[Solved] Title: Internet Disconnects after 3 Seconds on Asus A501LX DM099 with Cisco EPC3928 Router
10728 13
Why does my Ethernet connection disconnect after a few seconds on an Asus A501LX DM099 with a Cisco EPC3928 router, and how can I make it stay connected?
The Ethernet adapter is not getting a valid IP address, so first make sure the wired adapter is set to obtain IPv4 settings automatically (DHCP) and test again with Wi‑Fi turned off [#17029424][#17030113] If it still does not receive an address, power-cycle the router and reconnect everything in order: plug the Ethernet cable into the laptop, then into the router, reconnect the main line, and only then turn the router power back on [#17031881] One user reported that after doing this, the wired link came up normally and the internet worked at the expected speed [#17031881]
  • Ethernet link drops after 3 seconds on Cisco EPC3928
    #1 17029290
    sanfran
    Help: 963
    Rate: 3004
    Set the port speed on your laptop to a hard 1G / Full Duplex (or 1000M / Full Duplex) and see if it helps. Check the menu of the device and set the speed on this port to hard.
  • #3 17029365
    Epic
    Level 30  
    Help: 147
    Rate: 108
    1. Turn off WIFI (don't disconnect, just turn off the network card), turn off the computer.
    2. Connect the ethernet cable, turn on the computer.
    3. Check.
    Paste the command result while the computer is connected by cable:
    Code: Dos
    makosuu
    Help: 369
    Rate: 370
    I'm guessing the supplier is Toya so he doesn't have access to the panel :D Toye comes only with the modem itself.
  • Ping fails with general network error
    #5 17029371
    Epic
    Level 30  
    Help: 147
    Rate: 108
    1. Check the configuration of the Ethernet network card. Are you sure it is configured to get addressings automatically.
    2. You tried to update or reinstall the drivers for the Ehternet network adapter
    3. Paste the command result
    Code: Dos
  • Wi-Fi adapter shows invalid IP configuration
    #7 17029496
    Epic
    Level 30  
    Help: 147
    Rate: 108
    1. According to the command, you have not turned off the WiFI card and the computer is connected with it. Perform while connected by cable.
    2. Check the IP settings of the ethernet card. Is everything downloaded automatically from DHCP?
    3. Execute the command after disconnecting and turning off the WIFI card.
    Code: Dos
  • Ethernet adapter shows media disconnected
    #9 17030172
    Check whether the router is limiting connected devices
    #10 17030246
    Epic
    Level 30  
    Help: 147
    Rate: 108
    1rzepak wrote:
    Internet protocol version 4 and after clicking properties, everything is set to automatic there. If it is not, I would ask for a possible explanation of where I have to go.
    Yes, that was the place. However, as I can see, despite this configuration, the laptop does not receive an address from the router.
    Does the situation remain the same even after waiting a while after plugging in the cable?
    How is your access to the router's configuration panel? It is possible that the operator has limited what devices can be connected to the router, as long as he has access to the panel.
  • WPS button identified, but no router settings checked
    #11 17030554
    damcio1010
    On the back of the router, you can have a sticker with the device's IP address (default). Remember to log in to the panel to be connected to wifi because from what I can see on the cable you do not get any address.
    Maybe, by entering the router model in google.pl, find its deafult ip address. Enter the password default ip adress or something like that.
  • #13 17031881
  • #14 19106982
The discussion revolves around an internet connectivity issue experienced by a user with an Asus A501LX DM099 laptop connected to a Cisco EPC3928 router. The laptop connects to the internet via Ethernet for approximately 3 seconds before disconnecting, indicated by an orange LED on the router. Various troubleshooting steps are suggested, including setting the Ethernet port speed, ensuring the network card is configured for automatic IP addressing, and checking router settings. After multiple attempts and configurations, the user eventually resolves the issue by power cycling the router and reconnecting the Ethernet cable, resulting in stable internet connectivity.
TL;DR: 1 Gbps links can flap if auto‑negotiation misbehaves; "Set the port speed to a hard 1G / Full Duplex." This FAQ helps Asus A501LX + Cisco EPC3928 users stop 3‑second Ethernet drops and regain stable wired speed. [Elektroda, sanfran, post #17029357]
Why it matters: It quickly restores a stable, full‑speed wired connection for troubleshooting and everyday use.
How do I stop my Asus A501LX Ethernet from disconnecting every few seconds on a Cisco EPC3928?
Force the NIC to 1000M/Full Duplex in Windows. Disable Wi‑Fi to avoid route conflicts. Try a known‑good Cat5e or Cat6 cable. Reboot the EPC3928 and the laptop after changing settings. This stabilizes the link when auto‑negotiation loops. [Elektroda, sanfran, post #17029357]
What does the EPC3928’s orange vs green LAN LED mean?
On the EPC3928, a green LAN LED indicates a gigabit link at 1000 Mb/s. An amber LED indicates a 10/100 Mb/s link. Use Cat5e or better for gigabit. Cisco EPC3928 User Guide
Why does PING 8.8.8.8 say "General failure" when I plug in Ethernet?
Windows returns "General failure" when the TCP/IP stack has no usable interface or IP. In this case, the Ethernet adapter lacked a valid configuration and could not send packets. Fix the link and DHCP first, then retest. [Elektroda, Anonymous, post #17029371]
How do I check DHCP and IP settings for Ethernet in Windows?
Open Network Connections, right‑click Ethernet, Properties, then IPv4. Ensure both IP and DNS are set to Obtain automatically. Run ipconfig /all to confirm the adapter receives an IP, gateway, and DNS. If not, troubleshoot the link or DHCP. [Elektroda, Epic, post #17029424]
What power‑cycle order fixed this specific case?
Use this clean start sequence:
  1. Unplug all router cables and power, wait about two minutes.
  2. Connect Ethernet to the laptop, then the main coax.
  3. Apply power last, then test the wired link. This restored stability here. [Elektroda, Anonymous, post #17031881]
I can’t reach the EPC3928 admin page. What should I try first?
Check the sticker or manual for the default IP. Connect to the router over Wi‑Fi, then browse to that IP. If it still fails, the operator may restrict access. Try a different browser and confirm your device’s IP. [Elektroda, damcio1010, post #17031692]
Should I disable Wi‑Fi while troubleshooting Ethernet?
Yes. Turn off the Wi‑Fi adapter, then reconnect the Ethernet cable and test. This prevents Windows from routing traffic over Wi‑Fi and confusing results. Re‑enable Wi‑Fi only after Ethernet works. [Elektroda, Epic, post #17030113]
How do I set 1.0 Gbps Full Duplex on my Realtek PCIe GBE controller?
Open Device Manager, expand Network adapters, open Realtek PCIe GBE Properties. On Advanced, set Speed & Duplex to 1.0 Gbps Full Duplex. Apply and reboot the router and laptop if needed. "Set the port speed on your laptop to a hard 1G / Full Duplex." [Elektroda, sanfran, post #17029357]
ipconfig /all shows "Media disconnected" for Ethernet—what does that mean?
It means Windows sees no active link on that adapter. Causes include a bad cable, disabled port, failing negotiation, or the router not providing link. Fix the physical link first, then obtain an IP. [Elektroda, Anonymous, post #17030172]
Why is Wi‑Fi slower than wired on my 150 Mbps plan?
In this case, Wi‑Fi delivered about 90 Mbps while the plan was 150 Mbps. Wired Ethernet can reach plan speed when the link is stable. Use gigabit Ethernet for best throughput and latency. [Elektroda, Anonymous, post #17029290]
Could my ISP be limiting devices or access on the EPC3928?
Yes. The operator can lock the admin panel and limit which devices connect. This may block DHCP for unrecognized MAC addresses. Contact support if you suspect provisioning limits. [Elektroda, Epic, post #17030246]
What quick Windows network tests should I run after plugging the cable?
Disable Wi‑Fi completely. Open Command Prompt as admin, run ipconfig /flushdns. Then run ping 8.8.8.8 to check basic connectivity and latency. Save outputs for support. [Elektroda, Epic, post #17030113]
Do different Ethernet cables or LAN ports help?
Testing multiple cables and ports is smart. In this case, two cables and different router ports showed the same drop pattern. The final fix required a clean power‑cycle and link setup. [Elektroda, Anonymous, post #17029290]
The LAN LED is green but there’s no Internet—what does that imply?
A green LED shows physical link at gigabit speed. No Internet then indicates DHCP failed or the gateway is unreachable. Check if the adapter obtained an IP address and default gateway. [Elektroda, Epic, post #17030246]
Will pressing the WPS button fix Ethernet issues?
No. WPS pairs Wi‑Fi clients and does not affect wired link negotiation or DHCP on Ethernet. Troubleshoot the cable, NIC settings, and router instead. Cisco EPC3928 User Guide
Did the fix hold long term?
Yes. The user reported that after the clean power‑cycle and subsequent reboots, the issue did not return. The connection stayed stable. [Elektroda, Anonymous, post #19106982]
