How to Disassemble and Replace FAAC 414 Tube Arm Seal: Preventing Water & Frost Issues
marcinoser 18144 20
How do I disassemble a FAAC 414 gate actuator to replace the tube-arm seal and keep water out of the screw mechanism?
Detach the arm from the motor, then drill out the crimps on the actuator head and cut about 5 mm around the neck so the piston/tube assembly can be slid out to reach the seal [#16977108][#16983087] If you need more access, the lead screw can be disconnected from the drive mechanism by removing the pin secured at both ends, after which the draw tube with the tube screw can slide out [#16977108] The reported replacement seal size was 42x32x7, and an identical 32x42x7/10 ZZ scraper ring was also found; about 3 mm of the sleeve below the seal had to be ground away so it would seat deeply enough [#16983087][#16992354] The head is cast, so it cannot be riveted back in the usual way; one M5 screw was used instead, and a heat-shrink sleeve over the assembly hides the cuts and fasteners [#16983087][#16992354] The factory grease had mixed with water and froze, so use clean low-temperature grease rather than grease that hardens in frost [#16992354][#16983718]
  • #1 16975021
    marcinoser
    Rate: 26
    I have faac 414 gate automats. The simmering in the tube arm has solidified and it releases water to the screw mechanism, which causes problems in deeper frosts. Does anyone know to disassemble the piston and housing so that they can remove the seal?
    Added after 3 [hours] 11 [minutes]:
    I don't know if you are allowed to answer yourself, but I have solved the problem and I want to share it with those who may need it in the future.
    Disassemble the horn arm from the motor body and then remove the simmering sealing the stainless piston. First the rubber and then the metal ring, I don't know if they are separate parts or if it was originally one simmering, but it fell apart from old age. After removing the ring, vigorously tug both parts of the tube several times to knock out the Teflon sleeve that is under the simmer. Voila!
  • #2 16976654
    kotbury
    Gantry automation specialist
    Help: 2104
    Rate: 3639
    Just a question - you pick out the old simmering destructively, knock out the ring and stay on the screw, but can the new simmering be squeezed through the head of the slider? it is much wider than the chrome slider tube ....
  • #3 16976832
    marcinoser
    Rate: 26
    Well, or you should pull out the Teflon thread nut. Can it be done somehow?
  • #4 16977108
    kotbury
    Help: 2104
    Rate: 3639
    It cannot be made as a whole - it is cast as a whole within the slider tube - the tube is drilled at the end and the nylon of the nut is anchored in them. I have once dealt with an actuator with a nut torn off the pipe (car shot) and tried to re-anchor it but the bonding is not done - the plastic is slippery like soap. One could try to screw with screws with countersunk heads countersunk into the wall of the pipe, but the nut has a small wall thickness, the screws would have to be very short and I do not give such fastening too much chance.
    We ended up replacing it under the warranty (somehow they accepted the warranty).
    However, it is possible to disconnect the lead screw from the drive mechanism - just remove the pin secured at the ends with pins (it is visible after sliding the actuator cover tube on a slightly extended slider). After that, you can slide the draw tube together with the tube screw.
  • #5 16977124
    marcinoser
    Rate: 26
    Can you expand the last paragraph? I have unhooked the horn arm from the motor, but that's not enough to replace the sealant. I also wonder if it could be sealed in another way, PLN 300 for one piece of this screw is a lot ...: /
  • #6 16977208
    kotbury
    Help: 2104
    Rate: 3639
    I just took a look (I have one piece unfolded) - and I only have rather destructive ideas - or drill the piston creases on the lead screw head, remove the head and slide the piston backwards (then shoot with bolts or rivets during assembly) or roll a nylon nut to such a diameter, so that the simmering passes through it, then the gap between the tube and the nut should be supplemented with a sleeve (made, for example, of brass or bronze sheet or a tube - by mounting it with recessed screws).
  • #7 16977217
    marcinoser
    Rate: 26
    I also had an idea for turning the nut sleeve. Do you know what the door catch looks like inside, i.e. if it drills the crease, does it rivet it into one whole?
    kotbury
    Help: 2104
    Rate: 3639
    Unfortunately, I don't know (for me these elements and sealants were OK, I only replaced the broken drive head) - but you can try to drill through - if the mount is still in some way (such as hidden welds, glue) then at most you will burn one of the demolition methods, if you do loosens and lets you slide off - you can easily rivet it by preparing the conical sockets in the tube for the heads of the rivets and grinding the heads after riveting them flush with the tube, and if the actuator does not retract to the end and the heads do not run up to the simmering - install ordinary screws.
    And if you did - let the posterity know if it was successful.
  • #9 16977246
    marcinoser
    Rate: 26
    I can afford it, I have a few inches of "dead". In a week I will do it and let me know if it can be done, today rest :)
  • #10 16983087
    marcinoser
    Rate: 26
    We managed to break it. You have to drill the crimps quite deeply, and cut around the head, about 5 mm, so as to avoid crimping around the neck. Now I have access to everything in the tube, I have to order a simmering, 42x32x7. It cannot be riveted because the head is a cast, so the M6 screw will go through. I plan to stretch the heat-shrinkable sleeve over the whole thing so that the screws and cuts are not visible.
    Edit: Instead of the classic simmer, I found an identical 32x42x7 / 10 ZZ scraper ring on a popular auction site.
  • #11 16983459
    kotbury
    Help: 2104
    Rate: 3639
    Oh respect ...
    Now you know how to bite this frog.
    And it will be useful because the actuators are getting older ...
    As for riveting - if the head lasts without cracking, pressing the recesses with pins and turning the collar around will probably withstand the delicate arching of the rivet head, moreover, in most cases you will only need to rivet the hole further from the tip, the closer hole can actually be fixed with a screw (worse if someone used the maximum insertion as a stop - it happens).
  • #12 16983531
    alster1
    CCTV and Stationary Alarms specialist
    Help: 352
    Rate: 540
    Thanks for the description and photos, my actuators have been in use for about 12 years and there is not much left of sealants. Inspired by this topic, I start the exchange in the spring.
  • #13 16983639
    marcinoser
    Rate: 26
    When it comes to riveting, I thought it was a sleeve, and it would be a tear-off one, but it completely gives up riveting in favor of screws. The head is aluminum, so if you had a press and a punch and a prism for fixing, I think you could do such a pressing. However, it must be taken into account that after this treatment, the working length decreases by about 5 mm, and the aesthetic values slightly decrease. ;) Generally, having parts and knowing what and how in order, you can repair the set in 4-5 hours. The cost is almost symbolic compared to the new tubes - by replacing scrapers and chewed cables, I will close to PLN 40.
    I am still wondering about the lubricant, whether to leave what is (some red) or replace it with ŁT?
  • #14 16983718
    kotbury
    Help: 2104
    Rate: 3639
    Not Łt - it hardens in frost (Poland is not Italy, such grease only for gears) - I would use low-temperature grease for the screw - aluminum green or lithium white - maybe Lubinar central lubricant or similar grease ...
    marcinoser
    Rate: 26
    Time for a summary:
    After initial disassembly problems, assembly was fairly quick and without major problems. However, I decided to use simmerings instead of the scrapers, it seems to me that they will be tighter, the scraper, in my opinion, does not stick well and its rubber is quite stiff.
    In order to install the simmer / scraper properly, you need to grind about 3mm of the sleeve which is located just below it. It is possible that the original was 5mm thick, in addition, the edge is chipped during disassembly, so I sanded the sleeve to get it in deep enough.
    As for the grease ... The factory grease was completely mixed with water, so I'm not surprised it froze easily. I did not get aluminum grease in the area, so I used ŁT, I assumed that fresh and clean ŁT was better than the factory one with half water. I compared both in the freezer with the rest, I had no doubts which way to choose ... :)
    I used one M5 screw to fasten the head, I think you don't need more. The idea with a heat-shrinkable T-shirt hit the jackpot, it looks very aesthetic, the fi40 T-shirt is sufficient.
    Replacing the motor cable is unfortunately not as easy as I thought, because the cables are woven into the stator and you need to solder about 5 cm from it. Fortunately, there is enough space in the body to fit the cables after soldering.
    Summarizing the costs:
    Simmerings - 2 x PLN 7.5 = PLN 15
    Heat-shrinkable tubing - PLN 5
    4x1 cable that I had to replace - PLN 4
    New seger rings - PLN 2
    Most of us have grease in the workshop, it comes in quite a lot
    Shipments about PLN 15
    which gives PLN 41. (new tubes 2 x 270 PLN = 540 PLN) - there is a difference :D
    Below photos:
     How to Disassemble and Replace FAAC 414 Tube Arm Seal: Preventing Water & Frost Issues  How to Disassemble and Replace FAAC 414 Tube Arm Seal: Preventing Water & Frost Issues  How to Disassemble and Replace FAAC 414 Tube Arm Seal: Preventing Water & Frost Issues
  • #16 16992889
    kotbury
    Help: 2104
    Rate: 3639
    Well, this is a complete tutorial on changing sealants. Very good. Respect for willingness and consistency, I will not say that I will not use it ..
    I would like to add that there are simmerings with an additional scraper flange (or actually protecting - I have seen them on the output of half axles in cars) - they look like a combination of a scraper with simmering - I will try to track them (although it may not be such a dimension - these are probably dedicated automotive products)
  • #17 18365088
    Ricorro
    Help: 5
    Rate: 117
    Dear users, I just recently put the 414 on a 100mmx100mm post and it works perfectly. I have a question that bothers me. Namely, what do you do if there is ice on the tubes and turning on the actuator causes this ice to degrade the sealants, because they have to pick it up, if nothing happens to them. All in all, you could make covers for the top of the tube that would work. The question is whether it makes sense to do this. Write me your feelings about this item. Looking at the performance, is it probably the weakest element of this actuator?
  • #18 18365139
    marcinoser
    Rate: 26
    It is probably best to prevent icing so as not to scrape the chrome. Replacing the seals requires scraping the entire actuator, but the sealant itself is cheap. In my opinion, these sealants are wearing out time and UV, much more so than ice on a tube.
  • #19 18365267
    Ricorro
    Help: 5
    Rate: 117
    Already measured
    The diameter of the thicker pipe than the actuator is 45mm
    The widest diameter of the extendable arm when fixing the gate is 43mm (the handle at its widest point - then connected with the extendable tube)
    Otherwise I am already looking for a black corrugated tube with UV 55/46
    Or a larger equivalent, minimum length 50, preferably 60 cm for one arm, will look good and fulfill its function. I will mark the inspection holes tightened near the connection with the gate, draining any water at the bottom.
    If I find black fluted or smooth with UV, the look will be great.
  • #20 19571740
    RobertKiszlo
    Thanks for the tutorial,
    servomotors repaired, loose simmering replaced.
    I had a problem with drilling the pressed elements, only a visit to a friendly workshop helped, and even one cutter gave up. Hard material.
    It is not necessary to remove the entire cylinders, just detach the arms from the engine.
  • Simple arm removal and gearbox disassembly steps
    #21 19571807
    kotbury
    Help: 2104
    Rate: 3639
    There’s no need to remove the entire actuators; simply unclip the arms from the motor
    It’s as plain as day. Unscrew the clamp, unclip the pin on the drive shaft, and the tube is in your hand.
    PS. Gearbox dismantling. I got two of them for scrap price. They came apart and the retaining rings fell out from inside the gearbox. All I had to do was pull out the plastic washers under the clamp, remove the retaining ring (you’ll need pliers with very long jaws), and the bearing comes out with your fingers. You can check the condition of the clutch whilst you’re at it. Further dismantling, for example to replace the end bearing or the main sprocket, is a bit more complicated. You need to remove the stator, the rotor and its bearing; then, using a bent rod, push the clutch shaft out through the rotor borehole; you can then remove the complete gearbox from the housing, along with the end bearing.
The discussion revolves around the disassembly and replacement of the FAAC 414 tube arm seal to prevent water and frost issues. Users share their experiences with solidified seals causing water ingress into the screw mechanism, leading to operational problems in cold weather. The main solution involves disassembling the horn arm from the motor, removing the old seal, and replacing it with a new one. Various methods for accessing the internal components are discussed, including drilling and using screws for reassembly. Users also explore alternative sealing options and lubricants suitable for low temperatures. The conversation highlights the importance of proper maintenance to extend the lifespan of the actuator.
TL;DR: DIY seal swap on FAAC 414 can cut costs by ~92% (PLN 41 vs PLN 540). "which gives PLN 41 … there is a difference". [Elektroda, marcinoser, post #16992354] Why it matters: This guide helps homeowners stop water ingress and frost lockups without buying new actuators. It’s for FAAC 414 owners facing leaking or frozen tube arms.
How do I replace the FAAC 414 tube arm seal step‑by‑step?
  1. Drill the piston head crimps, then cut around ~5 mm to free the head.
  2. Extract old seal, sand ~3 mm from the sleeve below, and press a 32×42×7 simmer.
  3. Reassemble with an M5 screw, regrease, add heat‑shrink for finish. [Elektroda, marcinoser, post #16992354]
What seal size fits the FAAC 414 actuator?
Users successfully fitted a 32×42×7 mm rotary shaft seal. An alternative scraper ring marked 32×42×7/10 ZZ also fits the bore. [Elektroda, marcinoser, post #16983087]
Can I avoid removing the entire actuator from the gate?
Yes. Detach the arm from the motor, undo the bolt and the seger, and slide the tube off for bench work. [Elektroda, kotbury, post #19571807]
How do I deal with the cast aluminum head and factory crimps?
Drill the deep crimps and cut roughly 5 mm around the head to clear the neck. Reattach using a through‑bolt (M6 noted). [Elektroda, marcinoser, post #16983087]
What grease should I use for the lead screw in freezing weather?
Use low‑temperature aluminum or lithium white grease on the screw. As one expert says, "Not ŁT – it hardens in frost." [Elektroda, kotbury, post #16983718]
Which seals keep water out better: simmerings or scrapers?
A user found simmerings seal tighter than the stiff scraper used, improving water resistance and frost reliability after reassembly. [Elektroda, marcinoser, post #16992354]
Will ice on the chrome tubes destroy the seals?
Focus on preventing icing to protect the chrome. Wear comes more from time and UV than occasional ice on tubes. [Elektroda, marcinoser, post #18365139]
What tools and materials do I need for the repair?
You’ll need a drill, sanding tools, new seger rings, a 32×42×7 seal, grease, an M5 screw, soldering gear, and heat‑shrink. [Elektroda, marcinoser, post #16992354]
What’s a risky edge case with the FAAC 414’s internals?
The nylon drive nut is cast‑anchored in the slider tube. Re‑anchoring it reliably after removal is not feasible. [Elektroda, kotbury, post #16977108]
How long does the repair take and how much can I save?
Expect 4–5 hours of work and about PLN 41 in parts, versus ~PLN 540 for new tubes, a ~92% saving. [Elektroda, marcinoser, post #16992354]
Can I use an aftermarket scraper instead of a standard seal?
Yes. A 32×42×7/10 ZZ scraper ring was sourced and installed successfully as an alternative to a classic 32×42×7 seal. [Elektroda, marcinoser, post #16983087]
How do I improve appearance and protection after drilling the head?
Slide on a Ø40 heat‑shrink sleeve over the repaired section. It hides cuts and screws and adds splash protection. [Elektroda, marcinoser, post #16992354]
Is there a combo seal with an added dust lip for extra protection?
Yes, seals with an additional scraper flange exist. Sizing must match; automotive styles may not in this dimension. [Elektroda, kotbury, post #16992889]
Do I need to replace motor cables, and what’s tricky about it?
Cables weave into the stator. Solder about 5 cm from it and route joints inside the body with care. [Elektroda, marcinoser, post #16992354]
