LG 55UJ6307 TV: Connect Microlab Solo7C External Speakers via RCA Input & Optical Adapter
Gumowka111 31908 9
How can I connect Microlab Solo7C external speakers with RCA input to an LG 55UJ6307 TV?
You cannot connect those speakers directly with a plain RCA-RCA cable, because the TV’s RCA jack is an audio input used with Composite/Component IN, not an audio output [#17067394][#17067565] The Microlab Solo7C is an active speaker set, so it needs a line-level audio source rather than direct speaker output [#17067406] Use the TV’s optical audio output and an optical-to-RCA DAC/converter, such as a FiiO3, then feed its RCA output into the speakers [#17067406][#17068354]
  • #1 17067332
    Gumowka111
    I have LG 55UJ6307 TV and I want to connect external speakers in which I have only RCA input. I have an RCA cable - jack, but my TV has no headphones.
    I connected the RCA-RCA cable as in the picture:
    Unfortunately, nothing goes, I even looked at the TV sound settings and nothing, I still have HDMI input on the side and nothing more.
    Someone will advise you how to connect the speakers ??
    The speakers have a Microlab Solo7C.
    I heard something about the fact that he can buy a converter from an optical jack on the RCA
    But I do not know what's going on with it
  • #2 17067384
    RebellionArts
    Help: 56
    Rate: 150
    This output is intended for an amplifier, it will not work on ordinary speakers without the amplifier's supervision.
  • #3 17067394
    pietia86
    Help: 69
    Rate: 91
    And in my opinion it is Audio input to the TV, not output. It works together with the Composite IN input
  • #4 17067406
    Polon_us
    Help: 1184
    Rate: 1280
    A good friend heard, please buy a DAC converter such as FIIo3
    Oh, does your friend rave?
    What way out?
    Microlab Solo7C are an active set, by the way.
  • #5 17067449
    RebellionArts
    Help: 56
    Rate: 150
    A colleague does not rave just trying to help
    TV has already played on other speakers?
  • #6 17067524
    Polon_us
    Help: 1184
    Rate: 1280
    Yeah ...
    As much as it is input, the Component video signal also uses this input.
  • #8 17068354
  • #9 17354643
    marthunia
    Rate: 21
    Welcome,
    I will connect to this topic. I tried to connect the TV to the tower with cinch cinch. It did not work and honestly I have no idea why it did not work. Can you help?
  • #10 17355009
    Polon_us
    Help: 1184
    Rate: 1280
    @marthunia - please create your own topic.
    And add data / photos of your equipment
The discussion revolves around connecting Microlab Solo7C external speakers to an LG 55UJ6307 TV using RCA inputs. The user initially attempted to connect the speakers via an RCA-RCA cable but encountered issues, as the TV's RCA input is an audio input rather than an output. Responses suggest that the speakers are active and require an amplifier. A recommendation was made to use a DAC (Digital-to-Analog Converter) like the FiiO3 to facilitate the connection. Additionally, users pointed out the importance of checking the TV's manual for proper connection guidelines.
