Best 4G Router for nju mobile 40GB Plan: Dual-Band (2.4GHz & 5GHz) Options & SIM Card PIN Info
wertiko7 6588 16
Which 4G router should I buy for the nju mobile 40GB plan if I want good range and simultaneous 2.4/5 GHz Wi‑Fi, and does the SIM card need a PIN?
The thread’s only concrete router recommendation is the Huawei B525; it is suggested as the LTE router to buy, and the advice is to check your exact local coverage and signal before choosing it [#16977761][#16977826][#16977846] For the SIM, nju cards may have a PIN, but new nju online SIMs are reportedly able to have PIN verification disabled [#16977736]
  • #1 16977488
    wertiko7
    Rate: 100
    Soon I will order an offer from nju mobile internet 40gb for 29 zlotys.
    And I don't know what 4g router to buy for this offer.
    I care about good without emergency and with good range and that the router was able to transmit both 2.4 and 5 gh at the same time.
    Added after 32 [minutes]:
    And do you know if the sim card has a pin code, because how is it used in the router.
  • #3 16977697
    wertiko7
    Rate: 100
    Nju, because it comes out the cheapest. In addition, I have a prepaid orange telephone and mobile internet works fairly well in my place of residence.
    And after 6 months it will be 80gb for 29 PLN.
    And I'm looking for some good 4G router, but somewhere on the net I read that these cards have pin codes.
  • #4 16977736
    matek451
    Help: 4352
    Rate: 5810
    For PLN 29, T-Mobile has an unlimited internet connection. The subscription is 49 PLN / month, DL up to 20Mb / saw subscription 29 PLN is an unlimited internet fee +20 PLN installment for B525 or router with LTE-A worth about 400 PLN. The initial payment for B525 is 49 PLN. Subscription for DL up to 60Mb / s and no limit is PLN 50 / month (PLN 39 +20 for B525). And nju 40GB is not cheap at all, because in Play without a contract a minimum of 100GB for LTE you can have for 5/15 PLN per month. Own router. If Play has LTE coverage with you, the offer without a contract is much better than nju to which you still need to buy a router. have you tested Orange, what speeds do you achieve on your phone, what signal parameters do you have, what LTE band do you use in Orange? What is the location? Nju cards may have a PIN but not necessarily, new cards in nju online supposedly have the option to disable PIN verification.
  • #5 16977747
    wertiko7
    Rate: 100
    You can link to this internet with no limit in T-mobile because I searched and found nothing. There is a data limit everywhere.
  • #7 16977768
    wertiko7
    Rate: 100
    And you wrote that way earlier = For PLN 29, T-Mobile has an internet with no data limit.
    And this offer is more expensive.
  • #8 16977790
    matek451
    Help: 4352
    Rate: 5810
    Can't you read comprehension? Would you like for 29 PLN / month unlimited internet and with B525 hardware or LTE-A router worth over 400 PLN? The subscription consists of a fee for the Internet PLN 29 / month and PLN 20 installment for the router, in total it is PLN 49 / month. Http: //www.t-mobile.pl/r/repo1/tm/documents/doc_00008/D_007_0015993. pdf On the free market for such a router, if you wanted to buy it for nju, you would spend PLN 350-400 on Allegro, OLX. There is no such offer in Orange. Pre-paid is the cheapest in Play, where, as I wrote on LTE, a minimum of 100GB with maximum speed and then a possible funnel of 2Mb / s is up to PLN 5 / month. The cheapest LTE router with it is around PLN 150.
  • #9 16977802
    wertiko7
    Rate: 100
    Ok thanks for the info.
    And can this Huawei B529 router be connected to another router to extend the range, for example?
    I have a router not used Netgear Nighthawk X4S R7800 and can it be connected to this b529?
  • #10 16977820
    matek451
    Help: 4352
    Rate: 5810
    And did I write about the B529 somewhere? You ask questions yourself, but you didn't answer any, I asked about some things for a reason.
  • #12 16977826
    matek451
    Help: 4352
    Rate: 5810
    What is not interested in the link, I recommended B525 to this offer http://www.t-mobile.pl/tel PHONES-i-urzadzenia/modemy-i-routery/huawei-b525s/HU-M-T320.phtml? collection = AT-M-T050: AT-M-T060: HU-M-T120: HU-M-T260 :D KM-T040: HU-M-T250: prod2940001: HU-M-T230: HU-M-T320: HU-M-T330 & returnURL = / Mobile-and-device / modem-and-router / cat10022.chtml? Catid = cat10022
  • #13 16977834
    wertiko7
    Rate: 100
    Ok and then when I click it comes out that the unlimited subscription is 79 PLN. Is it as cheap as you wrote ???
  • #14 16977846
    matek451
    Help: 4352
    Rate: 5810
    You got the link to the home internet offer earlier, here you have a choice of equipment in this offer http://www.t-mobile.pl/tel PHONES-i-urzadzenia/modemy-i-routery/cat10022.chtml. All this, however, theorizing, lack of location does not allow you to comment on what the T-Mobile range looks like in it, how far and what NetWorks BTSs are nearby, in what bands they work, what signal parameters can be expected and whether an antenna will be needed external and what?
  • #15 16977853
    wertiko7
    Rate: 100
    Location Szczecin.
  • #17 17014239
    Starkes
    Level 19  
    Help: 5
    Rate: 43
    After all, Matek asks for the EXACT ADDRESS, street, house number or GPS position.
    How can you check the range without it (distances to individual BTSs?
The discussion revolves around selecting a suitable 4G router for the nju mobile 40GB plan priced at 29 PLN. The user seeks a dual-band router (2.4GHz & 5GHz) with good range and performance. Various options are suggested, including the Huawei B525 and B529 routers, with considerations about their compatibility and performance in specific locations, particularly Szczecin. The conversation also touches on the availability of SIM card PIN codes for nju mobile, with some users indicating that new cards may allow disabling the PIN requirement. Comparisons are made with other providers like T-Mobile and Play, highlighting their offers and router options.
TL;DR: Start with Huawei B525 for a stable 4G setup; T‑Mobile offers a 14‑day test, and B525 "aggregates two LTE bands." Check local LTE1800/2600/800 coverage before buying. [Elektroda, matek451, post #16977761]
Why it matters: Picking hardware and a plan without checking nearby bands, speeds, and SIM PIN rules can waste money and time.
Who this is for: People comparing nju mobile’s 40 GB plan with alternatives and choosing a dual‑band 4G/LTE router for home use.
What’s the best 4G router pick for nju mobile’s 40 GB plan with dual‑band Wi‑Fi?
From the thread, Huawei B525 is the recommended baseline. It’s noted for LTE‑A with two‑band aggregation and HManager support. Choose it if your location shows usable LTE1800/2600/800, then fine‑tune bands with HManager. [Elektroda, matek451, post #16977761]
Is nju 40 GB/29 PLN the best value, or are there alternatives?
An expert highlighted T‑Mobile’s unlimited offer (29 PLN service + 20 PLN for B525) and Play prepaid with at least 100 GB on LTE before a 2 Mb/s throttle. Validate coverage first, but these can beat nju on heavy use. [Elektroda, matek451, post #16977736]
Does the nju SIM have a PIN, and will a PIN block my router?
Yes, a nju SIM may ship with a PIN. New online cards reportedly let you disable PIN verification. If the PIN stays active, a router can fail to register until you remove or enter it. "Disable PIN verification" if your router lacks a PIN prompt. [Elektroda, matek451, post #16977736]
What speeds were cited for T‑Mobile’s home internet tiers?
The thread lists a plan with DL up to 20 Mb/s and another up to 60 Mb/s, with the 60 Mb/s tier quoted at 50 PLN/month. These are plan caps, not guaranteed throughput. [Elektroda, matek451, post #16977736]
Which LTE bands should I target for T‑Mobile in Poland?
Plan around LTE1800 (NetWorks), LTE2600, and LTE800. A router like the B525 can aggregate two of these for better throughput and stability. Align your antenna and band‑lock accordingly. [Elektroda, matek451, post #16977761]
How do I test which operator works best at my address?
Run structured tests at home. The expert asked for phone speed checks, signal parameters, and the LTE band in use before committing. Then select hardware and, if needed, an external antenna based on results. [Elektroda, matek451, post #16977736]
3‑step how‑to: quick coverage test before buying
  1. Insert each operator’s SIM in your phone and note LTE band, RSRP/RSRQ, and speed at your window.
  2. Repeat at peak (evening) and off‑peak, logging results per room.
  3. Pick the operator and lock bands in the router that matched best; add an antenna if signals were weak. [Elektroda, matek451, post #16977736]
Can I trial T‑Mobile home internet risk‑free?
Yes. The offer referenced includes a 14‑day testing period, so you can validate signal quality and speeds before deciding. "For testing 14 days." [Elektroda, matek451, post #16977761]
Is Huawei B529 better than B525 for this offer?
The adviser explicitly did not recommend B529 in this context and pointed you back to B525 details. Focus stayed on B525 plus coverage testing for fit. [Elektroda, matek451, post #16977826]
Can I connect my Netgear Nighthawk X4S R7800 to the LTE router to extend range?
The thread did not provide configuration guidance for pairing the R7800 with an LTE router. The adviser emphasized that accurate recommendations depend on exact location and coverage diagnostics first. [Elektroda, matek451, post #16977846]
Why do helpers ask for my exact address or GPS point?
They use it to measure distance and line‑of‑sight to specific BTS sites and pick the right bands and antennas. "How can you check the range without it?" [Elektroda, Starkes, post #17014239]
I said I’m in Szczecin. Isn’t city‑level info enough?
No. The expert called out that city‑only info isn’t actionable. Exact street or GPS is needed to assess nearby BTS and signal quality accurately. [Elektroda, matek451, post #16977929]
What is LTE‑A, and why does carrier aggregation help?
In this thread, LTE‑A is referenced as the B525’s ability to aggregate two LTE bands. Aggregation raises effective throughput and stability when multiple bands are available. "Aggregates two LTE bands." [Elektroda, matek451, post #16977761]
What is HManager in this setup?
HManager is mentioned as a tool the B525 works with. Users employ it to control or lock LTE bands on the router during optimization. "B525 works with HManager." [Elektroda, matek451, post #16977761]
