Intermittent Fiber Optic Connection: LOS LED Flashes Red on Router
Typowy Mirek 26700 16
Why does my fiber internet and TV keep dropping with the LOS LED flashing red, and could the cable under the skirting board be causing it?
The intermittent LOS red flash is more likely caused by the ONT/modem, its power supply, a bad connector/adapter, or a problem on the provider side than by the skirting board periodically “pinching” the fiber [#17660890][#17660916][#17661066] Fiber normally does not behave like a cable that sometimes makes contact and sometimes doesn’t; if it is physically damaged or badly bent, it usually causes постоянное attenuation or failure rather than random half-day outages [#17660890][#17661399] If the optical power level is around -25/-26 dB on GPON, that suggests excessive bend loss, a bad weld/pigtail, or a damaged adapter [#17660904] What you can check locally is whether the fiber runs freely with no sharp bends and whether any spare length is coiled too tightly, because a very small coil can attenuate the signal [#17661086] If the line and routing look fine, the operator should check the active equipment and optical level and consider replacing the ONT/modem rather than blaming the floor strip [#17660870][#17661399][#17661520]
  • Intermittent fiber link likely caused by cable pressure
    #1 17660840
    Typowy Mirek
    I don't know if I'm in the right section - if not, I apologize in advance and please place the topic in the right one.
    Now to the point...:
    I recently moved into a new apartment, where we were offered FIBER OPTIC - internet + TV.
    I agreed, the gentlemen from the company from which I got the service ran the fiber optic cable, which was hidden behind the floor strips (it was not bent), connected it to the router, there is WiFi, there is a TV signal - everything works fine.
    After a few days of use, suddenly there is no Internet and TV signal, once there is no signal for half a day, and for the second half everything works again, once it does not work all day, and the next day everything works again, and sometimes everything works, and then for 2 days -3 hours no signal (does not work), then comes back and works again.
    When there is no signal, the LOS LED on the router flashes red.
    When there is a signal, the red LED does not blink and does not light up.
    Of course, specialists from the company from which I got the service were called. They came and measured (probably because I'm not an expert) the fiber flow - it turned out to be OK. They thought about it, went to their boxes and came up with an idea, or rather a solution, here it is:
    - the floor panel or skirting board presses on the optical fiber, so sometimes there is a signal, sometimes there is not. And they added that they would replace my optical fiber after New Year's Eve, leaving me on New Year's Eve instead of Polsat (or another channel) with silence...
    My question: IS THIS POSSIBLE?
    I would understand if the optical fiber was interrupted, but then there would probably be no signal at all for several days, and sometimes there is, sometimes there is no signal. Besides, they measured everything and said everything was fine, and now I would have to tear off the skirting boards again to install a new fiber optic cable, which is not known whether it will work properly...
    COULD IT BE THEIR FAULT, E.G. SERVERS THAT SOMETIMES I HAVE A SIGNAL AND SOMETIMES I DO NOT?
    Best regards and I would like to ask for an answer
  • #2 17660870
    kranzio
    Help: 91
    Rate: 139
    Maybe the fault lies with the modem or power supply.
  • Faulty modem or connectors likely cause intermittent loss
    #3 17660890
    dzidek1968
    Help: 96
    Rate: 402
    I'm betting it's the supplier's fault. Fiber optic is not a cable that if it breaks, sometimes it will touch it, sometimes it won't ;-) . Once it breaks, it just sneezes. MZ, replacing the optical fiber will not help (maybe I'm wrong). Especially since no one seems to move it and the bending radius doesn't change over time. I remember that in our network, when we built the main threads on optical fibers, we had a problem with strong signal attenuation in one thread. It turned out that when I was welding the fibers, I accidentally bent the pigtail too much on the splice tray. :-) . And the attenuation increased dramatically, but the signal was still there, but weak. If you have it sometimes and sometimes not, I would rather bet on a faulty modem at your home or on the other side, at the operator's. Possibly some connectors on one side...
  • Possible fiber cable pinch at wall panel gap
    #4 17660899
    Typowy Mirek
    Everything is working, even the specialists from the company checked the equipment they provided, everything blinks green (power wlan, etc.) even when there is no signal, but when there is no signal, there is also this red diode next to LOS... Magic, I wonder about the text experts regarding the panels, whether something may be pressing and that's why the connection is interrupted and sometimes it works normally - for me it's strange, if only because there is about 5-8 mm gap between the panels and the walls where the fiber optic cable looks like a string is inserted, so I don't even know if it has minimeter diameter...
  • #5 17660902
    kranzio
    Help: 91
    Rate: 139
    Is the power supply external or in the modem? Maybe the end of the fiber optic plug that is plugged into the modem is badly connected. What modem do you have for fiber optic?
  • #6 17660904
    LucekB
    Help: 143
    Rate: 137
    What is the signal level is the question, if it is e.g. -25 or -26 (GPON), it is too much bent somewhere, a bad weld or pigtail, the adapter is damaged.
  • Active device more likely than fiber connector
    #7 17660916
    dzidek1968
    Help: 96
    Rate: 402
    You probably won't get a bad end of the fiber optic cable, maybe some crap happened. The fitter does not make the ends, he only welds on the finished pigtail. But I would rather bet on a problem with the active device. You know, if someone moves the plug or cable and sometimes it works, sometimes it doesn't, that's OK, but if everything lies still, it's probably not a problem...
  • Faulty modem or connectors likely cause intermittent LOS
    #8 17660930
    Typowy Mirek
    dzidek1968 wrote:
    I'm betting it's the supplier's fault. Fiber optic is not a cable that if it breaks, sometimes it will touch it, sometimes it won't ;-) . Once it breaks, it just sneezes. MZ, replacing the optical fiber will not help (maybe I'm wrong). Especially since no one seems to move it and the bending radius doesn't change over time [...] If you have it sometimes and sometimes not, I would rather bet on a faulty modem at your house or on the other side, at operator. Possibly some connectors on one side...
    The optical fiber was not moved after its installation, as you say, at the beginning everything worked without any problems, I will ask these specialists about the new modem, maybe the fact that everything lights up nicely in green does not mean that everything works OK in it. Although the specialists from the company said that everything ok, but if they were able to squeeze in a story about the panels, who knows...
  • #9 17660952
    kranzio
    Help: 91
    Rate: 139
    What modem did your friend install?
  • Intermittent faults are hardest to reproduce
    #10 17660953
    dzidek1968
    Help: 96
    Rate: 402
    I know how it works, I was a supplier myself for several years. I won't deny that if you have many clients, you probably don't look for problems yourself. I don't want to say that I'm pissing off the customer, but no one replaces the equipment in everyone's home right away, because you won't be able to do it even if you do gymnastics. :-) . First, less radical measures are taken, i.e. replacing the connectors, checking the cable routing, etc. Anyway, I will tell you that these types of faults (sometimes it works, sometimes it doesn't) are the most nasty. I'd rather have something just go wrong at the client's and replace it than have to go back ten times and it worked like hell every time we came back. ;-)
  • #11 17660961
    Typowy Mirek
    That's right, it lies motionless because, as I wrote, it worked, but then something happened later. Today, for example, there was no signal from morning until 6:40 p.m., and now there is - magic...
    Added after 5 [minutes]:
    huawei echolife hs8546v
  • #12 17661035
    kranzio
    Help: 91
    Rate: 139
    See this manual Link on the behavior of PON and LOS diodes. Instructions from another modem, but I think the principle is the same in yours. Unless you have the manual for yours.
  • #13 17661066
    SP5IT
    Help: 1298
    Rate: 1695
    Nonsense. If the installer thinks so, he should work elsewhere.
    In my opinion, the fault lies with the signal provider.
    M
  • #14 17661078
    Typowy Mirek
    Thanks, now, as I wrote earlier, everything is working from 6:40 p.m., so PON is on correctly, and LOS is not on at all. If the signal disappears again, I will write here what is happening, how they blink (fast or slow) and what it means with this instruction, maybe someone will then translate it into common sense. I will definitely describe everything because sooner or later the signal will probably disappear. I will try to keep you updated on everything ;-)
  • #15 17661086
    seb235
    Help: 98
    Rate: 74
    This is the biggest disadvantage of fiber optics - if something goes wrong, you basically can't do anything yourself, you have to call the service and, as is usually the case in life, when it shows up, everything works without a problem. It is also a pity that you did not pay attention to the signal level from the reflectometer, if such a measurement was made.
    As for the theory that sometimes you press something and then it doesn't work, and other times it works because there is no pressure - it seems moderately probable to me. For your part, you can basically check one thing - whether the cable runs freely along the route of sharp bends - if there are any, try to arrange it so that it runs as loosely as possible. Another issue is if you have a supply of cable in your apartment and I know that some companies do this and leave the cable rolled up in a coil at the customer's place. Unfortunately, if the diameter of the circle is too small, the signal on the cable begins to be significantly attenuated. So if you have a spare, you can try to loosen it slightly by increasing the diameter of the circle. Of course, there is no guarantee of success, but if it doesn't work and you don't know why, you don't risk anything and maybe you will find something.
    By the way, it's a pity you didn't talk to me, maybe they could have made a makeshift solution so that you would have a working service for a few days.
    As for the nomenclature, the optical fiber device is an ONT, not a modem. :)
  • #16 17661399
    dzidek1968
    Help: 96
    Rate: 402
    seb235 wrote:
    ... and I know that some companies do this and leave the cable wrapped in a coil at the customer's place. Unfortunately, if the diameter of the circle is too small, the signal on the cable begins to be significantly attenuated. So if you have a spare, you can try to loosen it slightly by increasing the diameter of the circle.
    Honestly, I don't know how tightly the cable would have to be wound and how many turns it would have to have to attenuate the signal :-) . I still remember when we bought a welding machine and, as it happens with big children ;-) , we had some fun, I wound individual fibers around my finger like a spring and the optical fiber didn't break, but also attenuated it quite a bit. I don't know how tightly the installer would have to wind the cable to make the signal disappear ;-) ). Therefore, as I wrote earlier and was confirmed by several colleagues, I do not believe that the optical fiber is to blame and I think it is the equipment's fault. Unfortunately, switches, converters, modems and optical modules can hang. If it happens once, e.g. after a temporary power outage, it's OK, but if it happens more often, the device needs to be replaced. These are costs, which is why the operator, as I wrote, first tries to "hide" the situation, and if it doesn't help after a while, then he will replace something. This is how it works, I know from practice :-) .
  • #17 17661520
    Typowy Mirek
    This is what I'm leaning towards the most...
    As I wrote earlier, guys, there was no signal since the morning, suddenly at 6:40 p.m. it is there and still working. As soon as it stops working, I will write, according to the instructions sent by my colleague Kranzio, what frequency the PON and LOS diodes are flashing, and what the instructions say it may mean.
    Well, some magic...
The discussion revolves around intermittent connectivity issues with a fiber optic internet and TV service, where the LOS LED on the router flashes red, indicating a loss of signal. The user reports that the connection works sporadically, with periods of no signal lasting several hours. Responses suggest potential causes, including a faulty modem, poor connections, or issues with the signal provider. Some participants emphasize that fiber optic cables are generally reliable unless physically damaged, while others recommend checking the modem and the signal levels. The user mentions the Huawei EchoLife HS8546V modem and expresses uncertainty about the installation and equipment provided by the service company.
TL;DR: LOS flashing red means the optical link is down. A measured level near -25 to -26 dBm suggests high attenuation; "what is the signal level is the question." Ask for an ONT swap and provider-side checks before re-cabling. [Elektroda, LucekB, post #17660904]
Why it matters: This FAQ helps apartment users fix intermittent fiber (LOS red) on Huawei/GPON and talk to support efficiently.
  • Typical GPON ONT receive power window: approx. -27 to -8 dBm (Class B+). [ITU‑T G.984.2]
  • On Huawei ONTs, LOS red blinking = loss of optical signal; PON solid = registered. [Huawei HG8245H User Manual]
  • Minimum bend radius for indoor fiber: approx. 10× cable diameter (≥30 mm typical) to limit macrobend loss. [TIA‑568.3‑D]
  • Up to 80% of fiber link issues come from contaminated connectors; clean SC/APC before reseating. [FOA Guide to Cleaning Fiber Optic Connectors]
  • ONT reboot and re-registration typically complete in 2–3 minutes; watch LEDs to confirm. [Huawei HG8245H User Manual]
Why is my LOS LED flashing red on a Huawei EchoLife HS8546V?
It means the ONT is not receiving sufficient optical signal. The LOS alert is tied to the physical fiber layer. Check whether PON is off or blinking, indicating no registration with the OLT. When PON turns solid, service should return. The behavior matches Huawei ONT manuals for similar models. [Huawei HG8245H User Manual]
Can a skirting board pressing the fiber really cause intermittent Internet?
Unlikely, unless it causes a severe bend or a break. As one installer put it, "Once it breaks, it just sneezes." A stationary, hidden drop that is not moving rarely changes bending radius over time. Intermittent LOS points more to connectors, splices, ONT, or upstream equipment. Ask the provider to inspect active gear before replacing the indoor drop. [Elektroda, dzidek1968, post #17660890]
What optical power level is too low on GPON?
If the measured optical receive level is around -25 to -26 dBm, suspect excessive bending. A bad splice or a damaged adapter can also cause it. Those values sit near the margin where minor disturbances cause drops. Request a technician to check splices and adapters and correct macrobends. [Elektroda, LucekB, post #17660904]
Is this more likely a provider-side issue or my ONT?
Several technicians point to the provider side for intermittent LOS. One wrote, "If the installer thinks so, he should work elsewhere." Ask support to check the OLT port, splitter, and their patching. Have them test with a known-good ONT at your outlet. [Elektroda, SP5IT, post #17661066]
How do I troubleshoot LOS dropouts at home?
Try this quick sequence:
  1. Power the ONT off for 60 seconds, then on. Wait up to 3 minutes.
  2. Note LOS/PON LED behavior and times. Photograph it for support.
  3. Clean and reseat the SC/APC connector using proper fiber tools. Avoid touching ferrules. Cleaning and reseating fixes many optical issues. [FOA Guide to Cleaning Fiber Optic Connectors]
Could a bad connector, weld, pigtail, or adapter cause this?
Yes. A bad splice, pigtail, or adapter increases attenuation and may trigger LOS. As an expert noted, "bad weld or pigtail, the adapter is damaged." Ask for inspection and re-termination, or swap the adapter at the ONT. [Elektroda, LucekB, post #17660904]
Could a faulty power supply or ONT cause intermittent LOS?
Yes. A marginal power supply or ONT can cause dropouts that look like line issues. Try a different known-good power adapter, then request an ONT swap. This rules out flapping hardware early. [Elektroda, kranzio, post #17660870]
Should I replace the drop fiber inside the apartment?
Replace the indoor drop only after checking active gear and connectors. One technician wrote, "I do not believe that the optical fiber is to blame." If the cable never moves, its bend radius should not change. Focus on ONT, connectors, and provider path first. [Elektroda, dzidek1968, post #17661399]
Does coiling spare fiber behind the TV increase loss?
Yes, if the coil diameter is too small. Maintain a loop diameter of at least 10× the cable diameter, about 30 mm or more for many drops. Tight coils create macrobends and add loss. Increase the loop diameter to reduce attenuation. [TIA‑568.3‑D]
How can I view optical power levels on my Huawei ONT?
Log in to the ONT web interface and check Optical Information or similar status. Huawei ONTs display Rx optical power and link status. Record values when the link is up and when LOS occurs. Share the data with support. [Huawei HG8245H User Manual]
Are "servers" to blame when LOS flashes?
No. LOS is a physical optical-layer alarm, independent of application servers. PON indicates GPON registration with the OLT. When LOS blinks, the ONT cannot see light from the network. That is outside any IP server’s control. [Huawei HG8245H User Manual]
How long should service take to return after a reboot or outage?
Expect 2 to 3 minutes for an ONT to boot and re-register. During recovery, LOS should clear and PON should turn solid. If registration takes much longer, report it and request upstream checks. [Huawei HG8245H User Manual]
What should I tell support to accelerate a fix?
Provide timestamps, LOS/PON LED states, and any optical power readings. Ask for an ONT swap and an OLT port or splitter check. As one pro said, "these types of faults are the most nasty," so evidence helps escalation. [Elektroda, dzidek1968, post #17660953]
Can the bending radius change over time without touching the cable?
If the cable is static, the bend radius normally remains constant. Thermal movement is minor indoors. As an installer wrote, the "bending radius doesn't change over time." Look at connectors, splices, and active gear instead. [Elektroda, dzidek1968, post #17660890]
Can dirty connectors alone trigger LOS?
Yes. Contaminated SC/APC faces can add several dB of loss and cause dropouts. Industry guidance notes up to 80% of fiber issues come from dirty connectors. Clean before reseating, using proper tools and procedures. [FOA Guide to Cleaning Fiber Optic Connectors]
