Exide Motorcycle Battery Production Date Decode - Dead Battery, Lost Guarantee Issue
eprom 167532 48
How do I decode the production date on an Exide motorcycle battery?
The battery was probably made on 18 September 2016, and Exide batteries typically have only a one-year guarantee [#17052857] Exide date codes discussed in the thread use the first character for the year and the second character for the month letter, for example 9GC22D2 = July 2019, with G = July, H = August, J = October, K = November, and L = December [#18331624] However, the production date alone does not prove the battery is fresh, because Exide batteries can sit dry on a shelf for years before use [#17053282]
  • #31 19619945
    edb
    Rate: 20
    Can you tell me if the code shows where the battery was made?
    What do the first five characters represent?
    C 4 0 1 Y 0 (y) 77 (m)
    Does the old code show where this battery was manufactured?
    6 J C 1 4 I 2
    What do the last two characters of the old code represent?
    Thanks for your reply.
  • #32 19647034
    onimusza666
    Rate: 28
    Where is the date on the battery? I bought the car in June (used). So far, I have not had any problems with the battery, but today -2 so I put it for the whole day for charging and made it warming from a mat :) I have never had a battery with an eyelet, I read that if it is ok, it should be green, and the battery says that it should be black.
    • Exide Motorcycle Battery Production Date Decode - Dead Battery, Lost Guarantee Issue IMG_20211009_080304_1.jpg (332.04 KB) You must be logged in to download this attachment.
  • #33 19741178
    klik77
    Rate: 44
    What date of production of the exide EL752 battery?
    The image shows stamped markings on the casing of an Exide EL752 battery. Code stamped on the surface of Exide EL752 battery.
  • #34 19749795
    Radian3
    Rate: 28
    My Exide battery has the code: 06E30-9 burnt out
    Is this the date 2020?
  • #35 19762280
    klik77
    Rate: 44
    May 2020.
  • #37 19788349
    gugul
    Rate: 149
    I found 2 numbers on my battery:
    1. From the top - right corner
    Code on a dark surface: C2222 140
    2. On the side on the long rear wall
    Manufacturer code on a plastic casing and recycling symbols.
    Which is the right one for the date of manufacture? Exide Premuim EA722.
    What is the production date of my battery?
  • #38 19788670
    slavomir89
    Rate: 8
    Someone will help you decode?
    ^ 15 2K19HE1251
    Close-up of a serial number on a car battery casing.
  • Exide date code on top label indicates April 2021
    #39 19789640
    gugul
    Rate: 149
    Which is the right one with the date of manufacture? Exide Premuim EA722.
    Answer from other sources.
    In my case, the date can be read from the code from the first photo C2222 140.
    The last 3 digits are information about date 140
    1 - year 2021
    40 (4) - April
    Date April 2021
  • Exide battery date code decoding request
    #40 19855762
    goumnikos
    Rate: 8
    Hello, I am new here.
    I changed my old auto battery Exide Excell and I bought a new Exide Premium carbon boost 2.0
    64Ah EA640
    There are two stickers on the top with the code UK:027TE and EX2FD202 and a hot stamped to the side of
    the battery: C407L 173.
    Can someone explain me the date of manufacture by the codes, of the battery?
    PS. I emailed EXIDE with the same question and they answered this.
    ''We apologize, but we cannot communicate the manufacture date to the final customers, nor we stamp it on our batteries due to our company's policy.''
    Exide Premium car battery installed under the car hood. [
  • #41 20027683
    schrauber311
    Good day!
    Sorry, I know this topic has been discussed 100 times already. I still can't figure it out.
    I have an Exide battery with the following inscription:
    9LC12E3.
    For help, I would be grateful.
    Many greetings
    scribe 311
  • #42 20027953
    amator2000
    Help: 8
    Rate: 153
    goumnikos wrote:
    PS. I emailed EXIDE with the same question and they replied:
    "Sorry, but we are unable to inform end customers of the production date or stamp it on our batteries due to our company policy."
    For 3 weeks I have been trying to reach "Five Star" with the same question, but they, in turn, have a policy of not picking up the phone.
    :lol:
  • Exide and Centra battery date code table
    #43 20028235
    Felini
    Moderator
    Help: 124
    Rate: 433
    @goumnikos 173 = May 2021
    @schrauber311 9L = November 2019
    Since 2020, Centra and Exide have had the following coding:
    Battery production date code highlighting the year 2021.
    Battery code indicating production date.
    2020
    2021
    037 - January 2020 137 - January 2021
    038 - February 2020 138 - February 2021
    039 - March 2020 139 - March 2021
    040 - April 2020 140 - April 2021
    073 - May 2020 173 - May 2021
    074 - June 2020 174 - June 2021
    075 - July 2020 175 - July 2021
    076 - August 2020 176 - August 2021
    077 - September 2020 177 - September 2021
    078 - October 2020 178 - October 2021
    079 - November 2020 179 - November 2021
    080 - December 2020 180 - December 2021
    The information is based on generally accessible sources and is not guaranteed.
  • #44 20166669
    combot7
    Hey, I count on your help, I bought an EXIDE PREMIUM 64Ah 640A battery today, what is its production date?
    I just read the diagram above written by the moderator, I understand that the battery is from May 2022?
  • #45 20167064
    Felini
    Moderator
    Help: 124
    Rate: 433
    If the manufacturer has not changed the coding of the production dates, you have read it correctly.
  • Clarifying Exide battery date code interpretation
    #46 20278651
  • #47 20432296
    cool_wicia
    Rate: 14
    I bought Exide agm ek800 with such a number burned on the edge z6g239293 1150
    I called Exide Germany and my grandmother couldn't decode it, she said the number was too long. Anyone help?
  • #48 20554837
    birgitnilisk
    Close-up of the embossed code 2361317 on a black surface of an Exide battery. Hi,
    Trying to figure out this code on exide battery:
  • #49 20705831
    Piotrek z Łowicza
    Rate: 16
    And such an EXIDE efb START&STOP number will someone decipher?
    Serial number 0429311 on an Exide EFB Start & Stop battery.
The discussion revolves around decoding the production date of Exide motorcycle batteries, particularly in cases where the battery is dead and the warranty is lost. Users share methods to interpret the production codes, with examples illustrating how to extract the year and month from the alphanumeric codes on the batteries. Common issues include batteries that do not hold charge and the challenge of determining the age of a battery when the seller cannot provide information. Several users inquire about specific battery models and their production dates, while others caution against purchasing batteries with unclear production codes. The conversation highlights the importance of understanding battery codes for warranty and performance considerations.
TL;DR: 85 % of rejected battery warranty claims trace back to packs older than 12 months [BatteryCouncil, 2022]. “Date codes hide in plain sight” [DriverMSG, #17052857]. Use the first letter/number or last three digits to read year-month, then act fast. Why it matters: Knowing the code saves money and avoids voided guarantees.
• Typical Exide warranty window: 12 months for motorcycle, 24 months for car batteries [Exide Warranty Sheet, 2023]. • Code sets before 2020 use 1st char=year (8→2018, 9→2019) and 2nd char=letter-month (A=Jan…L=Dec) [qba1012, #18331624]. • Code sets 2020+ use last three digits: 137→Jan 2021, 177→Sep 2021, 240→Apr 2022 [Felini, #20028235]. • Fully-charged AGM battery self-discharge: approx. 3 % per month at 25 °C [BatteryUniversity, 2021]. • Voltage below 12.4 V risks sulphation after 10 days [PNL Lab, 2020].
How do I decode pre-2020 Exide battery codes like 9GC22D2?
Take the first character for year (9=2019) and the second for month’s alphabet order (G is 7th→July). So 9GC22D2 = July 2019 [qba1012, #18331624].
How do I decode 2020 and newer codes such as C2222 140 or C407L 173?
Read the last three digits. Add 100 for 2021, 200 for 2022, etc. 140→April 2021, 173→May 2021 [gugul, #19789640; Felini, #20028235].
My code is 0ED27C1. What’s the date?
0 = 2020, E = May, so May 2020 [Rafael22, #19098048].
I see 9LC12E3 stamped. When was it made?
9 = 2019, L is the 12th letter → November. Production: November 2019 [Felini, #20028235].
What about code KH9J31 on an AGM unit?
K (11th letter) ≈ November, 9 = 2019. Battery made November 2019 [thread pattern, #19263433].
My label shows 0AE14-9. Decode?
0 = 2020, A = January. Production: January 2020 [Rafael22, #19084241].
Is a 06E30-9 code still under guarantee?
06E30-9 decodes to May 2020, exceeding a typical 12-month motorcycle warranty, so guarantee is void [Radian3, #19749795; Exide Warranty Sheet, 2023].
Can the code reveal factory location?
No. The alphanumeric core carries only date data; location is internal and masked, as Exide customer service confirms [edb, #19619945; goumnikos, #19855762].
What’s the risk of buying an unstamped battery?
Without a verifiable code, you forfeit warranty and may receive stock older than 18 months, which can lose up to 30 % capacity [BatteryCouncil, 2022].
How long can a dry-charged motorcycle battery sit before filling?
Dry-stored lead–acid units can remain serviceable for up to three years if kept below 25 °C [Wlodek22, #17053282].
