Reading data from Apator Elf heat meter via Mbus and RS232 converter - how?
drFeelGood 3609 2
  • #1 16936579
    drFeelGood
    Rate: 19
    Hello, short question: is it possible to read data from a heat meter with an mbus module as in the topic after connecting for example any mbus rs232 converter and a computer? I'm green on the subject, I haven't found anything at this level on the web so please be understanding.
  • #2 16936966
    pol102
    Help: 163
    Rate: 369
    The question is interesting but I'm betting no one will answer you, and Apator itself probably has an ace up its sleeve traditionally.... not without reason a converter from them costs 2700netto ;)
  • #3 16937371
    drFeelGood
    Rate: 19
    The protocol itself is well described and, to my current knowledge, the device should respond to a standard compliant query. But I only have theoretical knowledge :-) .
