Canon G3400 - The computer cannot search for the printer via WI-FI
Venime 5772 7
  • #1 16973198
    Venime
    Hello. I have a little problem. After restarting the router due to lack of power, I tried to connect to the printer. The printer didn't respond so I connected the printer to the phone, everything was ok. I entered the address of the printer and the meatball. The computer is not looking for her what to do
    Computer specifications
    HP Pavilion g series model
    Intel Pentium 2.10 GHz processor 2x
    Ram 4 gb
    Ps. I was able to connect the printer with the pc before the reset
  • #2 16976390
    piotr147
    Help: 12
    The printer goes into sleep mode and then it cannot connect to it.
    Install the original driver from the manufacturer.
  • #3 16976910
    Venime
    I understand. But I was installing new printer headsets :D
  • #4 16976959
    piotr147
    Help: 12
    The IP has probably changed.
    Search for it by searching for network devices?
  • #5 16979006
    Venime
    I did it how many times after restarting the router, nothing helped, it still does not search for it
    piotr147
    Help: 12
    Maybe the network card has broken.
  • #7 16979428
    Venime
    The printer has a week and the computer probably not because I could not use the Internet
    Reconfigure printer connection using WPS quick setup
    #8 16980375
The user is experiencing connectivity issues with their Canon G3400 printer after a router restart. The printer is not being detected by the HP Pavilion g series computer, although it connects successfully to a phone. Suggestions from the forum include checking if the printer has gone into sleep mode, verifying if the printer's IP address has changed, and reconfiguring the printer's connection to the router using WPS. It is also advised to delete the existing printer setup on the computer and search for new devices. Potential hardware issues, such as a broken network card, were also mentioned.
