iPhone 7 plus - The front camera does not work after replacing the display.
ciupektm 7329 4
  • #1 17069143
    ciupektm
    Hello all. I haven't looked here for a long time, but I have a problem, and maybe one of you met with such a case. Well, in the iPhone 7 plus after replacing the display, the front camera stopped working. Exactly, after switching the main camera to the front camera, a blurry view from the top camera or a black background appears. I will add that the speaker for calls and the proximity sensor is ok, so the flex tape is probably not damaged. Before replacing the screen, the webcam was working. Anyone have any idea? best regards
  • #2 17069193
    pdemski
    Help: 36
    Rate: 71
    I would undress again and check if I put everything together well, especially the flex from the camera. Check if there is any dust between the flex contacts and the socket.
  • #3 17071806
    ciupektm
    It did nothing. Connectors ok and clean. Probably the broken glass damaged the camera during disassembly. I ordered a whole new camcorder tape. Swap and we'll see what effect.
  • #4 17083735
    ciupektm
    Replaced the front camera with a new one and nothing else. In addition, the situation is that the main camera works only in the main application. Not in Snapchat and Facebook. I have no idea what that might be. Proximity sensor, speaker approx.
  • #5 17084069
    RafalB
    Help: 91
    Rate: 222
    There are many ideas, as there are many possibilities of damage during "panel repair / replacement"
    Broken elements, sticking, damaged laminate. Start by recreating the software and check the flashlight / flash operation.
    iFixThis
    Łowmiańskiego 18, Poznań, 60-685 | Tel.: 516XXXXXX (Show) | Company Website: https://www.instagram.com/ifixthis.pl/
