Washing machine Elektrolux 1300RPM error - How to eliminate the error
Frodoslaw1 8784 3
  • #1 17082325
    Frodoslaw1
    How can you clear the EHO error? Washing machine 1300 RPM. Everything is fine with electricity. I am asking for any tips on how to enter the service mode?
    Thank you
  • #2 17082609
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6953
    The errors related to the supply voltage will disappear by themselves once the problem is resolved. In addition, there may be a problem with the electronic module, then the errors will not disappear anymore.
  • #3 17083575
    Frodoslaw1
    Thank you, but can you know how to delete errors or restart>
  • EH0 points to mains voltage or frequency fault
    #4 17084548
    mrice
    Help: 2213
    Rate: 6953
    Yes, remove the fault and the washing machine will start. Elektrolux has no critical errors. You do not need the service mode here.
    In theory, EH0 is a mains voltage or mains frequency error.
    I understand that when you wrote that everything was fine with the current, the power was properly measured in terms of voltage and frequency and under load?
    If so, you would have to look at the module, but it is rather a job for a good electronics engineer.
