Canon Pixma G3400 vs Epson L3050: Comparing Multifunction Printers for Home Use, Photos & Cost
stefan1908 8349 10
Which multifunction printer should I choose for home use with occasional photo printing: Canon G3400 or Epson L3050, and what other models are worth considering?
For home use, the Canon G3400 is an older model, and if you want a newer Canon G-series printer you should look at the G3410 or G4410 instead; the Epson L3050 also has no LCD display, while the L3070 adds an LCD and memory card support [#17118898] If photo quality matters more, the thread points to Canon TS8050 or MX925, or Epson Expression Premium XP-530/XP-630, as better choices for high-quality photos [#17123233] The Epson XP-342 is described as a good printer for ordinary documents and school use, but not as a high-quality photo printer [#17123233] Another reply suggests that for cheap ink use and simple home printing, models like Epson XP-342, Canon MG5750, or Brother DCP-J105 / T500 can be enough around the 300 PLN range [#17124133]
  • #1 17118676
    stefan1908
    Rate: 22
    Hello. I would like to ask for help in choosing the multifunction printer. My initial choice fell on the canon G3400 or epson L3050. The devices have similar parameters, but the devil is in the details, and I do not know them too much. The printer is typically for home use, sometimes a photo. The price is also within the "limits", they have a permanent power supply system, the original inks reasonable prices. Until now I had a laser CLP-300, but begins to refuse to obey (dirty cards) and it's time to think about a new one. Please any suggestions
  • #2 17118898
    hessto
    Help: 10
    Rate: 79
    Canon G3400 is old, then the new Canon PIXMA 2018 G series - G1410, G2410, G3410, G4410.
    Epson Expression Premium XP-530 (ink inks Epson Claria Ink it's high quality, price is expensive).
    Epson L3050 - no LCD display.
    Epson L3070 - LCD display, memory cards.
    Epson Ink (ink color paint info bottom)
  • #3 17119078
    stefan1908
    Rate: 22
    I would like a canon g3410 although the price of the epson L3050 is comparable and even give an additional 2 volumes. black ink. But which of the two will be better and problematic to use. And what do you think about Brother InkBenefit Plus DCP-T500W
  • #4 17122992
    stefan1908
    Rate: 22
    And what do you think about EPSON XP342 can always be changed to "eternal cartridges" or ciss system it will come out cheaper than, for example, canon g 3400 or epson l3050, and it has both a display and a memory card slot, only as the printer works. Maybe some of the users will say
  • #5 17123233
    hessto
    Help: 10
    Rate: 79
    Photo-HQ (High Quality).
    - Canon TS8050 and MX925 have a high 2400dpi.
    -Epson Expression Premium XP-530, XP-630.
    EPSON XP-342 is a good, but not-HQ-photo.
  • #6 17123417
    stefan1908
    Rate: 22
    Photos do not have to be a priority although sometimes something will print, it is important that the printer was OK. It has to be typically for home use, photocopying, printing to school, etc. I guess I will be tempted.
  • #7 17124133
    hessto
    Help: 10
    Rate: 79
    Printers and cheap inks, resetter.
    Ordinary office doc, txt, color ... to school and printers ~ 300 PLN is enough ...
    Epson XP-342, inks, resetter, WIC program
    Canon MG5750, inks, reseter, WIC program, canon servic tools.
    Brother DCP-J105 ew T500.
  • #8 17124351
    stefan1908
    Rate: 22
    I am almost decided on this epson xp342, the price is that if something happens to the printer after a while, it won't be such a loss, and maybe the copier will be functional and all you have to do is buy a printer from the top shelf. One more thing that makes me wonder is whether the menu on the display is in Polish, and whether the configuration with wifi is quite simple because I'm thin
    Added after 4 [hours] 53 [minutes]:
    Well, it happened I bought this XP342 printer and after the first start it turns out that it prints in blue, I have no idea how to set it up. The attachment prints from the old laser printer which is dirty and the one from xp342 in blue. The second thing as long as the network connection went I have no idea how to connect to a smartphone without any problems. Maybe some of my friends would lead me by the "handle" how to put it
    • Canon Pixma G3400 vs Epson L3050: Comparing Multifunction Printers for Home Use, Photos & Cost 20180324_162740.jpg (547.31 KB) You must be logged in to download this attachment.
    • Canon Pixma G3400 vs Epson L3050: Comparing Multifunction Printers for Home Use, Photos & Cost 20180324_162724.jpg (1.85 MB) You must be logged in to download this attachment.
  • #10 17125610
    stefan1908
    Rate: 22
    I have already dealt with these colors, a unique school mistake, I am ashamed to admit I simply did not rush those straps from the cartridges. As for the first tests I am happy with the purchase, I still master these settings, e.g. for photos and it will be OK.
  • Estimated PLN 400 for multifunction printer with CISS
    #11 17136582
    stefan1908
    Rate: 22
    I'm happy with the printer, it meets my expectations, the display is also a nice thing, the ciss system is on its way, and it is very far away. After adding up the costs, it will cost around PLN 400 for a multi-functional color device with wifi, a memory card slot and a display, as well as an additional permanent power supply system - it's a decent price. Thank you hessto colleague for the advice and I think I can end the topic
The discussion centers on selecting a multifunction printer for home use, specifically comparing the Canon Pixma G3400 and the Epson L3050. Users highlight that both models have similar specifications, but details such as display features and ink costs are crucial. The Canon G3400 is noted as older, while newer models like the G3410 are suggested. The Epson L3050 lacks an LCD display, which some users find limiting. Alternatives like the Epson XP-342 and Brother DCP-T500W are also mentioned, with considerations for cost-effectiveness and features like Wi-Fi connectivity and memory card slots. Users express satisfaction with the Epson XP-342 after initial setup issues, emphasizing the importance of print quality for both documents and occasional photos.
