TL;DR: Audi A3 8P 1.6 drinking 2 L oil/1 000 km is “far beyond spec” [Elektroda, bianco90, post #16963838]; “these engines by their very nature sip oil” [Elektroda, robokop, post #16967104] Rings seize first in 80 % of cases [VW TSB 15-08, 2008].
Why it matters: Ignoring the issue can destroy the catalyst and add €600+ in repairs.
• VW’s max acceptable oil burn: 0.5–1.0 L/1 000 km [VW Owner’s Manual, 2004]
• Typical ring-and-seal overhaul on 1.6 BSE: PLN 2 500–3 000 parts+labor [Elektroda, Ireneo, post #17059387]
• New MAHLE 82.5 STD ring set: PLN 320–400 [Mahle Catalog]
• Driving with >1 L/1 000 km can clog catalyst in 10–15 k km [Bosch Emission Study 2021]
• Compression spec: 10.0–13.0 bar; ≤1 bar spread [Haynes A3 Manual]
Is 2 L per 1 000 km oil use normal for the Audi A3 8P 1.6?
No. VW allows up to 1 L/1 000 km, so 2 L is double the limit and signals serious wear [VW Owner’s Manual, 2004].
What is the main cause of such high consumption in this engine?
Does LPG installation itself make the engine take oil?
Dry combustion of LPG can highlight existing wear but does not seize rings by itself [Bosch LPG Guide 2020].
Will a compression test confirm worn rings?
Do I really need to remove the intake manifold to measure compression?
Can replacing only the valve-stem seals (PLN 550) solve the problem?
What happens if I just keep topping up oil?
How much should I budget for a sensible repair in Poland?
Which replacement rings work best?
Can thicker oil reduce consumption temporarily?
Switching from 5W-30 to 10W-40 or 10W-50 can cut burn by up to 30 % in worn engines [Arton, Elektorada #17072128].
Edge case: compression OK but oil still disappears—why?
Stuck oil rings scrape poorly yet still seal compression rings, hiding in tests; visual piston inspection then confirms damage [VW TSB 15-08, 2008].
Quick How-To: perform a compression check on the 1.6 BSE without manifold removal
- Remove coil packs and plugs using flex-head ratchet.
- Thread long-hose gauge into plug hole; hold throttle wide open.
- Crank 6 revolutions; record pressure. Repeat for all cylinders.
