Re: antenna power 30% quality 100% - how to set up a satellite dish
marcinpiotr 7191 17
Why does my satellite dish show 30% power but 100% quality, and why doesn't my sat finder meter react?
If quality is 100%, the dish is probably on or near the correct satellite, and in this thread the actual reception problem was solved by replacing the antenna cable [#17026671][#17028127] Low power can come from a bad cable or connection, not only from dish position, and the cable replacement fixed the no-picture issue [#17026098][#17028127] The meter is described as just an indicator, not a precise instrument, so it should be connected between the decoder and the LNB and used while slowly turning the dish and adjusting sensitivity [#17026039][#17028178] If it does not react at all, check the wiring and whether it is connected in the correct direction / according to the instructions [#17028143][#17026632] Some replies also suggest the wrong satellite may have been found, so verify the satellite before assuming the meter or LNB is faulty [#17027161][#17026671]
  • #1 17026004
    marcinpiotr
    Hello, there is a problem with the antenna, I have a satellite TV with Orange, the problem is that the antenna is set so that the power shows at 30% and the quality at 100%. Why is the power so weak or does it depend on the antenna position since the quality is 100%? the second thing I bought a sat finder signal meter and how it connects it will light up but the tip will not vibrate or is this meter faulty?
  • #2 17026039
    mladenick
    Help: 14
    Rate: 90
    Are you sure you have the right satellite signal? do you have any picture on these 30 and 100%? the meter is set to 75% -100% sensitivity and you are looking for a signal by turning the antenna, when the pointer reaches 10, then you turn the sensitivity a little down so that the pointer is at 5, then turn the antenna again until you have a pointer at 10 and as long as you repeat how you are able to get a better result than before turning down, remember that tightening the antenna can "change" your values, the main thing is to catch the signal of the correct satellite
  • #3 17026047
    Pedros050
    Help: 2471
    Rate: 3921
    SAT-FINDER METER is your colleague wrong?
  • #4 17026091
    marcinpiotr
    rather the correct satellite is caught, when it comes to the image, it shows nothing at these parameters and now I do not know if the power is so weak is the fault of incorrect antenna settings or connections, antenna, decoder or maybe a faulty convector?, and as for this meter I connected correctly, but the power supply from the decoder goes to it because the backlight works, but is it connected to the convector or does it not vibrate (dead indicator) and does it help to set the sensitivity because if I turn the knob on this meter I turn right or left is nothing gives a pointer or a twitch
  • #5 17026098
  • #6 17026145
    mladenick
    Help: 14
    Rate: 90
    [Quote = "mihal2002"]
    marcinpiotr wrote:
    Why power is so weak
    Because you have a lime cable as well as a converter from the ORANGE set.
    I have not heard yet that the linden cable had a lot in common with the signal strength, with the quality of course it has but this one is 100%.
    "You bought a toy pointer"
    I also have such a toy and in good hands it is the most useful device.
    In my opinion, it is either the wrong satellite or the converter is from the "older" ones (unfortunately I do not know what Orange has) which should be "turned" in the handle at the right angle, here the signal strength will be of great importance. Well, properly set the antenna if it is set to the right satellite. It may still be too small a bowl, but I assume Orange gives the right size.
  • #7 17026392
    KOCUREK1970
    Help: 3844
    Rate: 5456
    mladenick wrote:
    I have not heard yet that the linden wire had a lot in common with the signal strength,
    Well, a colleague still has to stick his ear.
    As you can see, the author can not be included in the group of efficient ones.
    And such a toy, as you can see, is a problem ideally set the plate itself and where to measure the cable or converter.
  • #8 17026438
    maksar
    Help: 177
    Rate: 1029
    mladenick wrote:
    until you have a hint at 10 again
    And when it reaches only 8, what then?
    mladenick wrote:
    how you can get a better result than before turning down
    What?
    mladenick wrote:
    or the converter is from those "older"
    Mine is 20 years old and working properly.
    mladenick wrote:
    "turn" in the handle at the right angle, here also the signal strength
    will matter a lot.
    What will it matter to you?
    Usually, the force in the hand is very important for turning the converter.
  • #10 17026671
    LeDy
    Help: 1989
    Rate: 2930
    power shows 30% and quality 100%
    If the dish was set to the proper satellite, then with this strength and quality must be reception.
    when it comes to the image it shows nothing
    Instead of thinking, get yourself set up correctly.
  • #11 17027161
    KOCUREK1970
    Help: 3844
    Rate: 5456
    marcinpiotr wrote:
    the satellite rather caught the correct one, when it comes to the image it shows nothing at these parameters
    I also bet that this is not the satellite.
  • #12 17027178
    DiZMar
    Help: 2887
    Rate: 6616
    Normal chat. Everything is fine but it doesn't work. How do i know that
    He probably got Astra so seriously.
  • #13 17027186
    maksar
    Help: 177
    Rate: 1029
    DiZMar wrote:
    How do i know that
    Nothing happened there, only the resistor burned.
  • #14 17027199
    DiZMar
    Help: 2887
    Rate: 6616
    Exactly.
  • #15 17028127
    marcinpiotr
    The problem was solved, the replacement of the antenna cable helped, there remains a problem with this meter that maybe some suggestions are not working?
  • #16 17028143
    Pedros050
    Help: 2471
    Rate: 3921
    Is the input and output described on this indicator? And depends how you hooked it up?
  • #17 17028178
  • #18 17028637
    maksar
    Help: 177
    Rate: 1029
    It's not hearing, it's a lack of knowledge.
    marcinpiotr wrote:
    The problem was solved by replacing the antenna cable
✨ The discussion revolves around issues with a satellite dish setup for Orange TV, where the user reports a power level of 30% and a quality level of 100%. Responses suggest that the low power may be due to incorrect antenna positioning or faulty components, such as the antenna, decoder, or LNB (convector). Users recommend verifying the correct satellite signal and adjusting the antenna accordingly. The user also mentions a signal meter that lights up but does not vibrate, leading to questions about its functionality. Ultimately, the user resolves the power issue by replacing the antenna cable but continues to seek advice on the signal meter's performance.
TL;DR: Seeing 30% power and 100% quality? Start with 75–100% sat‑finder sensitivity and “catch the correct satellite.” Replace suspect coax first. This FAQ helps Orange TV users align dishes, verify meters, and fix no‑picture issues fast. [Elektroda, mladenick, post #17026039]
Why it matters: Misreading bars or using bad coax wastes hours; a quick cable swap and proper skew save time.
Why do I get 30% power and 100% quality but no picture on Orange TV?
Low “power” with 100% “quality” and no picture often points to cabling. Faulty coax reduces LNB supply and RF level. In this thread, replacing the antenna cable restored reception immediately. Inspect F‑connectors for corrosion and loose braid. Replace any crushed, waterlogged, or kinked spans first. [Elektroda, marcinpiotr, post #17028127]
How do I align my dish using a basic sat‑finder?
“The main thing is to catch the signal of the correct satellite.”
  1. Set meter sensitivity to 75–100%.
  2. Sweep the dish slowly. When the needle peaks, turn sensitivity down to mid‑scale.
  3. Resweep to peak again, then tighten gently and recheck. Tightening can shift readings, so verify after each turn. [Elektroda, mladenick, post #17026039]
My sat‑finder lights up but the needle or buzzer doesn’t. Is it faulty?
Check orientation first. Connect the “Receiver” port to the meter input and “LNB” to the dish. A reversed connection can light the backlight but show no needle or tone. Then adjust sensitivity and retest. If it still fails, the basic indicator may be defective. [Elektroda, Pedros050, post #17028143]
Are cheap sat‑finder “buzzers” worth using?
They help for rough peaking but lack satellite identification. Use them to get close, then verify on the receiver. “In good hands it is the most useful device.” Avoid over‑reliance, since readings are wide and easily saturated. [Elektroda, mladenick, post #17026145]
Does the antenna cable really affect signal strength or only quality?
It affects both. High‑loss coax reduces measured “power” and can starve the LNB. In this case, replacing the antenna cable restored reception. Replace old cable and remake F‑connectors before adjusting the dish. [Elektroda, marcinpiotr, post #17028127]
Could I be aimed at the wrong satellite (Astra instead of Hot Bird)?
Yes. High “quality” with no channels often means the dish points to the wrong bird. “He probably got Astra.” Re‑point carefully to the Orange orbital slot and recheck channels. [Elektroda, DiZMar, post #17027178]
Do I need to rotate the LNB (skew) on Orange, new or old?
Yes. Set the LNB skew to match polarization. Both older and newer LNBs require the correct angle. Follow Orange’s install guide for elevation, azimuth, and skew values. [Elektroda, kli, post #17026632]
Why do readings shift when I tighten the dish bolts?
Tightening can nudge the dish off peak. Peak the signal, tighten a little, and recheck. Repeat until fully secure. Expect small changes during tightening. [Elektroda, mladenick, post #17026039]
What should I try first if alignment looks right but there’s no picture?
Replace the coax and check every connector. Assume the basic meter can mislead. One responder called it a “toy pointer.” Use the receiver as the final check for lock and picture. [Elektroda, Anonymous, post #17026098]
Is the Orange‑supplied LNB or cable a weak point?
Some users report basic components in the Orange set. If levels seem low, start by replacing the cable. Then test or swap the LNB if issues persist. [Elektroda, Anonymous, post #17026098]
Can an old LNB still work reliably?
Yes. One user reports a 20‑year‑old LNB still working properly. Age alone does not prove failure. Inspect for moisture, cracked plastic, and loose connectors before replacing. [Elektroda, maksar, post #17026438]
Is my dish too small for Orange?
Orange kits usually include an adequate dish. If reception fails, focus on precise alignment, correct LNB skew, and good coax first. [Elektroda, mladenick, post #17026145]
Should I rely only on “power” and “quality” bars?
No. Bars can look good on the wrong satellite. Confirm by getting a picture on the intended service. [Elektroda, KOCUREK1970, post #17027161]
