Lenovo G700 - After using Avast Cleanup, the Internet disconnects every now and
d69d 4098 4
  • #1 16946775
    d69d
    Rate: 9
    Hello, a few weeks ago I installed Avast Cleanup premium in the test version. I did everything, etc., but from that moment on, I get damned because every now and then the Internet hangs up. I uninstalled it because it is not worth the price but I have the problem. On average, every half hour I lose my connection when I don't use the Internet anymore and when the computer turns off. What could have changed?
  • #2 16946797
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    If you have restore points, restore them, and for the future do not mindlessly use such programs.
  • #3 16946832
    d69d
    Rate: 9
    Great answer. It is good that you did not write that I would not touch the computer.
  • #4 16947143
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    What question does this answer. You haven't provided your system, how you connect to the internet. You used the program, you did something in it and now you have to guess what the program has changed or removed. Maybe it will be better if you use your last advice.
    You have points to restore, you don't have to check the power plan settings, wifi card settings (if you connect so) in the device manager (Energy management).
  • #5 16948415
    d69d
    Rate: 9
    then now I will give you advice in the field in which I am a specialist. if something ever happens to you and you get to the hospital, do not bother the staff, do not ask for help, but next time do not use your body thoughtlessly. or going a step further, die immediately if you can't use life without any problems.
    I understand that you were a computer master as soon as you jumped out of your mother's womb, unfortunately I didn't have that and I often learn from mistakes.
    for advice like "don't use mindlessly", "don't use" you should get the level of not only a specialist, but even a genius.
    I made it. without restoring points.
