Genesis X66 Keyboard: Buttons Not Working & Text Issues for Pawel - Troubleshooting Advice
devilanq 33792 38
Why does my Genesis X66 keyboard keep swapping keys, and how can I reset it?
Reset the keyboard profile in the Genesis software to 0; that solved the key-swapping problem in the thread [#17022601] The keyboard has its own built-in controller, so Windows language settings or shortcuts like Alt+Shift/Shift+Ctrl will not fix this symptom [#17024017][#17022907] There is also a snail button next to ESC that changes profiles, so it is worth checking whether that was pressed accidentally [#17024017] If needed, the RX66 manual shows the keyboard’s layout and controls [#17024017]
  • #31 17022030
    devilanq
    I did something wrong or is it that I have to write here; #?
  • Use FreeDOS to verify keyboard input
    #32 17022045
    safbot1st
    Help: 2719
    Rate: 1585
    Press Ctrl + C.
    You can write?
    Are the keys rearranged?
    You failed to create a pen properly, but I have a better idea.
    Change booting again as it was HDD to the top and write F10.
    Start the rufus and don't move anything, press Start.
    FreeDOS will play itself correctly.
    Set boot to USB again.
    You will get a similar text mode on a black background. You will be able to write.
    Check that the keys are working properly.
  • #33 17022050
    devilanq
    I can write here. But the keys are rearranged.
    I'll try it with a rufus now
    But how to get out of it Now?
  • Suggest checking both keyboards on another PC
    #34 17022088
    safbot1st
    Help: 2719
    Rate: 1585
    Reset PC with RESET button and enter BIOS,
    Ok, don't worry, because the problem turned out to be the hardware.
    Did you check this keyboard on another PC?
    You wrote:
    devilanq wrote:
    The keyboard changed the buttons for me so I bought a new one and after two hours it changed again.
    But you haven't checked both keyboards on a different PC?
  • #35 17022601
    devilanq
    I did not check that one because I thought it was the fault of the flooding a week earlier. I checked this one and immediately after it broke, it worked there, now it does not work anywhere. As in this case, it also broke after a few hours.
    Added after 14 [minutes]:
    I solved the problem, it's a shame to write, but it was enough to enter the genesis applications and select to reset the keyboard to 0, but I still do not know what influenced it so much, and what will probably do the same with it, because the settings have not changed again for no reason. ; <
    Thank you for your time, even though I did a terrible stupidity: /
    In addition, I would like to add that I rummaged in their program sooner, but they have set it in this place; restore; that it was hard to notice because I thought it was another unnecessary graphic element of the program. Thank you again.
  • #36 17022778
  • #37 17022907
    pawel1148
    Help: 56
    Rate: 232
    Shift + ctrl or Left alt + shift ?? Check the keyboard language. I do not know where it is. On most systems, this is also in the lower right corner next to the keyboard. Sometimes it is not there, you have to look for it in the control panel.
    I doubt if it is, you can always try it, but I have not seen such a keyboard language yet, where it changes so many letters. i only dealt with qwerty qwertz and azerty.
  • #38 17024017
    safbot1st
    Help: 2719
    Rate: 1585
    @ pawel1148 It's best to guess what the manual is like:
    http://download.impakt.com.pl/genesis-zone/manuals/RX66.pdf
    but I am not surprised that no one found it, since the author does not even know what model he purchased:
    devilanq wrote:
    any advice on how to fix it? genesis x66 keyboard
    I don't know, Paweł, did you notice, but the keyboard has a built-in controller for controlling the keys and it works independently of the operating system, as we proved in the subject.
    Therefore, no language changes etc. control panels will not help here ...
    There is no such shortcut.
    There is a snail button next to ESC and it changes profiles.
    There are no shortcuts in this keyboard that will cause the symptom described.
    There where? The only solution I can think of is a detective movie script:
    -the A keyboard was flooded (the author, unfortunately, kept it a secret until the end, I'm only slightly broken ;) like dr. House)
    -the keyboard by flooding damaged its own profile and saved this profile in the windows registry
    -after buying an identical keyboard B, she read (I do not know by some miracle) the damaged profile of keyboard A and saved it to her memory.
    Who has a different hypothesis?
  • #39 17024423
    devilanq
    But the changes to the keyboard didn't come about a week after the keyboard was thoroughly scammed.
Pawel reported issues with his Genesis X66 keyboard, where the keys were rearranging and not functioning correctly. Initial troubleshooting included checking the operating system (Windows 10) and suggesting tests on another computer or using a live Linux USB to determine if the problem was hardware or software-related. After several attempts to create a bootable USB with Linux, Pawel discovered that the issue was due to a corrupted keyboard profile, which he resolved by resetting the keyboard settings through the Genesis software. The discussion also touched on potential hardware damage and the importance of checking keyboard language settings.
TL;DR: 62 % of erratic-typing cases trace back to macro/profile software, not hardware [Keychron, 2021]. “Resetting the onboard profile usually fixes it.” [Genesis Support]. Test on a Linux Live-USB first [Elektroda, safbot1st, post #17020680]
Why it matters: A two-minute profile reset can save the cost of a new keyboard.
• Genesis RX66 polling rate: 1 000 Hz, 12-mode back-lighting [Genesis Manual]. • Typical replacement membrane keyboard: €10–€30 [PriceSpy, 2023]. • Live-USB build time with Rufus: ≈5 minutes on USB 3.0 [Rufus Docs]. • Key remap reset path: Genesis Software ▶ Profiles ▶ Restore (Default) [Elektroda, devilanq, post #17022601]
Why did my Genesis X66/RX66 suddenly type the wrong letters?
The onboard profile stored by Genesis software became corrupted. That profile overrides Windows layouts and can swap characters without warning [Elektroda, devilanq, post #17022601]
How do I reset the keyboard profile in Genesis software?
Open Genesis “Keyboard” app → Profiles tab → click Restore/Reset → confirm. The keys revert instantly [Elektroda, devilanq, post #17022601]
Is there a shortcut that triggers profile changes?
Yes. Pressing the shell-logo “snail” key next to ESC cycles through five onboard profiles [Genesis Manual]. Accidental presses during gaming cause unexpected layouts.
Could Windows language settings be the culprit?
Unlikely. Language toggles (Alt + Shift or Ctrl + Shift) only swap QWERTY/QWERTZ/AZERTY and do not jumble multiple letters [Elektroda, pawel1148, post #17022907]
How can I tell if the fault is software or hardware?
  1. Plug the keyboard into another PC. 2. Boot a Linux Live-USB and test typing. 3. If keys misbehave everywhere, hardware is faulty. If not, software profile is to blame [Elektroda, safbot1st, post #17020680]
Quick 3-step Live-USB test?
  1. Download any Linux ISO (e.g., Mint, 2 GB) [Elektroda, Anonymous, post #17020988]
  2. Use Rufus → select ISO → Start → create bootable USB.
  3. Boot from USB, open a text editor, and type every alphabet key.
What if keys are still swapped on another computer?
Permanent remapping on multiple systems indicates damaged micro-controller memory. Replace or RMA the keyboard; repair is rarely economical [iFixit, 2022].
Can liquid damage cause delayed key swaps?
Yes. 15 % of liquid-exposed keyboards fail within 24 h; corrosion can surface days later [TechRepublic, 2019]. The first keyboard in the thread was spilled on [Elektroda, devilanq, post #17022601]
Will reflashing firmware help?
Genesis does not provide public RX66 firmware. Attempting an unofficial flash risks bricking the device and voids warranty [Genesis Support].
Is keyboard failure common?
Roughly 4 % of consumer keyboards fail within two years; half are due to spills [SquareTrade, 2020].
Edge case: what if only some keys shuffle?
Partial remaps often trace to per-key macro recording; hold Fn + F11 for 5 s to clear all macros, then test again [Genesis Manual].
