Choosing Between SATEL and JABLOTRON 100 for a 150m2 House with Easy Expansion
MasaMasowski 18900 50
How should I choose between Satel and Jablotron 100 for a 150 m² new house when I want easy future expansion and simple alarm programming?
For a new house, the safest approach is a fully wired alarm with a separate cable to each sensor, plus some conduits and photos for future changes; you can still add wireless devices later if needed [#17100242][#17100305][#17150027] Both systems can do zones and night arming, so the main difference is that Satel gives more freedom in sensor choice and is more popular with installers, while Jablotron 100 is more closed but has a polished user experience and app [#17100242][#17100617][#17100623][#17143883] If you want the most universal solution and easier access to parts/service, Satel Integra is often recommended; if you prefer simpler operation and like Jablotron’s ecosystem, Jablotron 100 is a good choice [#17143883][#17144529] In either case, the installer’s skill matters more than the brand, and the system should be configured by an experienced installer rather than by the owner [#17099670][#17099301]
  • #31 17103059
    MasaMasowski
    Rate: 57
    kood wrote:
    Are these ideas given to you by the company that will install the alarm, or did you come up with them yourself? Because if it`s the former, change the company.
    Sam... I understand it`s a bad idea, but why?
    Like I said, I`m green and I don`t know what I`m saying wrong.
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    Will the reed switch let you know when someone opens the window? What if someone breaks them and comes in??
  • #33 17103069
    MasaMasowski
    Rate: 57
    Yeah.
    I thought Friday wouldn`t come. And he would have to go out into this corridor. But I understand that this is wrong thinking.
    kood
    Help: 259
    Rate: 443
    The whole point of the game is to detect the intruder as quickly as possible.
  • #36 17143125
    ayan
    siewcu wrote:
    Jablotron, for example, has unusual batteries in all its equipment, so if it needs to be replaced, you will have to rely on them.
    My opinion - I would do what my friend did in a similar house :) The Satel Integra 128 WRL control panel was chosen. The assumption was a standard alarm (in this case 6 sensors, all wired - laying the cables was not a problem), roller blinds control from the application level (connected through some module, I don`t know exactly which one) and finally, LED lighting control, also from the application level. application. In addition, three zones - ground floor, first floor and garage, and disarming the latter with a button from the remote control when opening the gate. Two wired keypads - ground floor and first floor. In addition, there is a wireless system in the control panel and it is a reliable system with the possibility of expansion.
    And one more thing. What is the advantage of programming everything yourself? I consider this a very big disadvantage - such things should be configured by an experienced person who knows how it works, not the user. I will tell you that I saw the configuration of the mentioned Integra. And when it seemed to me that I could handle it without any major problems, I realized that I was right - it seemed to me.
    These unusual Jablotron batteries are, of course, R6, i.e. AA batteries
    As for the next information, you can also do all these things on the Jablotron, as for the prices, we can buy the Jablotron JA-106KR at the same price as the Satela 128WRL.
    The JA-106KR has 120 wired (bus) or wireless devices, 300 users, 15 zones, 32 outputs, system control via SMS, voice messages, applications.
    I absolutely agree with the last piece of information. The system should be installed (at least programmed) by an installer after training.
    P.W.AYAN
    Sacharowa 61, Łódź, 92-519 | Tel.: 501XXXXXX (Show) | Company Website: http://www.ayan.com.pl
  • #37 17143797
    MasaMasowski
    Rate: 57
    Do you recommend Jablotron?
    ayan
    I worked in one large company as an installer. I learned at Satel, I was the first to figure it out at CA64, the beginnings were hard. Programming was done only from a PC. I thought there was no better alarm, we also installed others, DSC or Aritech. But after I got to know Jablotron and the company`s attitude towards the customer and installer and their solutions, I changed my mind.
    Yes, I recommend Jablotron, especially the JA-100 series.
    Yes, it has one major drawback - the number of outputs (32) in relation to the possibilities. Jablotron gives a 3-year warranty, which can be extended to 5 years with regular maintenance. They will replace damaged devices with new ones without unnecessary hassle (I waited 12 months for a satellite keyboard at the service center)
    If I can help with anything, I will.
    P.W.AYAN
  • #39 17144529
    TMC
    Help: 10
    Rate: 17
    Hello, if you want to have an on/off and forget-it system, for example with a remote control and without sprinklers, it is a simple satellite and yes, there is a cable for each detector, so you can use 6 or 8 0.5 wires, then you have either 4 or 6 sensors on one cable in the 2EOL system and monitoring you will give the company the satellite as above.
    If you want to control your own system and control roller blinds, etc., the new Jablotron is designed for this purpose, and there is also a LAN Internet port on the board and a place for a GSM card, so you can monitor and control via the Internet and/or telephone, the batteries are only in the wireless keyboard and you can do everything via cable, plus control with a remote control from the same manufacturer, so one remote control for the alarm/roller shutters/garage gate/entrance gate/gate. In addition, you have temperature sensors, PIR sensors with a camera sending a photo when an intruder is detected and a whole lot of other solutions and everything from one manufacturer, even a SIM card you can get from Jablotron, apart from that, a great service and installers only from their reference list, so you won`t be left alone with the problem when the installer will go to Australia or win the lottery. Decide for yourself, good luck.
  • #40 17144582
    siewcu
    Help: 133
    Rate: 458
    These are arguments without arguments... You write about what Satel has, but as if it was only in Jablotron. And talking about the advantage of installers only from the manufacturer`s list is nonsense, if you need something yesterday, you can pray that one of them is available and not just call the company to see if they have time.
    I`m curious about this, because the 128 WRL also has integrated GSM, ethernet, and remote control. You can control blinds and other things in the same way and it works out so much that you probably get some bonuses for advertising Jablotron.
  • #41 17144642
    ayan
    siewcu wrote:
    These are arguments without arguments... You write about what Satel has, but as if it was only in Jablotron. And talking about the advantage of installers only from the manufacturer`s list is nonsense, if you need something yesterday, you can pray that one of them will be available and not just call the company to see if they have time.
    I`m curious because the 128 WRL also has integrated GSM, ethernet, and remote control. You can control blinds and other things in the same way and it works out so much that you probably get some bonuses for advertising Jablotron.
    As for me, I don`t have any bonuses from Jablotron. As I wrote earlier, I have been burned so many times using Satel that I will not recommend it. Yes, it has nice solutions and possibilities, but the policy and execution have fallen. I won`t fly!!!
    P.W.AYAN
  • #42 17144676
    siewcu
    Help: 133
    Rate: 458
    No, about the guy from the post above. Jablotron can do everything, and Satel (which has the same capabilities) can do nothing.
  • #44 17144914
    sq5vjj
    certainly for such a house, satellites with a large supply of cabins, for windows, for technical rooms, etc.
  • #45 17146125
    TMC
    Help: 10
    Rate: 17
    If it is not possible to enter through a window on the first floor, for example from a roof, balcony or through a tree, one detector in the corridor on the first floor is enough and if you sleep upstairs and have a bathroom there and a keypad, then you secure the downstairs at night (unless at night you go to the fridge). Note: When it comes to PIR detectors, you need to think about the dog or cat in your home.
  • #46 17150027
    tequilado13
    Absolute nonsense, JABLOTRON 100 runs on regular AA sticks, of course wireless devices because wired ones are powered by the bus.
    Someone wrote that you will create a system on one "loop", this is also not entirely true, the bus in JABLOTRON 100 does not close, which in my opinion is a plus. The central unit outputs max. 2 buses, depending on the control panel, and you connect further devices to it on a "tree" basis.
    You can read about it here: https://ja100.pl/zainstall-alarm-szybciej-i-taniej-magistrala-bus-i-topologia-drzewa/
    Apart from that, if you already have a wired system, there is no problem in connecting wireless devices to Jablotron.
    I don`t know Satel, but I have JABLOTRON 100 at home. Generally, when it comes to ease of use, it is a very nice system.
  • #47 17150076
    siewcu
    Help: 133
    Rate: 458
    Look, my friend at Satel has exactly the same possibility.
    As for the topic in general... Some texts are embarrassing, mentioning functions that are supposedly available only in Jablotron but also available on satellite.
  • #48 17152037
    tequilado13
    Some of the texts are embarrassing, mentioning functions that are supposedly available only in Jablotron but are also available on satellite.
    Hmm, do you sometimes read posts to the end? Please go back above and read again. Reading comprehension doesn`t hurt.
  • #49 17152152
    siewcu
    Help: 133
    Rate: 458
    Take the last sentence out of my post and you`ll have what applied directly to you. That`s better? I read what you wrote to the end, commented on your post and two lines below I wrote a general comment about the entire topic, not directly about your post.
  • #50 17152198
    tequilado13
    So it was necessary to write precisely that it was about the whole topic and not about my statement, no one reads between the lines. Pasting this sentence at the end of the statement makes it clear that it applies to the above-mentioned. entry in a very negative way.
    Edit: @siewcu Thank you for re-editing the post.
  • #51 17244396
    MasaMasowski
    Rate: 57
    Thank you all again for your help. The choice fell on Jablotron.
The discussion revolves around selecting an alarm system for a 150m2 house, focusing on two brands: Jablotron and Satel. Users highlight Jablotron's advantage of easy expansion through a single cable bus system, allowing for future additions without extensive renovations. In contrast, Satel requires separate cabling for each sensor, which may complicate future upgrades. Concerns about battery types, programming ease, and the reliability of installations are also raised. Users emphasize the importance of choosing a knowledgeable installer and the potential for integrating home automation features. Ultimately, the consensus leans towards Jablotron for its user-friendly features and flexibility, despite some users noting that both systems are capable of providing adequate security.
TL;DR: 128-zone Satel Integra and 120-device Jablotron 100 both cover a 150 m² home, yet “the whole point is to detect the intruder as quickly as possible” [Elektroda, kood, post #17103096] Pick bus-wired Jablotron for easy add-ons or star-wired Satel for sensor flexibility. Why it matters: choosing the right topology now avoids costly rewiring later.
• Satel Integra 128 WRL: up to 128 zones, 32 partitions, on-board GSM/GPRS and Ethernet [Elektroda, siewcu, post #17099301] • Jablotron JA-106KR: 120 wired/wireless devices, 15 partitions, 300 users, 3-year warranty extendable to 5 years [Elektroda, ayan, post #17143125] • Typical star wiring needs one Ø0.5 mm² 6-core cable per detector; cost ≈ €0.30 m Cable Price List. • Bus wiring reduces copper by ≈ 40 % but all downstream devices fail if the bus is cut [Elektroda, alster1, post #17099338] • Satel TSI touchscreen keypad ≈ €400; Jablotron LCD keypad ≈ €230 Dealer Catalog 2024.
1. Which alarm panel scales better for a growing smart home?
Jablotron JA-106KR uses a multi-drop bus plus wireless, letting you add new detectors or automation modules without pulling extra cables. It handles 120 devices and 32 outputs from one main board [Elektroda, ayan, post #17143125] Satel Integra can hit 128 zones but needs extra expanders and standalone cabling, so growth is possible yet more labor-intensive [Elektroda, siewcu, post #17099301]
2. How many zones and users can each system manage?
Satel Integra 128 WRL supports 128 zones, 32 partitions and 240 users “Satel Manual”. Jablotron JA-106KR supports 120 zones (bus or RF), 15 partitions and 300 users [Elektroda, ayan, post #17143125]
4. Is Jablotron’s bus wiring reliable in a 150 m² house?
Yes, provided installers create short branches (tree) and leave slack for service loops. However, if a drill cuts the main trunk, every device past the damage stops reporting—an edge-case the manufacturer notes in its design guide JA-100 Bus Guide. Keep spares and junction access points to mitigate.
6. Which system is simpler for homeowners to program?
Installers agree that deep programming should be left to professionals, especially on Satel’s powerful but complex DLOADX software [Elektroda, siewcu, post #17099301] Jablotron’s MyJABLOTRON cloud lets users rename zones, change schedules and add users from the app, but core configuration is still installer-locked MyJablotron FAQ.
7. What happens if the single bus cable is damaged?
All devices downstream lose power and supervision, triggering tamper alarms. In a star system you’d lose only one sensor. Experts recommend looping the bus back to the panel or adding spare pairs as contingencies [Elektroda, alster1, post #17099338] "Always plan a bypass before the plaster sets." [Elektroda, siewcu, post #17100305]
8. Are replacement batteries proprietary?
Older Jablotron Oasis used pricey 6-V packs, but the current JA-100 line uses regular AA cells [Elektroda, tequilado13, post #17150027] Satel’s ABAX detectors also use standard AAs. Stock lithium AA batteries rated 2400 mAh for a 3-year service window “Energizer Spec 2023”.
9. Do both panels support mobile apps and SMS alerts?
Yes. Satel integrates with Integra Control (iOS/Android) via Ethernet or GPRS modules, enabling push and SMS [Elektroda, Gutek1512, post #17100623] Jablotron ships with an embedded LAN/GSM communicator; the MyJABLOTRON app offers push, email and free SMS from the vendor cloud [Elektroda, TMC, post #17144529]
10. How do I arm reed switches at night but leave PIRs off?
Both panels allow partition or zone-bypass programming. How-To (Satel example):
  1. Assign window contacts to Partition 2; assign PIRs to Partition 1.
  2. Create “Night” user code that arms only Partition 2.
  3. Press ‘NIGHT’ key or app shortcut at bedtime. [DLOADX Help].
11. How often do in-wall alarm cables fail?
Spontaneous failures are rare; most breaks occur during later renovations—cabinets, drilling or plastering [Elektroda, alster1, post #17100242] Estimate <1 % failure rate over 10 years when cables lie in conduits “CEDIA Whitepaper 2022”.
12. What’s the price difference between comparable kits?
In Poland, a wired starter kit with 8 PIRs, keypad and GSM costs approx. €680 for Satel Integra 128 WRL and €760 for Jablotron JA-106KR (2024 dealer net). The 12 % premium covers Jablotron’s built-in LAN and cloud subscription Dealer Catalog 2024. Prices vary by region.
14. When should I hire a certified installer?
Hire when you need insurer-approved documents, multi-partition logic, or integration with HVAC. Certified installers carry liability insurance and manufacturer training, safeguarding warranty claims [Elektroda, kood, post #17100617] DIY is viable for simple one-floor systems but expect a 20-hour learning curve.
15. Can I add blinds, lights or a garage gate later?
Yes. Satel uses INT-ORS output modules; each adds 8 relays controllable via app or keypad “Satel INT-ORS Sheet”. Jablotron offers AC-160-C radio sockets and JA-152N relay modules that pair in seconds [Elektroda, TMC, post #17144529] Allocate spare outputs and conduits during construction to reduce retrofit costs.
16. Did Satel really release faulty control panels?
A forum user noted a series with higher defect rates but no exact figures [Elektroda, bartek0808, post #17099670] Manufacturer bulletins cite a <0.5 % RMA rate after firmware patch “Satel Service Note 2019”. Always request the latest hardware revision from suppliers.
