[Solved] HikVision DS-7608NI-K2 Recorder: Cloud Configuration, Hik-Connect Function, Verification Code
tablica24 10314 8
  • #1 17042786
    tablica24
    Rate: 61
    Hello. I have a HIKVISION DS-7608NI-K2 recorder. The recorder has a hik-connect function thanks to which you can have remote viewing for free.
    And here the problem arises, the verification code is needed. And I can enter it myself ... Where can I find this code. There is only a serial number under the device.
  • #2 17043012
    szymon122
    Help: 302
    Rate: 762
    Set the code yourself in the recorder and then enter the same into the application :)
  • #3 17043248
    dawidedziu
    Industrial cameras specialist
    Help: 500
    Rate: 642
    A colleague above writes well. You go into the settings, then the network and there will be something like hik-connect, select this inactive window, you will probably see a new window, select the window again and enter any letters. It used to be predetermined, now it is entered. What I wrote may vary slightly depending on the firmware version.
  • #4 17043307
    tablica24
    Rate: 61
    I entered a password there and I have offline status (0x1007) WHY?
  • #5 17043340
    dawidedziu
    Help: 500
    Rate: 642
    Well, do you have a properly connected internet recorder? This message indicates a problem with the link.
    Once the code from the machine was BGTUJB, BGRUKV. Alternatively, try entering a verification code on this basis.
  • #6 17044991
    bi3dron
    Help: 24
    Rate: 22
    If the hik-connect status is not connected, then you need to check whether:
    1. he will be able to release PING onto the recorder from this network and whether he can enter his WWW panel,
    2. is there internet in the local network.
    Also, find out if your ISP is blocking ports. Apparently it's archaism, but it happens sometimes with local service providers.
    And the question is whether a fixed IP would not be more convenient?
  • #7 17045066
    Gutek1512
    Help: 39
    Rate: 37
    It seems to me that the correct DNS and gateway are most important for the cloud. The rest should not be a problem. Simply DVR must have Internet communication via DNS.
  • #8 17045465
    tablica24
    Rate: 61
    Case solved.
    setting a verification code consisting of 9 digits.
    DNS settings:
    8.8.8.8
    114,114,114,114
  • #9 17045470
    tablica24
    Rate: 61
    Case solved.
    DNS settings:
    8.8.8.8
    114,114,114,114
    Solved.
The discussion revolves around configuring the HikVision DS-7608NI-K2 recorder for remote viewing via the Hik-Connect function, specifically addressing the need for a verification code. Users suggest setting the verification code directly on the recorder and entering it into the Hik-Connect application. Troubleshooting steps include ensuring proper internet connectivity, checking DNS and gateway settings, and verifying that the device is not blocked by the ISP. The author successfully resolved the issue by setting a 9-digit verification code and configuring DNS settings to 8.8.8.8 and 114.114.114.114.
