Setting Up NC+ Satellite Antenna in the Netherlands: Weather Impact & Signal Stability
222krzyŚ009 5793 2
  • #1 17064239
    222krzyŚ009
    Hello, I kindly ask you for information about how you can set up the satellite nc + antenna in the Netherlands because once it is set it is good and nowow bad. On a sunny day it was ok and after some time no signal. Satellite dish 60. I have no idea how to set up the antenna for proper operation. Please help, greet Krzysztof from the Netherlands
  • #2 17064296
    sanfran
    Help: 963
    Rate: 3004
    60 is a bit small, but it should do well.
    Antenna alignment is not only aiming at the point, but also choosing the angle of the converter. In turn, the satellite set is not only an antenna with a converter but also cables.
    If there are problems, I recommend contacting a professional, he will come and set up.
  • #3 17064435
    maksar
    Help: 177
    Rate: 1030
    To the author.
    Provide the location of this installation.
    Moderated By simhak:
    Unnecessary removed, please weigh the words ...
