ELM Diagnostic Interface: Clarifying the Difference Between OBD2 and OBDII
Krzys55 21915 9
What is the difference between OBD2 and OBDII?
OBD2 and OBDII are the same standard; the only difference is the notation or spelling, with “II” written as Roman numerals [#16950992] [#16950997] Both do the same thing, so there is no technical difference between them [#16951010] The forum also notes that OBD2/OBDII is not the same as EOBD or OBD [#16951103]
  • #1 16950852
    Krzys55
    Help: 89
    Rate: 303
    Hello to all forum members. I recently purchased the ELM diagnostic interface in which the instructions are written: "do not confuse OBD2 with OBDII". What is the difference between them? Thanks for the answer.
  • #2 16950992
    MobilTruck
    Help: 139
    Rate: 965
    Krzys55 wrote:
    OBD2 with OBDII. "What is the difference between them
    In spelling.
  • #3 16950997
    Cobrat
    Help: 35
    Rate: 502
    As above, the Roman and Arabic numerals. I have not seen such a cheap grip for a long time ... Unless the error in printing :P
  • #4 16951010
    kkknc
    Help: 1916
    Rate: 6713
    Both do the same. But you paid more. ;)
  • #5 16951029
    Krzys55
    Help: 89
    Rate: 303
    So they wrote it for a reason?
  • #6 16951079
    kkknc
    Help: 1916
    Rate: 6713
    The reason was cash ...... You made it.
  • #7 16951103
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    In this case, only spelling.
    But OBD2 / OBDII is not equal to EOBD and is not equal to OBD.
  • #10 16951406
    Krzys55
    Help: 89
    Rate: 303
    Ok. Thanks for explaining
The discussion centers around the ELM diagnostic interface and the distinction between OBD2 and OBDII. Participants humorously note that the difference is primarily in spelling, referring to the use of Roman versus Arabic numerals. They suggest that both terms refer to the same diagnostic protocols, implying that the differentiation may be a marketing tactic. Additionally, it is clarified that OBD2 and OBDII are not equivalent to EOBD or OBD. A link to further information on OBD is provided for additional context.
