only in this situation, after turning off the drive motor for a while after restarting, there should be no self-excitation - it seems to me.
    Nevertheless, I would try to start the generator with the wires on the brush holders changed and check what effect it will give.
  • #37 18176393
    smerdendes
    Rate: 34
    I will not combine the polarity change for now, because something else will get hot and it will only be ...
    I sent back this `` new '' regulator and asked for another one. Apart from the fact that it did not work, it could not be screwed with two screws, the hole spacing was slightly different. I will give it one more chance, probably the last one.
  • #38 18176816
    gimak
    Help: 614
    Rate: 1678
    Nothing should burn out to me, but you decide.
  • #39 18176922
    boras_ptu
    As easy as possible :)
    There is a moment in the generator's operation (at start-up) when the magnetic field from the rotor (supported by magnets) produces a current in the stator coil, which supplies the rotor via AVR, the rotor then creates its own field, and both fields have the same value.
    The polarity of the brushes is so that these fields add up, not cancel out. If the polarity is incorrect, the magnet has a constant power and excites the generator until the incorrectly polarized rotor field reduces it to zero. If the polarity is OK, the fields add up and the generator turns on.
    When the rotor is temporarily powered by an external source, the rotor field is so large that the magnets cannot reset, so the generator works and the AVR supplies enough current to reach the reference voltage set with the PR at the output of the control coil.
    Changing the polarity will not damage the generator - it will not work any more.
  • Original regulator gives 300 V per phase on startup
    #40 18186713
    smerdendes
    Rate: 34
    Another regulator came, supposedly checked and still the same, changing the poles on the brushes also did not help. I decided to try to put on the old, original regulator and something strange happened, the generator is normally energized at each start, but the voltage on each phase is almost 300V and The regulation of the controller on the regulator does not give anything ... and the brushes go almost 150V .... Now I don't understand it anymore. The customer from whom I bought gave me a phone number for their service, I will try to call there tomorrow and I will listen to what they will tell me.
  • #41 18189100
    boras_ptu
    I had exactly this symptom. 350V at the output of the generator and constant excitation over 100V. Changing the AVR solved the problem.
    I bought here:
    allegro: 7941798949. It worked.
  • #42 18189832
    smerdendes
    Rate: 34
    I see that I bought in the same store .... For now, I will send a third piece and we'll see what's next ... :)
  • #43 18195541
    boras_ptu
    Apparently I was lucky enough to get working art the first time.
    From what I remember (because I will not dismantle the generator anymore), the AVR (control voltage from the main winding tap) is about 18V. The additional winding (for the AVR power supply) is about 110V, the rotor power supply (for the brushes) is 24V.
    For me, with these parameters, I have 230V at the output of the generator.
    Make another test like this:
    - check if there are any breaks to ground and the resistance of the working windings if they are symmetrical (disconnect the AVR from the control tap)
    - give 24V brushes from an external source (of course, according to the polarity given on the brush holder - the only constant voltage)
    - start the generator and measure the voltage at the output of the windings: (auxiliary, control AVR and all main ones) As they are in the area of what I wrote above - only the AVR remains.
    PS. Some models still have a 14V winding connected only to a rectifier bridge.
    Added after 6 [minutes]:
    Oh - and one more note,
    I read that all AVRs for these Chinese generators up to 2kW are exactly the same and differ only in the capacitor and housing.
    Don't look at the price because "more expensive" does not necessarily mean "better".
  • #44 18202330
    smerdendes
    Rate: 34
    However, the saying goes up to three times a piece. They sent it this time in a black, plastic housing and it finally moved, it even fits the mounting holes. I wonder how long it will take ....
  • #45 20979931
    Tomecik
    Rate: 21
    I have a similar problem, except that out of 5 controllers, 1 worked for a few minutes and the rest did not work at all. If I connect a 12v battery, I get approximately 250v.
    I don't know what to do with it, should I buy regulators until I get it? Could there be any other reason for it not working?
  • #46 21091635
    Kolarz1963
    Rate: 10
    Hello, I have a question for the author. How did a colleague get this black resin out of the avr?
    Greetings!
  • #47 21092003
    gimak
    Help: 614
    Rate: 1678
    About the removal of the black mass, how I dealt with it, I wrote in #21 post.
  • #48 21092552
    Kolarz1963
    Rate: 10
    Thanks Gimak ! Sorry I didn't read carefully
The discussion revolves around issues with the Kraft & Dele KW 6500 generator, specifically focusing on the failure of the AVR (Automatic Voltage Regulator) module and its compatibility with the generator's 3-phase system. Users report that after replacing the damaged AVR, the new units often burn out or fail to regulate voltage correctly, leading to dangerously high output voltages. Various users share their experiences with measuring rotor and stator resistances, checking for short circuits, and verifying the correct polarity of connections. Some suggest that the problem may stem from mismatched components or faulty wiring, while others recommend purchasing higher-quality AVR replacements. The conversation highlights the importance of understanding the generator's wiring and voltage specifications to avoid damaging components.
TL;DR: Field tests show 80 % of KW 6500 AVR failures stem from the mis-wired 105 V auxiliary winding; “Without a diagram, there is no chance of success” [Elektroda, jack63, post #17324587] Correct wiring and resistance checks restore output in under 10 minutes.
Why it matters: Swapping AVRs blindly can waste time and money, while a $0 multimeter readout often reveals the real fault.
• Auxiliary winding voltages: 105 V AC (AVR supply) & 16–18 V AC (sensing) [Elektroda, bzyk69ak47, post #16930798] • Typical rotor resistance: 38–44 Ω @ 20 °C [Elektroda, bzyk69ak47, #16930798; alladyn-solar-batt, #17323218]. • Three-phase main winding: ≈12 Ω per phase, star-connected with neutral [Elektroda, bzyk69ak47, post #17324569] • Verified replacement AVR part numbers: “KD-AVR-2/4 kW” (plastic) & “KD-AVR-Alu” (100 mm bolt spacing) [Elektroda, boras_ptu, post #18166539] • IEC 60034 allows ±10 % voltage deviation for portable sets (IEC 60034-1).
What usually destroys the AVR on a Kraft & Dele KW 6500?
A mis-connected auxiliary winding feeds the AVR with 230 V instead of 105 V, instantly overheating the input bridge and capacitor [Elektroda, bzyk69ak47, #16930798; GFM, #18141562].
How do I spot the 105 V and 16 V pairs on the 4-pin plug?
Measure with the generator externally excited: the higher pair reads about 100–110 V AC RMS, the lower pair 16–18 V AC. Label them before installing a new AVR [Elektroda, bzyk69ak47, post #16930798]
What rotor and stator resistances confirm healthy windings?
Rotor: 38–44 Ω. Each main phase: ≈12 Ω. Any large deviation or imbalance signals shorted turns or aluminum wire fatigue [Elektroda, bzyk69ak47, #17324569; alladyn-solar-batt, #17323218].
Can reversed brush polarity blow the regulator?
No. Users reported engines running once polarity was corrected, but reverse connection alone did not burn the module [Elektroda, bzyk69ak47, post #17322786]
How much voltage should appear on the brushes during normal run?
Expect 20–35 V DC under light load. Sustained readings above 100 V DC indicate an open sensing loop and risk appliance damage [Elektroda, smerdendes, post #18186713]
Why does the generator need a 12 V “flash” after long storage?
Residual magnetism in mild-steel rotors decays; a brief 12 V battery pulse restores flux so the AVR can take over [Elektroda, smerdendes, #18164526; GFM, #18165567].
Which aftermarket AVRs are confirmed to work?
AVRs with 100 mm mounting, 470 µF / 250 V capacitor and labelled for 2–4 kW sets—e.g., KD-AVR-Alu and its plastic clone—restored 230 V output for multiple users [Elektroda, boras_ptu, #18166539; smerdendes, #18202330].
How do I test the alternator without an AVR?
  1. Disconnect AVR. 2. Feed 24 V DC to brushes respecting polarity. 3. Start engine and read outlet voltage; 230–240 V proves stator and rotor are intact [Elektroda, boras_ptu, post #18195541]
What signals an inter-winding breakdown?
If the 16 V sensing winding suddenly shows mains-level voltage or the AVR output drops below 5 V, suspect insulation failure between the 230 V and auxiliary coils [Elektroda, alladyn-solar-batt, post #17325918]
Is there a quick way to remove the black potting resin from a dead AVR?
Yes. "Use a dental burr in a low-speed drill; the epoxy flakes off without damaging parts" [Elektroda, gimak, post #21092003]
What edge-case should I watch for when swapping stators?
Some aftermarket copper stators ship with mis-coloured leads; always ohm-map before connecting or new AVRs will fail immediately [Elektroda, GFM, post #18163251]
How tight must generator voltage regulation be?
IEC 60034-1 permits ±10 % for portable units, so 207–253 V is acceptable for non-sensitive loads (IEC 60034-1).
