[Solved] Choosing the Right Boiler for Eco-Pea Coal: Power Calculation for 16sqm, 24sqm & 224sqm Areas
suharow 5316 15
How do I choose the boiler power for an eco-pea coal stove: based on usable area or total area?
Choose the boiler by the building’s heat demand after insulation, not by simply using total floor area. The project’s 24 kW is likely based on a gas-boiler-style calculation and can be too much for a well-insulated new house; a practical rule mentioned was about 60–90 W/m², which gave around 16 kW for the described house [#17083377][#17085906] For an uninsulated house, the calculated need can rise to about 24 kW, but that applies only for very low outdoor temperatures and a large part of the season will need much less power [#17085906][#17083827] Because you plan to insulate next year, several replies recommend sizing for the finished house, around 15–16 kW, with reserve for frosts [#17085906][#17344693] If the boiler will also heat domestic hot water, factor in the DHW tank/coil and your hot-water consumption when selecting the set [#17084024]
  • #1 17083114
    suharow
    I plan to buy a stove for eco-pea coal, I read a bit on forums and according to forum users, for a building like mine, the sufficient power is about 16 sq. M. The project is 24 sq. M. The usable area is 140 m and the total area is 224 m.
    According to the boiler power formulas, it is about 224 m that requires approximately 24 kW.
    So the power counts for the usable or total area?
    MEVEX1
    Rate: 8
    I have a 10x11m house, two usable floors plus a heated attic.
    Boiler kwp eko 20kw gutter burner.
    Considering the usable area, it is 200m plus the attic 100m.
    Total height 2.5m times 300m.
    Since I have 24 degrees downstairs, 23 degrees on the first floor and in the attic, about 10 degrees at minus 12, the fuel consumption is around 500 kg per month and a large power reserve is probably 70kw according to the calculation for the total area, it would be slightly exaggerated. The boiler also heats the domestic hot water
  • #3 17083321
    suharow
    I have 16 x 7.6 room height 2.70, ground floor and attic.
    So 24 kW from the project will be too much power? There are guidelines for gas heating in the project, maybe hence such power?
    sq9etc
    Help: 11
    Rate: 15
    Here, count approximately:
    http://cieplowlasciwie.pl/
    if that's not enough for you, you can hire a specialist to do it exactly.
    Aaalbercik
    Help: 38
    Rate: 81
    If it is a new house, well insulated, take the heat demand on a level
    60-90w / m2 and choose a boiler for this power.
    If you have a project, you have calculated building heat losses and this will be your "boiler power"
    You have 24 kW in the project because it is probably a combi boiler.
  • #6 17083512
    Xantix
    Help: 686
    Rate: 1657
    If the house is new and well insulated, it will definitely be too much. Assuming a factor of 75 W / m2, this gives a power of about 16 kW. Remember also that the above-mentioned power is given to the lowest daily average in a given climate zone (about -20 degrees) and such temperatures are very rare in our country - so it is better to have a boiler a bit too small than too big. Because an oversized boiler will cause trouble almost the entire season, and a bit too small for a week a year at most.
    Certainly - gas boilers are now available in only 2 or 3 power versions (oscillating just around 20 kW) - this is due to their great power modulation capabilities. In the case of a gas boiler, you should focus more on the parameter of minimum power than maximum ...
    Oh, and it is also important whether your boiler will heat DHW ...
  • #7 17083744
    suharow
    The building is new, yet not insulated.
    The boiler is also to heat domestic hot water
  • #8 17083761
    Xantix
    Help: 686
    Rate: 1657
    And when do you plan thermal insulation?
    What is your domestic hot water consumption?
    Use the website http://cieplowlasciwie.pl as advised by a colleague above. It's a pretty good free OZC calculator.
  • #9 17083827
    suharow
    I counted in this calculator and for the insulated one it came out 10-12 kW and for the under-insulated one 24 kW.
    We plan thermal insulation for next year (money, or rather the lack of it).
  • Boiler sizing must include DHW tank and controls
    #10 17084024
    Aaalbercik
    Help: 38
    Rate: 81
    I understand that through the hot water heater
    so you need to check the coil power in the tray
    in addition, the type of the tank (with a coil or double-walled)
    The capacity of the cylinder coil should be the same or greater than the boiler capacity.
    You select the boiler according to the target heat demand.
    You take into account central and hot water
    The fact that the building is now not insulated is a transitional period and the power of the boiler
    choose a finished house.
    In addition, there is also the boiler automatics, because it "governs" the power transferred to the central heating and hot water
    I would propose to ask the seller for the selection of devices (you can verify what he chooses)
    If you make mistakes when purchasing devices, operation may be far from optimal.
    In the sets: heating boiler + DHW tank + control, minor errors are often important in the operation of the set.
  • Smaller burner option for future insulation upgrade
    #11 17084030
    sq9etc
    Help: 11
    Rate: 15
    Some manufacturers of boilers with a feeder can order a smaller boiler with a burner from a larger model. That is, for example, a 17 kW boiler with a burner from the 25 kW version. Something like this would arrange you, after insulation you put on the right burner and it's ok. Unfortunately, it costs a bit and before you warm up you have to accept the boiler with a higher flue gas temperature, i.e. with lower efficiency, when the boiler will operate above the declared power. However, there should not be many such situations.
  • #12 17085218
    suharow
    In that case, I conclude that 24 kW from the project is too much power and look for about 16 max 20 kW
    Xantix
    Help: 686
    Rate: 1657
    You just need 16 kW. As I wrote, the 24 kW for an uninsulated house is only available for a daily temperature of around -20 degrees. For a crushing part of the heating season, you'll need less than half that power, around 10-12 kW. A 16 kW boiler will still have a reserve for typical frosts, and if the temperature drops to -20 degrees for a few days, you can temporarily heat yourself up with e.g. oil.
  • #14 17085908
    MEVEX1
    Rate: 8
    New generations of eco-pea coal boilers, and more precisely, multi-fuel boilers with a gutter burner recommended by me, the retort limits the user to one fuel, in the power range of 15kw to 25kw eco-kwp multi have identical burners. The boiler power is regulated by the controller itself and the selected blowing. Drivers e.g. tech-483 with pid. in the service settings tab, it has limited airflow and not only to the given maximum boiler power. Of course, the construction of a boiler, e.g. 15kw, will not allow you to achieve 25kw of heating power by changing the settings alone, and to maintain the 5th class of flue gas emission, too small area of the boiler water jacket. Remember that the boiler should be chosen by an installer experienced with this type of boilers. low boiler power. At the first stage, high boiler inertia, increase in boiler temperature after the above-set one, long downtimes, which are very dangerous with pellet fuels, heat retraction into the container; at the second one, there is no additional heating of the boiler, the effect of condensation on the walls of the boiler, airflow operation in high speed ranges, which causes the blow-out of light fuels.At the end, the boiler installation itself can reduce its efficiency by up to 30 percent. Blacksmiths will not install and set these boilers correctly.
  • #15 17085999
    Sstalone
    Help: 72
    Rate: 398
    1. The boiler should be selected according to the heat demand after thermal insulation.
    2. Do not oversize the power of the feeder boiler, unless it is a pellet boiler with an igniter.
    3. For the period of insulation, put a used backfill, unfortunately these are additional costs for installation, it should be considered whether it is not profitable to take a loan for insulation, if there is no own financial resources ...
  • #16 17344693
    suharow
    After consulting with a plumber, I decided to buy a red stove with a capacity of 15 kW.
The discussion revolves around selecting the appropriate boiler for heating with eco-pea coal, specifically addressing power calculations for different building sizes (16 sqm, 24 sqm, and 224 sqm). Users emphasize the importance of considering both usable and total area when determining boiler power. Recommendations suggest that for a well-insulated new house, a boiler power of around 16 kW is sufficient, while for an uninsulated house, a power of 24 kW may be necessary. The consensus is to avoid oversizing the boiler to prevent operational issues, and to consider future insulation plans when making a decision. Users also mention the need for the boiler to heat domestic hot water and suggest using online calculators for precise heat demand calculations.
TL;DR: Use about 75 W/m² (~16 kW for ~224 m²); "better to have a boiler a bit too small than too big." Size eco‑pea coal boilers to heat loss and DHW, not project max. [Elektroda, Xantix, post #17083512]
Why it matters: This FAQ helps homeowners and renovators sizing eco‑pea coal boilers for 140–224 m² homes avoid oversizing, fuel waste, and comfort issues.
Should I size by usable area or total area for eco‑pea coal?
Don’t size by area alone. Use the building’s heat‑loss from your project, or a demand estimate. For a new, insulated house, 60–90 W/m² is a practical check. Choose boiler power to match that heat demand. This avoids oversizing and short‑cycling. [Elektroda, Aaalbercik, post #17083377]
Is 24 kW too big for a 224 m² new build?
For a new, well‑insulated home, 24 kW is oversized. Using 75 W/m² yields about 16 kW. Design powers target rare −20°C days, not typical weather. “Better to have a boiler a bit too small than too big.” [Elektroda, Xantix, post #17083512]
What if my house is not insulated this winter?
Pick around 16 kW, even uninsulated. Most of the season you’ll need only 10–12 kW. A 16 kW unit leaves reserve for typical frosts. If a cold snap hits −20°C, add temporary heat, like an oil heater. [Elektroda, Xantix, post #17085906]
Does heating domestic hot water change the boiler size?
Yes. When using a cylinder, ensure the coil’s heat‑exchange capacity matches or exceeds the boiler’s output. Select the tank type and controls to suit. Size the boiler for the target, insulated demand, covering space heating plus DHW. Controls govern heat distribution. [Elektroda, Aaalbercik, post #17084024]
Why does my project specify a 24 kW gas boiler?
Project specs often list common gas models around 20–24 kW. Gas units modulate widely, so designers focus on minimum power, not maximum. That number does not mean your building needs 24 kW. Match solid‑fuel boilers to actual heat demand. [Elektroda, Xantix, post #17083512]
Can I buy a smaller boiler now and upgrade the burner after insulation?
Yes. Some makers let you pair a smaller boiler body with a larger burner, then swap later. Before insulation, expect higher flue‑gas temperatures and lower efficiency when you push above the declared power. After insulating, fit the right burner. [Elektroda, sq9etc, post #17084030]
Should I oversize a feeder boiler for safety?
No. “Do not oversize the power of the feeder boiler.” Oversizing leads to poor operation and wasted fuel. Exception: pellet boilers with an igniter can tolerate more oversizing. Better invest in insulation than extra capacity you won’t use. [Elektroda, Sstalone, post #17085999]
What goes wrong with bad sizing or setup?
Too low power causes high inertia, overshoot, and long downtimes. Pellets can retract heat into the hopper. Without added reheating, condensation forms on boiler walls. High fan speeds may blow light fuels from the grate. Bad installs can lose 30% efficiency. [Elektroda, MEVEX1, post #17085908]
How do I quickly estimate boiler power myself?
Use a free heat‑demand calculator. 1. Gather area, insulation, windows, and climate data. 2. Enter details at cieplowlasciwie.pl. 3. Read the recommended power and size near the insulated target. Hire a specialist if you need precision. [Elektroda, sq9etc, post #17083363]
What real‑world fuel use should I expect?
A user with about 200 m² plus a heated attic and DHW reported around 500 kg of eco‑pea coal per month at −12°C. Indoor temps were 24°C downstairs and 23°C upstairs. Treat this as an example, not a guarantee. [Elektroda, MEVEX1, post #17083142]
What did the original poster finally choose?
After consulting an installer, the OP bought a 15 kW “red” eco‑pea coal boiler. This follows the thread’s 16 kW recommendation. [Elektroda, suharow, post #17344693]
Is financing insulation smarter than temporary heating hardware?
Consider financing insulation rather than buying a temporary backfill boiler and extra fittings. Temporary setups add cost and complexity. Insulation lowers demand permanently and improves comfort. It can let you choose a smaller, cleaner, cheaper‑to‑run unit. [Elektroda, Sstalone, post #17085999]
Do modern controllers modulate power on multi‑fuel units?
Yes. Controllers like Tech‑483 with PID regulate airflow and firing to track a set power. They also let service limits cap maximum output. However, a 15 kW boiler cannot safely deliver 25 kW by settings alone. Construction constraints still apply. [Elektroda, MEVEX1, post #17085908]
