[Solved] Kruger & Matz Street Headphones - Issues with Bluetooth Pairing with Audio Stream Transmitters
gieniapierda 10350 7
  • #1 16987355
    gieniapierda
    Help: 56
    Rate: 130
    Good morning!
    Recently I have Kruger & Matz Street headphones. They do not pair with any audio stream transmitters, or "DO NOT SEE THIS". After that they play correctly on the cable, read MicroSD etc. Is there any correct soft that can be uploaded to them so that this Bluetooth "surprises"? The producer wrote "There may be a problem at the first pairing" but these pairings were bad and nothing.
  • #2 16987719
    aaanteka
    Help: 729
    Rate: 1195
    Do you own a precise model Kruger & Matz Street BT KM0623?
  • #4 16987890
    aaanteka
    Help: 729
    Rate: 1195
    And everything is clear - PLEASE READ THE AUCTION DESCRIPTION ONCE AGAIN:
    " Headphones Kruger & Matz Street BT KM0622 / KM0623 in white or black Sale!!!
    Now for only 79 PLN! (well below the market price of functional handsets - footnote)
    Check, test !!!
    At the auction we offer Kruger & Matz Street Bluetooth headphones. The bluetooth function works on most devices, but is not compatible with all devices. The problem most often occurs at the first pairing. In addition, the headphones are fully functional and functional. After charging, they also work wired, you can also play music from the microSD card.
    The complete set includes: USB cable - micro us, original packaging with case, jack-cable
    We give a 24-MONTH WARRANTY for the complete set EXCEPT BLUETOOTH FUNCTION.
    According to ARTICLE 557 and 558 of the Civil Code, the devices do not have rights under the warranty.
    You can withdraw from the contract within 14 days of receipt of the product !!!
    Please note that you have purchased a defective product.
  • #5 16988300
    gieniapierda
    Help: 56
    Rate: 130
    I know all this ... but, there is no way to uninstall and reinstall the Bluetooth application / software? It seems to me that devices based on Bluetooth communication work on a similar software. The difference in these headphones and the resulting lack of pairing may be due to a different pickup frequency. So something like the radio from abroad once tuned to Polish ukf. And this is what I mean, and the problem will not be solved by quoting the auction description :spoko:
    aaanteka
    Help: 729
    Rate: 1195
    Buddy, you bought a defective product with a damaged function. Noting that the distributor sells headphones at a price of 1/3 of the market price, it should be assumed that this is a damage to the BT module that their service could not handle. And believe me, Lechpol has a group of experienced service workers. Certainly they could upload the right soft and sell a full-fledged product with advantage. Ultimately, it was to work in a relatively new Bluetooth 4.1 standard.
    BT4.1
  • #7 17005399
    gieniapierda
    Help: 56
    Rate: 130
    Repeated use of the above headphones via a mini jack cable on the same device (this time it is a Xiao RedMe phone) caused the device to recognize Kruger & Matz also via BlueTooth. I don't know what to explain but it works and evaporates. I close the topic
  • #8 17005400
    gieniapierda
    Help: 56
    Rate: 130
    As I wrote above :idea:
The discussion revolves around issues with Bluetooth pairing of Kruger & Matz Street headphones, specifically the KM0631 model. The user reports that the headphones do not connect to any audio stream transmitters, although they function correctly when connected via cable or using a MicroSD card. Responses indicate that the Bluetooth functionality may be defective, particularly since the headphones were purchased at a significantly reduced price, suggesting potential damage to the Bluetooth module. One user mentions that repeated use of the headphones via a mini jack cable eventually allowed the device to recognize them via Bluetooth, indicating a possible intermittent connection issue. The conversation highlights the lack of available software updates to resolve Bluetooth pairing problems.
