[Solved] VW Passat b5 1.8 8v Gasoline - Cold Engine Jerking at 2k RPM, Post NGK Wires & Candles Update
Maksiu922 16995 16
Why does my VW Passat B5 1.8 petrol jerk only when the engine is cold around 2000 rpm, and where should I start diagnosing it?
Start with the fuel system, especially the fuel filter and any leaks or air ingress, because the symptoms point more to fuel supply/pressure than to ignition. Warming the coil for hours and reinstalling it made no difference, so the coil was considered unlikely [#17064820][#17066639] One suggestion was to check for a fuel hose leak or aeration and to try starting after cycling the ignition key several times to prime the pump; if it drives normally at first and then starts jerking, fuel pump pressure drop or water in the system is suspected [#17068304][#17071388] Another reply noted that new wires and plugs can still be poor quality, but vacuum leaks or throttle-related faults should also be checked if fuel issues are excluded [#17067473] In the end, replacing the fuel filter cured the jerking completely in freezing weather, which strongly confirms a clogged or restricted filter as the cause [#17116197]
  • #1 17064702
    Maksiu922
    Rate: 10
    I have a VW Passat b5 1.8 8v. Gasoline without gas. For some time the car after firing and starting jerks at revolutions from 2 thousand. After driving 1-2 km after jerking there is no trace. The engine catches some temperature. The car tugs only when the engine is cold. First, I replaced the candles and wires. There is no error on the computer, e.g. Loss of ignition. And now the question is where to start? The new coil is about 800 PLN and I do not want to start with THIS while the wires and candles are from NGK. And after their exchange there is a big improvement but not total. On the other hand, cold starting of the engine is exemplary, the same is the engine's cold operation at idle. In the first gear, he also starts without any problems. The problem arises from the second gear of 2 thousand revolutions as I wrote. Has anyone met this before? Where to start?
    Regards
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    Maksiu922 wrote:
    The new coil is about PLN 800 and I don't want to start with THIS
    Remove the coil, heat for 2-3 hours in an "oven" at 60-70 degrees.
    Mount it to the "cold" car and check that there are exactly the same symptoms that you described above.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 17064846
    komandospolen
    Or heat the coil with a heat gun at 100C taking care of the wires, you will save time with disassembly.
  • #4 17066440
    Maksiu922
    Rate: 10
    I did so too. I warmed the coil for 3 hours and after the assembly there was no difference.
    CameR
    Help: 1139
    Rate: 3272
    ... i.e. rather it is not a coil or at least there are no microcracks through which moisture penetrates and causes HV micro breakthroughs.
    ABC KOM
  • #6 17067268
    misterbociek
    Help: 40
    Rate: 120
    Hello!
    And maybe you have something like that you start the car in the morning, go and at the beginning everything is OK and only after about 1-2 kilometers this circus begins?
  • #7 17067473
    robokop
    Help: 1763
    Rate: 6371
    However, I would focus on wires and candles. Just because they're new doesn't mean they can't be of poor quality. This one. Second - there are three unpleasant ailments - the throttle module integrated with the adjuster and TPS sensor, the camshaft adjuster cylinder and the pneumatic suction valve. The first two, as a rule, generate errors in the event of a fault, while in the case of the 3rd element, sometimes you hear a hissing sound near the throttle - the engine sucks "left" air.
    ven0n
    Help: 5
    It is similar in our case, as soon as it fires up it moves for a dozen or so seconds so that it is impossible to drive. But in my case I sniffed the fuel leak, maybe the hose snapped (and the fuel system is aerated). Everything as the author described, fires up and works on a sterile pattern.
    Fire it in the morning, ride it until it stops pulling, even if it doesn't get hot, put it out. Fire it a minimum in 2-4 hours so that you can be sure that it is cold, before starting a minimum turn the key twice as if you were warming the candles (you start the fuel pump twice), start it and write if it goes on.
  • #9 17068842
    Maksiu922
    Rate: 10
    I'll do it anyway. I also decided to replace the fuel filter, but that's after the hose test. If water has accumulated in the fuel filter, it may freeze and hinder fuel flow. However, there is such a thing as the return of fuel from the engine (someone mentioned it to me). Perhaps the fuel heated after returning to the tank from the engine when it goes to the filter heats it enough that the water that is frozen there heats up and melts. Then the correct fuel flow occurs.
    And where did you have the damaged hose? Perhaps this is a characteristic fault?
    misterbociek wrote:
    Hello!
    No, the problem arises as soon as it changes gear from 1st to 2nd. And with these frosts (-10 degrees) I have to drive from 4 or 5km for improvement
    robokop wrote:
    while for the 3rd element, sometimes the throttle hiss is heard - the engine sucks the "left" air.
    Tomorrow I will check if something is heard, and by the way, is it a fairly clear hiss? Do you have to listen to hear it?
    ven0n
    Help: 5
    I have not done it yet, cold, no garage and the engine with accessories fills the space under the hood to the brim, I only know that you feel gasoline, the car used every day drives normally.
    As the hose shot specifically, the hiss should be clear, for me it burst from the vacuum of the brake servo (058 133 783 L) at the bend, I already heard it standing even a meter from the car (quiet engine) but still did not jerk.
    Look for the hissing on the right rear of the engine from the perspective of the car opposite, just put your ear where there are the most snakes.
  • Cold-start jerking points to fuel supply issue
    #11 17070579
    Maksiu922
    Rate: 10
    So I did the test. I drove quite a lot until 2pm today. The car stood up to 18 hours. I fired as you wrote (I turned the key twice). I made it less than 6 km. Interestingly, the first 1.5 to 2km jerked nothing. What was the worst driving period so far. The car was driving properly. At 2 km, delicate single jerks appeared. They appeared up to 4 km with decreasing quantity and power. That the symptoms would disappear completely.
    The conclusion I have is a problem with the fuel supply. Unfortunately, I also do not have a garage and the frost is strong so I will change the filter only when the temperature is above 0. And tomorrow I will buy a means for draining water from the fuel system. I will write how it all ends in a while. Is this enough or is it necessary to look for leaks in the system? Regards :D
    Fuel pump pressure drop suspected after reset test
    #12 17071388
    ven0n
    Help: 5
    So now before you turn it on again, turn the key 4 times, when you turn the key to the off position, wait 5-10 seconds, to be sure pull it out so that there is a greater chance that the information in the computer that will turn the pump will reset. Then you'll have even more confidence that it's something with the fuel system. If you will drive correctly from the very beginning and then start jerking again, you can assume that the pressure generated by the fuel pump drops, or the water collapses around the system.
  • #13 17073400
    Maksiu922
    Rate: 10
    Today I added a means to remove water in the fuel system and tomorrow again before 7 am departure. I did today with about 7km after adding, so it will certainly spread along with the fuel. Tomorrow morning I will see if there is improvement. I'll let you know ...
  • #14 17076200
    Maksiu922
    Rate: 10
    Unfortunately, it is still jerking. But I won't do anything else during freezing weather
  • #15 17076667
    ven0n
    Help: 5
    It tugs immediately after firing despite using the method I proposed?
    Does it start jerking while driving 2km further?
  • #16 17085573
    Maksiu922
    Rate: 10
    Immediately. Today is a lot of warm so jerking is almost gone. It was raining again and the high humidity does not affect the quality of the engine. Maybe replace the fuel filter soon
  • #17 17116197
    Maksiu922
    Rate: 10
    I was able to change the fuel filter before winter came again. Temperature around minus 5 or even minus 7 degrees. There is no trace of jerking on the new filter. It is true that on that filter I made almost 15 thousand km and so it was to be replaced. Regards :) and thank you for helping me get started
The discussion revolves around a VW Passat B5 1.8 8v gasoline engine experiencing jerking at around 2000 RPM when cold, which resolves after a short drive. The user has replaced the spark plugs and ignition wires with NGK products, but the issue persists. Suggestions include testing the ignition coil by heating it, checking for vacuum leaks, and inspecting the fuel system for water or blockages. The user suspects a fuel supply issue and plans to replace the fuel filter. After adding a water-removal additive to the fuel system, the jerking improved, and ultimately, replacing the fuel filter resolved the problem entirely.
TL;DR: Passat B5 cold jerking often traces to a clogged fuel filter (15,000 km on the old one); "There is no trace of jerking on the new filter." Confirm with fuel-pump priming and coil-heat tests before buying parts. [Elektroda, Maksiu922, post #17116197]
Why it matters: For VW Passat B5 1.8 8v owners fighting cold-engine jerks near 2k rpm, this FAQ fast-tracks diagnosis and a proven fix.
What’s the most likely fix for cold-engine jerking on a Passat B5 1.8 8v?
Replace a clogged fuel filter. In the thread, jerking in sub-zero weather disappeared after installing a new filter. The old filter had about 15,000 km. The owner reported, "There is no trace of jerking on the new filter." [Elektroda, Maksiu922, post #17116197]
What does “jerking at 2k rpm” look like on this engine?
It appears near 2,000 rpm on a cold engine, especially during the 1st‑to‑2nd gear change. First gear launches are normal. Cold idle is smooth, and starting is exemplary. No “loss of ignition” code appears. [Elektroda, Maksiu922, post #17064702]
How do I prime the fuel pump to test fuel delivery?
Use this quick check:
  1. With a cold engine, turn the key to ON four times, waiting 5–10 seconds each time and removing it to reset.
  2. Start and drive; note whether it pulls cleanly at first.
  3. If it later begins jerking, suspect pressure drop or water in fuel. [Elektroda, ven0n, post #17071388]
What did the ignition-priming test show for the OP?
After priming, the first 1.5–2 km were smooth. Then light jerks appeared and faded by about 4 km. The pattern indicated a fuel-supply problem, consistent with a restricted filter. [Elektroda, Maksiu922, post #17070579]
How can I test the ignition coil for cold-related breakdown?
Heat the coil and compare symptoms. "Remove the coil, heat for 2–3 hours in an 'oven' at 60–70 degrees." Refit to a cold car and road‑test. If symptoms differ, moisture‑related breakdown is likely. [Elektroda, CameR, post #17064820]
If the heated-coil test shows no change, what then?
Treat the coil as unlikely. As one expert summarized, it is not the coil, or there are no microcracks allowing HV micro‑breakthroughs. Move on to fuel and air diagnostics. [Elektroda, CameR, post #17066639]
Can vacuum leaks cause similar hesitation?
Yes. The pneumatic suction valve and nearby plumbing can leak, sometimes with a hiss near the throttle. "The engine sucks 'left' air." Inspect hoses and valves before replacing major parts. [Elektroda, robokop, post #17067473]
Where should I listen for a hiss, and which hose is suspect?
Listen at the right‑rear of the engine. A brake‑servo vacuum hose (058 133 783 L) split at its bend and hissed audibly from a meter away. That case did not cause jerking, so treat it as an edge case. [Elektroda, ven0n, post #17069748]
Do weather or humidity change the symptoms?
Warmer weather almost eliminated jerking in the case discussed. Rain and high humidity did not worsen engine behavior. The owner still planned a fuel‑filter change, which later solved it. [Elektroda, Maksiu922, post #17085573]
How far do I need to drive for symptoms to fade in severe cold?
At about −10°C, improvement appeared after roughly 4–5 km. The car then pulled normally as coolant and fuel warmed up. This distance shrinks as ambient temperatures rise. [Elektroda, Maksiu922, post #17068842]
Do new NGK plugs and wires rule out ignition problems?
No. New parts can still be poor quality. Re‑check plugs and leads if symptoms persist. Also consider the throttle body/TPS, camshaft adjuster cylinder, and the pneumatic suction valve as potential causes. [Elektroda, robokop, post #17067473]
Will throttle/TPS or cam adjuster faults set fault codes?
Usually yes. The throttle module (with adjuster and TPS) and the camshaft adjuster cylinder typically generate errors when faulty. Scan first before replacing components. [Elektroda, robokop, post #17067473]
Why were there no misfire codes here?
In this case, the ECU showed no “loss of ignition” code despite jerking. Cold starts and cold idle were exemplary. That pointed the diagnosis away from immediate ignition failure. [Elektroda, Maksiu922, post #17064702]
Does a fuel smell matter during diagnosis?
Yes. A noticeable fuel smell can indicate a leak or aeration from a damaged hose. One user suspected a snapped hose and recommended ignition cycling to rule in a fuel‑supply issue. [Elektroda, ven0n, post #17068304]
