[Solved] Skoda Octavia II 1.6 - Error P2626 after replacing the lambda sensor
invisibleman 22104 3
  • #1 16968077
    invisibleman
    Help: 40
    Rate: 154
    Car skoda Octavia II 1.6 BSE (Siemens controller) with gas. After replacing the lambda probe ahead of the catalyst (broadband), error P2626 appears - the lambda probe positive current correction circuit / interrupted. The error can only be triggered by braking the engine - otherwise you can drive and the error does not appear. Has anyone encountered such a case in the VW group? I don't know if I came across a factory damaged probe or the problem is somewhere else, e.g. adaptation after replacement is necessary.
    New probe from NTK.
  • #2 16969730
    grzecho3223
    Help: 27
    Rate: 35
    I bought a new one and it was lame after a trip to scrap metal, I bought a drug and has been playing for 4 months
  • #3 17006503
    invisibleman
    Help: 40
    Rate: 154
    2 new probes (replacement) generated an identical error. After replacing it with a used original, everything works fine.
  • #4 17006507
    invisibleman
    Help: 40
    Rate: 154
    Replacing the probe with the original used solves the problem.
